Sony DVP-NS975V FAQ / Brain dump - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 1495 Old 01-06-2005, 08:55 AM - Thread Starter
Paul Bigelow's Avatar
Hea,
I most certainly am!
If the green cannot match no matter what, it sounds like the color decoder of the Samsung may need some tweaking, if that possible.
Check for white crushing with the gray steps or the resolution pattern.
In the resolution pattern next to the 100% box, there is a box that is 100% with a 95% inner box. The inner box should be discernable. If not visible, the contrast/picture level is too high.
Paul
Paul Bigelow is offline
post #362 of 1495 Old 01-06-2005, 08:59 AM - Thread Starter
NoVaGator,
As far as I can tell the progressive button only affects the component. Haven't seen any change via the HDMI.
There is no absolutely "correct" setting. Some sets allow for 720p and 1080i, some allow for 1080i only. If 720p is available, give it a try! Otherwise, obtain the Digital Video Essentials DVD and run through the test patterns and see if the display does noticibly better with one resolution or the other.
Paul
post #363 of 1495 Old 01-06-2005, 09:20 AM
liberatusvirus's Avatar
I use 720p into my GWIII w/HDMI to DVI, only because it's closer to the monitor's native resolution. It looks great. Oddly, the HD feed from my Motorola STB looks better when set to 1080i, even on the 720p stations--probably an anomaly of the STB. It certainly won't hurt for you to experiment.
Ed
liberatusvirus is offline
post #364 of 1495 Old 01-07-2005, 10:09 AM
gimletmaker's Avatar
I have a Samsung HLP5063W display. Before I go through the "buy it - test it - return it" dance on the 975, I thought I might try to get some definitive answers to a few specific questions:
1) Has anyone else that has the Samsung HLP5063W tested the 975 using HDMI to HDMI at 720P to see if the HD/SD color space issue occurs?
2) Does the Samsung HLP5063W provide a means to map SD/HD color space at 720P connected via HDMI to HDMI?
3) General comments about PQ and color with the 975 paired with the HLP5063W via HDMI to HDMI at 720P?
RandyM
gimletmaker is offline
post #365 of 1495 Old 01-07-2005, 12:51 PM
zyx5432's Avatar
Any updates on the recent rash of tray locking problems?
Was this a bad batch of players, or something else?
zyx5432 is offline
post #366 of 1495 Old 01-07-2005, 12:55 PM
NoThru22's Avatar
Quoted: 366 Post(s)
Liked: 169
Why would it have colorspace issues? Aren't they caused from the HDMI->DVI conversion only?
NoThru22 is offline
post #367 of 1495 Old 01-07-2005, 02:04 PM
Penton-Man's Avatar
From Robert Whitehead (a truly helpful and knowledgeable poster)
"So, the HDMI signal from the 975 is properly SD. If upscaled it may cause a display device to switch into HD Color Space, which can only be remedied if the display allows you to force the player into SD color space on the HDMI input.
But when the HDMI output is hooked into a DVI display device, the 975 improperly outputs RGB HD Color Space, and there is no remedy for this."
Penton-Man is offline
post #368 of 1495 Old 01-07-2005, 03:50 PM
tblankenship's Avatar
I'm having problems with the tray locking and not being able to turn the power off (short of removing power). I once had success in running through a "Quick Setup" in order to open the tray and then being able to play a DVD. Now, however, I cannot not get a DVD to play.
Is it best to deal with this problem through Sony or through my purchase store?
tblankenship is offline
post #369 of 1495 Old 01-07-2005, 04:27 PM
Penton-Man's Avatar
zyx5432
Check your PM please.
post #370 of 1495 Old 01-07-2005, 10:37 PM
asung's Avatar
I'm also curious as to any updates on the "Tray Locked" issue. I only have a couple weeks before I can return the Sony, and it would be good to know if there is some kind of solution. Does anyone have the service manual, and if so, does it say anything about this issue?
asung is offline
post #371 of 1495 Old 01-08-2005, 12:35 AM
Mtnmike's Avatar
Not a big deal I guess, but this player will not play HDCD's over optical digital. It plays just about every other CD format. I haven't tried SACD yet cause the cabling is so damned expensive, but over Optical Digital that format does not play. Anyone find anything different?
Mtnmike is offline
post #372 of 1495 Old 01-08-2005, 01:23 AM
kdog044's Avatar
Quoted: 30 Post(s)
I don't think any of the <$300 players will except perhaps the Panny S97. I believe you would need to look at the Denon 2910 for that.
kdog044 is offline
post #373 of 1495 Old 01-08-2005, 06:43 AM
Rock the Mullet's Avatar
I just return the player to the place I bought it. who wants to send the player in for servicing, wait to get it back....
I got mine from ABT electronics, by the way - I had two lemons - tray lock problem and refusal to playing any discs.
Rock the Mullet is offline
post #374 of 1495 Old 01-08-2005, 07:37 AM
Well, I thought that I'd dodged the bullet, but my player came up lame just like Rock the Mullet's. Local service centers cannot fix this problem. If you can't get an exchange from the place where you bought it, you'll be required to send it to Sony's headquarters in Texas for a replacement, if one is available. I don't know what Sony intends to do when they have no direct, refurbished exchange to offer; I'm about to find out. They make noise about "alternative models." Now what could they possibly be?
Ed
post #375 of 1495 Old 01-08-2005, 10:58 AM
Liberatus - that is exactly what I thought - what would they send in its place? and also, who wants a refurbished player after their new 1 month old DVD player will not work. This is simply inexcusable. VERY poor quality control on Sony's part.
I was very upset because I really liked this player - great PQ and audio. No macroblocking either - at least from what I saw.
post #376 of 1495 Old 01-08-2005, 11:23 AM
I agree. I loved the way the player sounded and looked, the wrong color space with DVI notwithstanding. Sony appears to have rushed to market with this player, giving their local service people no codes for fixing it along the relevant lines. Although a firmware fix will probably work its way along the network, if not to individual users, the sting of buying a new player, shipping it to Texas, and having to wait God knows how long for a replacement to arrive, is too much indignity to swallow. I'm hoping, at the very least, that Sony will simply fix mine and send it back to me. At this point, a refurbished 975V with the bugs removed (I even made a pitch for them to correct the RGB problem), given what I know about the new ones, would be welcome. If they offer me another model, I'll flatly refuse; I got this thing for the digital connection. Hell, I bought a DVI switch box and hundreds of dollars worth of cabling, not to mention a slew of SACDs. Sony has to make good. Let me know how you make out.
Ed
post #377 of 1495 Old 01-08-2005, 02:04 PM
Ed,
ABT was really cool about returning or exchanging the Sony. the second one is already on its way back to them. I'll probably go with the Panny, but I my interest is piqued with respect to the Oppo.
Good luck yourself!
post #378 of 1495 Old 01-09-2005, 06:34 AM
kdog044's Avatar
Quoted: 30 Post(s)
I'm relatively inexperienced in this but if I am understanding correctly it's not that the color space is incorrect for an HDMI output but that they didn't provide a way to change it to RGB for those who have DVI inputs such as Denon and Panasonic did. Obviously if they had a DVI ouput it would be a given but it would seem to me if I had a DVI based display and I was looking at purchasing a DVD player I would make sure it had a DVI ouput or at least the ability through setup to output the RGB colorspace. Or am I totally wrong here?
kdog044 is offline
post #379 of 1495 Old 01-09-2005, 08:44 AM
kdog,
When the HDMI player is connected to a DVI display, its YCbCr must be converted to RGB. Under this condition, the Sony processes the DVD correctly at standard def., both interlaced and progressive, but at 720p and 1080i upconversion, it sends an improper high-def decoding. Apparently, no DVI display currently on the market can compensate for that mistake, whereas an HDMI display may well be able to substitute the appropriate standard color space when in a similar situation.
Ed
post #380 of 1495 Old 01-09-2005, 09:17 AM
twilburn's Avatar
I would like to know how many of you have this unit, for how long, and how many exchanges you have made (if any).
I received mine for Christmas and have exchanged once already. So far it is still working. The only thing I changed was excluding it from any macros on the remote.
twilburn is offline
post #381 of 1495 Old 01-09-2005, 09:44 AM
Mtnmike's Avatar
One month and no problems noted.
Mtnmike is offline
post #382 of 1495 Old 01-09-2005, 10:49 AM - Thread Starter
One problem after two months. The only issue I've seen is an occasional reboot when accessing DVE test patterns a lot. No other disc has exhibited this problem. Otherwise, no locked trays or video abnormalities (aside from the documented in the first post).
Paul
post #383 of 1495 Old 01-09-2005, 10:58 AM
twilburn : two exchanges already (first lasted five weeks, and second lasted only 1 week). won't try for a third unit.
post #384 of 1495 Old 01-09-2005, 12:08 PM
I've had mine 2 months. Last week it stopped playing discs. The only way I can open the tray is while it is turned off. It is able to determine if the disc is a CD or DVD, but it just does not play it. I'll be trying to exchange mine ASAP.
post #385 of 1495 Old 01-10-2005, 12:33 AM
robshdtv's Avatar
Had mine for 3 weeks and so far so good. The only strange thing was after putting a commercial DVD in today it needed a reboot to finally play. At first it just flashed dvd on the display but didn't play anything. I power cycled and it worked fine.
I would have to say it would be a shame if these things were all together buggy. The overall quality feels solid and this thing is speedy in menus and layer switches. Plus matched up with my Sony KDFWF55 the picture quality through the hdmi looks great! I hope Sony can fix the issues with this player with a firmware release. I bought the extended warranty on this one just to be safe. I have 4 years to keep my fingers crossed and if it can't be fixed I guess a replacement is in line.
-Rob
robshdtv is offline
post #386 of 1495 Old 01-10-2005, 09:00 AM
DrEd's Avatar
Spoke to Sony (via Support site "chat" session) and they claim to not do firmware updates...
DrEd is offline
post #387 of 1495 Old 01-10-2005, 09:17 AM
That seems to be true so far as offering firmware updates to individual consumers is concerned, but their authorized service people are usually able to get anything that they need, at some point, anyway. In this case, however, Sony has not yet provided the needed info and/or data to technicians anywhere but at the Texas facility.
Ed (no relation)
post #388 of 1495 Old 01-10-2005, 02:23 PM
Repdetect's Avatar
Quoted: 14 Post(s)
Had mine 2 weeks before I got my HDMI cable and.... distorted signal from HDMI output, so I've sent it back to Texas for a replacement. Otherwise, looked awesome via component out to a KP46WT520. Can't wait to see the HDMI output.
Sony HW40 ES, Oppo BDP-103, Gallo Classico CL-4/ Classico CL-C Center/ 2-CL-10 Subs/ Classico CL-2 surrounds, Emotiva UMC-200/ XPA-5/ XPA-3, Toshiba HD-A3. Roku X, Darbee Darblet, Silver Ticket 110" White Screen  "All rooms, speakers and ears are different, trust your own ears."
Repdetect is offline
post #389 of 1495 Old 01-11-2005, 05:09 PM
oregonstitch's Avatar
Rats, just had a scare. The tray would not open. Turned it on/off a couple times, hitting eject each time. About the fourth try it ejected. Keeping fingers crossed.
oregonstitch is offline
post #390 of 1495 Old 01-11-2005, 05:10 PM
Closed Thread DVD Players (Standard Def)
