Panasonic DVD-S97S FAQ / Brain dump - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
post #811 of 4325 Old 11-06-2004, 09:02 PM
Sango's Avatar
Quoted: 16 Post(s)
Hmm I didn't think of mpeg4 in that way. I thought thought that DivX and Xvid are completely differnet formats and the same with MPEG 4.
My S97 is on back order and I'm the first to be on the next batch which comes in from Onecall.
Sango is offline
post #812 of 4325 Old 11-06-2004, 09:10 PM
mallu2u's Avatar
Originally posted by Sango
Aww that's so curel!! j/k!! lol!!
I'll have to try it when I get my unit when it arrives.
What is the trick and what does it attempt to do?
mallu2u is offline
post #813 of 4325 Old 11-06-2004, 09:37 PM
gcmail's Avatar
S97 REPORT
Panasonic S97 HDMI-HDMI
Panasonix 53x54 Widesceen RPTV
Coax connection to Yamaha HTR 5150
PSB Speaker System
Discs used: DVE, Star Wars Trilogy, Lord of the Rings Trilogy, Monsters Inc., Matrix Reloaded, Day After Tomorrow.
I will say that this player outperforms the Denon 1910 in both video and audio performance by a wide margin. The MB is frustrating, but I was able to reduce it to "acceptable" levels after half a day of fine tuning and testing. While I found it unacceptable on the Denon, the added picture and sound quality on the S97 made the MB negotiable for me.
These were my final settings:
1080i (480p shows no MB but obviously has a softer, less detailed picture, I have no 720 on my RPTV).
HDMI Colorspace -- RGB (Switching from 4:4:4: Colorspace to RGB made the biggest difference in reducing MB).
DNR off (DNR softened the picture and didn't improve MB at all on my set).
User setting 1 AV Enhancer User 1
Black Level - lighter (switching between this and darker, didn't do much)
HDMI RGB Range -- enhanced (really helped MB)
Hope this helps some of you RPTV people.
gcmail is offline
post #814 of 4325 Old 11-06-2004, 10:49 PM
klepoy's Avatar
Hi,
Just purchased the dvd-s97 yesterday. Does anyone know how to make this player correctly play 4:3 DVDs? I've tried setting the picture mode/zoom to AUTO but it still stretches the image on my pioneer 1110hd plasma.
I used to have a Denon 1910 but returned it because it couldn't play 4:3 dvds correctly over HDMI. I hope it's not the same problem with the Panny.
Any help would be appreciated.
klepoy is offline
post #815 of 4325 Old 11-07-2004, 05:32 AM
ahro's Avatar
Quoted: 2033 Post(s)
Liked: 4130
Originally posted by klepoy
Hi,
Try putting the the player setting on 'normal' if I remember, and use the aspect ratio adjustment on your display, That worked for me on my AE500 PJ
korsjs likes this.
HENRY
78HU9000, 10 BIT, TS-01; NEW 3500 OCB, WD PASSPORT HDD
ONKYO TX-NR646 ATMOS RECEIVER
ISCAN MINI, UHD 30 PACK. SAMSUNG BJ7500 BLU RAY PLAYER
USB 3.0 4 PORT HOT SWITCHABLE HUB, ROKU 4,SAMSUNG K-8500 BRP
ahro is offline
post #816 of 4325 Old 11-07-2004, 07:36 AM - Thread Starter
Paul Bigelow's Avatar
klepoy,
See page 15 of the manual:
Display menu: "4:3 Aspect" should be "Normal".
Paul
Paul Bigelow is offline
post #817 of 4325 Old 11-07-2004, 10:16 AM
Sango's Avatar
Quoted: 16 Post(s)
Is to see if the unit has a hidden password window. There is another part after but as long as it's not confirmed I won't say it will be true for this unit.
Sango is offline
post #818 of 4325 Old 11-07-2004, 11:19 AM
Sango's Avatar
Quoted: 16 Post(s)
There should be a significant difference because the those players are using Panasonic's all-in-one chipset which is inferor to that using dedicated chips such as the S97 and 2002 Faroudja based units.
Did you also try S97 using component to see how it does?
I've tried the DVD-S75(aka DVD-S55 for North America), and it was very horrible. The colors didn't quite look well and I saw jaggies in my anime(CG based) on diagonals(very obvious ones)!!
Sango
Sango is offline
post #819 of 4325 Old 11-07-2004, 11:35 AM
vdmai's Avatar
I don't think you're gonna get the "WOW" factor 'til HD or 1080P comes along. You don't think 20-25% is significant?
Daniel
vdmai is offline
post #820 of 4325 Old 11-07-2004, 11:45 AM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
Originally posted by AkaStp
Is it possible that my Sammy 50" DLP does pretty much the same job converting 480p via component from the F87 to the TV's native 720p as the S97 outputs at 720p?
When you use component out of the DVD player there is a conversion to analog. The TV must convert back to digital. That's all extra and error prone. You don't say anything about actual PQ issues.
Is there a difference in details or color when the scene is dark?
What about banding when there is a large area of gradually changing color?
What about skin tone?
If you uses specific scenes that illustrate situations that cause trouble you have a better chance of telling if there are differences.
Also, the Samsung DLP user settings can over-ride differences in PQ between DVD players. What user settings are you using and which model (HLM, HLN, HLP) TV set do you have?
Personally I think 20% - 25% improvement can be significant.
htwaits is offline
post #821 of 4325 Old 11-07-2004, 12:29 PM
Rich4av's Avatar
Sango, if you PM me the information, I'll check for you.
Rich
Rich4av is offline
post #822 of 4325 Old 11-07-2004, 12:55 PM
Rich4av's Avatar
After calibrating my S97, I have enjoyed several days of rediscovering many of my DVDs. I use a projector setup which makes it easier for me to see the picture improvements when it's 8-feet wide.
I have played the Star Wars DVD s many times and do not see MB. I use an HDMI cable and a HMDI-DVI adapter. The color space is always RGB.
I have a "tube" HDTV too, but you can't see as many of the improvements there. The quality of the upscaling and the colors are much improved over my D1 or the HTPC. I, for one, consider this unit a bargain! I have not fired up my HTPC in a week.
Rich
Rich4av is offline
post #823 of 4325 Old 11-07-2004, 01:17 PM
mallu2u's Avatar
for making it region-free? if not, what shall the secret password potentially allow access to?
mallu2u is offline
post #824 of 4325 Old 11-07-2004, 01:19 PM
Sango's Avatar
Quoted: 16 Post(s)
mallu2u,
Yup you got the idea, both region/macrovision free but without the SVC Disc #2 which is the part after, it cannot be confirmed.
Sango is offline
post #825 of 4325 Old 11-07-2004, 01:36 PM
mallu2u's Avatar
mallu2u,
Sango: Then send the info to Rich4av fast. He is willing to give it a shot
mallu2u is offline
post #826 of 4325 Old 11-07-2004, 08:24 PM
Sango's Avatar
Quoted: 16 Post(s)
Didn't work!! I'll have to see if I can find a way when I get the unit.
Sango is offline
post #827 of 4325 Old 11-07-2004, 08:55 PM
Cricricri's Avatar
I count on you for that !
Gimme a new firmware or some funky theory so I can run DVE one more time !
Cricricri is offline
post #828 of 4325 Old 11-07-2004, 11:30 PM
megamii's Avatar
Is this following picture an example of macroblocking?
Note: the blue background is actually black because my digital camera in some ways make blacks into blues. The screenshot is from "The Passion of the Christ" before the ending credits.
megamii is offline
post #829 of 4325 Old 11-07-2004, 11:31 PM
Rich4av's Avatar
AkaStp, our settings will be relative to our displays, so they may not be of much use. Note that the S97 allows you to store 3 User settings.
For me, Contrast = 0, Brightness = 0 or +1 (depending on movie), color = -1, sharpness = +2, gamma = 0 to +5 (on darker movies).
After I calibrated my projector, the picture detail and color are just amazing. I also have been watching older DVDs
Rich
Rich4av is offline
post #830 of 4325 Old 11-08-2004, 05:14 AM
ToddMcF2002's Avatar
Regarding that posted picture - I see that kind of thing occasionally on my Momitsu. If that is as bad as it gets maybe I should just order this Panasonic.
ToddMcF2002 is offline
post #831 of 4325 Old 11-08-2004, 05:37 AM
Bytehoven's Avatar
Quoted: 36 Post(s)
Liked: 66
Does the S97 offer all of these adjustments over the HDMI output? I assume yes.
RJ
XBL GT: J05HB4G05H
PSN ID: Bytehoven
Battle Log: Bytehoven
Bytehoven is offline
post #832 of 4325 Old 11-08-2004, 07:58 AM - Thread Starter
(picture edited out)
megamii,
I don't have the movie, but I think that is what is being seen in the picture. It could just as easily be the transfer. Again, my picture of the macroblocking is "brightness enhanced".
Paul
post #833 of 4325 Old 11-08-2004, 08:03 AM - Thread Starter
Bytehoven,
Yes, these adjustments are available via HDMI.
Paul
post #834 of 4325 Old 11-08-2004, 08:05 AM - Thread Starter
My settings:
Contrast = 0, Brightness = +1, Sharpness = -1, Color = 0, Tint = 0, Gamma = 0.
post #835 of 4325 Old 11-08-2004, 08:17 AM
LiteUp!'s Avatar
My Samsung HD TV is a HLM507, two years old.
I did not notice any improvement from the S97 at 480p over component vs. the F87 at 480p over component.
I didn't mention PQ issues because I didn't really notice any. I have followed many of the threads and descriptions and discussions of macroblocking and other issues but I didn't notice anything like that, not even on Finding Nemo. Nothing jumped out as unusual or unacceptable. Maybe I need to sit closer to the display and look harder to try and find the problems.
I used 20-25% to try and convey that there is some improvement over the F87's PQ, but not a lot. I.e. it is hardly noticeable TO ME. But, no, I don't consider 20-25% to be a very significant improvement. To be honest, I expected a lot more out of a $300 DVD player but, as others have stated here and elsewhere, there are limits to what can be extracted out of existing DVD material. Someone, somewhere in this forum, made the statement that you can't get gold from coal.
Believe me, I keep looking hard to try and find the improvements because (a) it is a much more expensive player and (b) many of you have said that the PQ should be much better than run-of-the-mill non-upconverting players and (c) I'm trying to find reasons to justify keeping it over my 60-day old F87 which, unfortunately, I'm outside of the return period for. Upon reflection, I should not have bought the F87 with the S97 on the horizon and, if I had not, I would have no hesitation to keep the S97. Anyone want a barely used (<60 days) old F87?
But, there is another issue I'm wrestling with. As my TV has just the one DVI input I had to disconnect my Sammy 360 D* HDTV receiver to use it for the S97. In order to dedicate that DVI input to the S97 I have to use component or RGB for the HDTV receiver but am not as happy with the resulting PQ over component or RGB vs. DVI. I find that the difference in PQ for the HDTV receiver between DVI and component or RGB to be much more noticeable than for the S97 over DVI relative to the F87 over component. I really don't want to spend $200-300 on a switch and the necessary extra cables and adapters. So, it seems to me, that the best use of my TV's DVI input is for HDTV receiver. It seems rather pointless to use the S97 at 480p over component.
As I've mentioned earlier, I am not a videophile. I have not even fully calibrated my kit yet. I'm just looking at overall PQ from a purely subjective standpoint. This is just one person's opinion presented for what is worth. Your experience may be totally different. You know what you are looking for.
AkaStp,
Have you not noticed the horrible chroma bug problem on your F87? That alone kills it for me and there is really no comparison. I have an F85 that has it as well...it is very noticeable to me, especially on any animated films. The S97 apparently does not have this problem, that's why I am actually very interested in finding out exactly what they did in the new MPEG decoder over the XP30/50/RP82. The F87 (and F85) uses MEI's all-in-one bargain MPEG decoder that has various problems, unlike the "near-perfect" RP-82/XP-30/50 from 2 years ago.
The only way society can advance is with open and independent thought.
LiteUp! is offline
post #836 of 4325 Old 11-08-2004, 08:20 AM
mallu2u's Avatar
Guys: Ordered the player from JR on Friday. Will get by middle of next week but got a good price on it. PM me if you need details (as we are not allowed to discuss prices here).
Also, please post your settings for the player, esp if you have a RPTV. I have a Sony XBR 60'' and am looking forward to setting it up right with this player.
mallu2u is offline
post #837 of 4325 Old 11-08-2004, 08:24 AM - Thread Starter
I guess I should go through the player tonight and post my settings (at least the ones changed from default).
Paul
post #838 of 4325 Old 11-08-2004, 08:59 AM
LiteUp!'s Avatar
Paul
Thanks Paul! Much, much appreciated.
LiteUp! is offline
post #839 of 4325 Old 11-08-2004, 09:14 AM
docdish's Avatar
Hi All,
Just purchased one from J&R.
Have been very impressed by the efforts thus far to evaluate the video aspects of the player. It seems to approach state of the art in this regard.
What I am curious about, and have not seen mentioned, is anyone's opinion regarding the audio output of the player.
I hope to use it via HDMI to SA-XR70(if it ever ships), so I am not that concerned regarding its D-A performance.
I don't know if anyone has had a chance to compare it's digital output with either 2 channel or DTS/DD from players regarded to have quality audio sections such as the current crop of denons, or for that matter a comparision to a dedicated CD player (do these still exist?).
Regarding enhanced playback, don't know if anyone has listened to DVD-A discs or HDCD with the unit.
Many thanks in advance,
Michael Sabadish
docdish is offline
post #840 of 4325 Old 11-08-2004, 10:00 AM
Rich4av's Avatar
Yes, it does. The PQ on the HT1000 (which you also own) is amazing at 720p. I do not see any MB.
Rich
Rich4av is offline
Reply DVD Players (Standard Def)
