The best PIC Q dvd player!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 10-26-2004, 07:55 AM - Thread Starter
joerod's Avatar
Quoted: 704 Post(s)
Liked: 633
This thread is to see what people think not read as to which dvd player has the best overall picture quality! If you were stranded on a desert island and needed the best pic Q available which unit would you ask for. Pioneer, Denon, Sony, Arcam, Bravo, Samsung, Panny, Zenith, Toshiba, Apex or any dvd player you can come up with that you have experience with. Component, Dvi, Hdmi does not matter, it could have any output. What does matter is the Pic Q! For the norm, try and keep it a unit under 2,500. With HDDVD and BluRay coming, I can't see anyone spending more than that on a DVD player today.
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #2 of 18 Old 10-26-2004, 08:14 AM
Q of BanditZ's Avatar
Oh no, not another one of these... This will turn into a fanboy pissing contest before day's end.
I'll just cut to the chase: Integra 10.5, Onkyo 1000, Denon 3910, Pioneer 59, a couple of Arcams, the old Panasonics that everyone raves about around here, etc. etc. This is just going to go nowhere.
You're going to get a different answer from whoever responds to this thread. Good luck.
Great ISF Job by Chad B.
Q of BanditZ is offline
post #3 of 18 Old 10-26-2004, 08:22 AM
djironic's Avatar
In addition, it's highly dependent on the display device, as I've learned. The same DVD player will look better or worse on certain displays, so it's nearly impossible to look at DVD player PQ by itself without factoring in the display.
djironic is offline
post #4 of 18 Old 10-26-2004, 10:59 AM
mpgxsvcd's Avatar
Quoted: 2709 Post(s)
Liked: 2411
I will just jump in and say the DVD decoder that everyone else will forget to mention. Use a Home Theatre Computer! The new Nvidia decoder combined with FFdshow corrects all of the problems that exist in other DVD players and it allows true resizing at what ever resolution you choose and you can output over any type of conector including component cables. White/Black crush, Chroma Bug, Jittering, Green/Red Push, and aspect ratio problems can all be corrected with an HTPC. What more could you ask for? Every single stand alone DVD player has some sort of defect. With an HTPC you can eliminate them all.
mpgxsvcd is offline
post #5 of 18 Old 10-26-2004, 11:26 AM
You lose convenience with HTPC and for the guy who wants to just plug, play, and be off to the races in seconds, it's not very practical, but yes, it can yield very nice fruits.
post #6 of 18 Old 10-26-2004, 11:37 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3523 Post(s)
Liked: 4514
It's evident from all the research I've done that the best picture quality is only available from those DVD players that haven't started shipping yet. Every reviewer seems to agree that the player, "just around the corner" is clearly superior. Players only seem to develop significant picture quality problems after they ship. Probably the bits wear out with use....
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #7 of 18 Old 10-26-2004, 11:50 AM
pnichols's Avatar
It's obvious what the best PQ DVD player could be - a heavy case with a reliable DVD drive inside, a decoder chip from a Pany XP50 inside, and an iSCAN HD+ inside. Simple.
Build it and we will come.
Phil
pnichols is offline
post #8 of 18 Old 10-26-2004, 06:23 PM - Thread Starter
joerod's Avatar
Quoted: 704 Post(s)
Liked: 633
Q, If you had one choice, between the Pioneer 59 and the denon 3910, which would you get??? Thanks I really appreciate your views...Joe
joerod is offline
post #9 of 18 Old 10-26-2004, 07:35 PM
rbmcgee's Avatar
Q, not to pounce, but there is simply no STB anywhere that can hold a candle to the convenience of a properly setup HTPC.
PS: when I speak of convenience, I'm referring to "using" rather than "setting up/acquiring".
Bob
rbmcgee is offline
post #10 of 18 Old 10-26-2004, 08:08 PM
CCarncross's Avatar
rbmcgee, I'm assuming you're relying on ripping all your titles to HD's, which some people do not do, because its still up in the air about its legality. There are actually some honest people left in NA. WHen left to our own devices, most do not take the high road.
CCarncross is offline
post #11 of 18 Old 10-26-2004, 08:45 PM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 42
The new APEX player, 1080P upconversion. It will be available at Walmart for $49 in about two years.
My Theater Room JVC RS4910, Panamorph UH480, 148 in. 2.40:1 Dalite HD Pro 1.3, Klipsch THX Ultra II's x 7, Quad JTR Captivator S1 subs
My Previous Non-Dedicated space
RobZ is offline
post #12 of 18 Old 10-26-2004, 08:50 PM
Waterbug's Avatar
LOL!
two wrongs don't make a right, it makes an even.
Waterbug is offline
post #13 of 18 Old 10-26-2004, 09:43 PM
rbmcgee's Avatar
Obviously ripping DVDs to the server makes the whole process much easier, however even when playing from discs, nothing can beat the convenience of an HTPC. Not by a long shot.
BTW, as I've stated, I own all the DVDs I rip ... so I don't appreciate your insinuation.
Bob
rbmcgee is offline
post #14 of 18 Old 10-26-2004, 10:10 PM - Thread Starter
joerod's Avatar
Quoted: 704 Post(s)
Liked: 633
Thanks to those of you that provided a good opinion, and to those that went WAY off topic. Anyway the point was if you were on a desert island and could only have ONE dvd player with your display, which unit would it be???
joerod is offline
post #15 of 18 Old 10-26-2004, 10:30 PM
Earz's Avatar
I would take an Onkyo sp 1000 unless of course my name was Thurston Howell the third..then I would be more inclined to take this slightly more expensive player http://www.goldmund.com/products/eidosreference/
Earz is offline
post #16 of 18 Old 10-26-2004, 10:37 PM
ac388's Avatar
Quoted: 115 Post(s)
Liked: 38
The best one in HK now is Marantz 9500. BAR NONE !!!!!!!!
Man see things as they are n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
post #17 of 18 Old 10-26-2004, 10:42 PM
pnichols's Avatar
joerodcowboys, <- quite the handle!
"Anyway the point was if you were on a desert island and could only have ONE dvd player with your display, which unit would it be???"
Aren't you reading the posts? Again ..... here's mine from above: It's obvious what the best PQ DVD player could be - a heavy case with a reliable DVD drive inside, a decoder chip from a Pany XP50 inside, and an iSCAN HD+ inside. Simple.
(P.S. Just giving you a hard time ...... isn't this HT stuff fun!?)
BTW, I guess you would want a pretty good portable generator on that island too? I can recommend one! ;)
Phil
pnichols is offline
post #18 of 18 Old 10-26-2004, 10:42 PM
Shock96's Avatar
I will stick with my Denon 1600 thank you.
Mike
Shock96 is offline
Closed Thread DVD Players (Standard Def)
