I-O Data AVeL LinkPlayer2 FAQ - Page 47 - AVS Forum | Home Theater Discussions And Reviews
post #1381 of 1408 Old 07-30-2008, 09:57 AM
tc5531's Avatar
Anyone still got the firmware files up to and including the October 05 firmware? I have a new Linkplayer 2 box (from eBay - people STILL sell them!) and it needs bringing up to a usable level. October 05 is the one I use on my other Linkplayers but ANY available .BIN would keep me happy since the Taxan/IOData is down.
Thanks for your help
tc5531 is offline
post #1382 of 1408 Old 10-04-2008, 07:18 PM
jcmills's Avatar
Yes I would love to get the Oct 05 firmware as well. I cannot find it anywhere.
jcmills is offline
post #1383 of 1408 Old 10-04-2008, 08:01 PM
bigrig's Avatar
Quoted: 24 Post(s)
Links posted here still work. Someone mentioned Firefox might work better.
http://www.avsforum.com/avs-vb/showt...63#post7252963
Matt
"It's an invention, and it makes Non-Stop Rocking possible!"
bigrig is offline
post #1384 of 1408 Old 10-04-2008, 09:54 PM
jcmills's Avatar
Nope I can't get any of the links to work, in IE or Firefox.
jcmills is offline
post #1385 of 1408 Old 10-04-2008, 10:03 PM
satnav4's Avatar
Just send a PM with your email, and I can send the files and the procedure.
satnav4 is offline
post #1386 of 1408 Old 10-08-2008, 09:13 AM
markspark1981's Avatar
Hello Fellow Avel Linkplayer2 owners--
I have a question about .TS files. I have downloaded a few .TS streams (1080i format) from the Web that are HDTV recordings of TV shows, etc. They play great on my Avel Linkplayer2 unit.
My question is -- how can I create a playable TS file on my player from an MKV or M2TS file? I don't want to use the network feature to do it. I usually connect an external HD to the player.
Is there any software out there that will work?
Any help would be greatly appreciated!!!!!!!!! I just bought a Pansonic 50" Plasma 720p and want to watch some HD content on it.
HALP!!!!
markspark1981 is offline
post #1387 of 1408 Old 10-08-2008, 10:06 AM
Yahoo's Avatar
If you want permanent copies of the file saved after viewing, best bet would be convert it to XVID format using MediaCoder (free).
If you want to just view it once, google for the AVLink Advanced Server that will transcode on the fly.
- Balance Between
- Quality & Price!
__________________
Knowledge + Application = Real Change
Seek and you shall find the truth that awaits.
Yahoo is offline
post #1388 of 1408 Old 10-08-2008, 10:37 AM
TPeterson's Avatar
Quoted: 235 Post(s)
Liked: 29
Actually, since the AVLP2 doesn't play MPEG-4 (H.264), you're going to have to re-encode such streams as MPEG-2 to play them.
TPeterson is offline
post #1389 of 1408 Old 10-08-2008, 01:31 PM
Thanks. What program do you recommend I use? Don't want to use MediaCoder -- it stalled for me.
I have Super and Gotsent that I guess can do that job. Anything better? I want to convert to an MPEG-2 file that is of the highest quality that Avel Linkplayer 2 could handle.
-Mark
post #1390 of 1408 Old 10-14-2008, 01:33 AM
chakotay2's Avatar
Since IODATA has pretty much dumped this product... what is the latest server software for it? Is there any 3rd party software still being developed?
chakotay2 is offline
post #1391 of 1408 Old 10-14-2008, 05:41 AM
mrwilson's Avatar
Try WIZD. It's open source and works much better than IOData's software.
mrwilson is offline
post #1392 of 1408 Old 10-14-2008, 07:29 AM
chakotay2's Avatar
Hmmm, looks like that development is pretty dead too... last update 2006. Any active ones?
post #1393 of 1408 Old 10-26-2008, 08:37 AM
kmac727's Avatar
I saw in a prior post that we can play MKV files by editing the Advanced Server server-config.xml file, telling it to transcode the MKV files. I tried editing that file (with Notepad++) but still get the "Unknown Format" error on my LinkPlayer. Here is what I did:
First i tried this entry which didn't work:
Code:
Then I tried this, and it still didn't work:
Code:
I don't have the instructions for Advanced Server, so I'm operating blind here.
I have the necessary Codecs installed and can play MKV files with MediaPlayer on the computer running Advanced Server. Can anyone tell me what changes need to be made to the config file. Much thanks.
kmac727 is offline
post #1394 of 1408 Old 10-27-2008, 06:22 AM
kmac727's Avatar
Nevermind. Ignore my post above. I was editing the wrong server-config.xml file. Apparently, regardless of what drive you install Advanced Server on (mine is installed on the D: drive), the config file is placed on the C: drive in the user's "Application Data" folder.
And, by the way, the correct edit is: . If you have the proper CODEC installed, you can play MKV files, but you cannot FF or Rewind. I set my output bitrate at 8000 Kbps, which gives me visibly better resolution than the default setting.
kmac727 is offline
post #1395 of 1408 Old 10-28-2008, 01:12 AM
tc5531's Avatar
Swiss Center looks like it's still being looked after, and has quite a lot of advanced features. swisscenter.co.uk - I might just have to try installing it to see how much better (or not) it is than the old WIZD install I'm using.
tc5531 is offline
post #1396 of 1408 Old 11-10-2008, 05:00 AM
FerFer's Avatar
I need the firmware for DVD IODATA AVP2/DVDLA, who accepts subtitle SRT, but IODATA Site and the of TAXAN are not answering, anybody would it have to make available that file?
FerFer is offline
post #1397 of 1408 Old 11-10-2008, 05:42 AM
FerFer's Avatar
I did not explain myself right.
here in the forum am found a link working for the "Oct 05 firmware" and when it setups, of the signature mistake, therefore I need other that works.
FerFer is offline
post #1398 of 1408 Old 11-29-2008, 08:24 PM
john_hatchett's Avatar
Anyone ever get the firmware source for this player?
john_hatchett is offline
post #1399 of 1408 Old 12-19-2008, 01:25 AM
chakotay2's Avatar
If I put a Blu-Ray DVD drive in one of the computers on my network, is there any way to stream it to my entertainment center where my JVC-SRDVD100U is?
post #1400 of 1408 Old 01-10-2009, 12:23 PM
RalphArch's Avatar
One thing I have noticed about ps3 media server http://www.avsforum.com/avs-vb/showthread.php?t=1085772 is that shows edited with h2 do not have the lipsync issue so I don't have to pause and hit play to get back in sync on the linkplayers like I do on the advanced server.
Although last night it wouldn't play one of the files I had cut commercials out of so I did watch that one on advanced server. They all seemed to play without an issue on the ps3 - maybe that was resetting them for playback on other devices like the linkplayers?
RalphArch is offline
post #1401 of 1408 Old 01-02-2011, 06:38 PM
Gojira69's Avatar
My linkplayer finally died.
What's the new best solution for playing network files on my TV?
Gojira69 is offline
post #1402 of 1408 Old 01-02-2011, 06:46 PM
NJ Jackals's Avatar
I went with a Popcorn Hour C-200
NJ Jackals is offline
post #1403 of 1408 Old 01-02-2011, 06:50 PM
Yahoo's Avatar
Does the C200 play back the LinkPlayer Server apps or the Wizd?
I actually have a new one in box as a backup to sell.
- Balance Between
- Quality & Price!
__________________
Yahoo is offline
post #1404 of 1408 Old 01-03-2011, 07:15 AM
NJ Jackals's Avatar
It as it's own apps and YAMJ (with Aeon) is much better than WIzd
Http://Www.YouTube.com/watch?v=upSk4w12q-E
post #1405 of 1408 Old 01-03-2011, 09:56 PM
Yahoo's Avatar
Great.
Actually there is one feature in Wizd I have not found in ANYTHING else. That is the "shuffle" playback of video (including subfolders of the current folder).
Does YAMJ do that and also does it run on Win7 64 bit as well as Win2000? Thanks.
- Balance Between
- Quality & Price!
__________________
Yahoo is offline
post #1406 of 1408 Old 09-05-2011, 10:20 AM
mrincredible's Avatar
Can someone post server installation binaries for windows and linux please? iodata.com site is offline for a while...
mrincredible is offline
post #1407 of 1408 Old 03-24-2012, 07:44 PM
mrwilson's Avatar
Google WizD and use that. Much better than the stuff that shipped with it.
mrwilson is offline
post #1408 of 1408 Old 03-25-2012, 08:35 AM
h2ofun's Avatar
Has not been updated for many years, and may not work on Windows 7 I assume
h2ofun is offline
Reply DVD Players (Standard Def)
