denon dvd 3910 new firmware version -8 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-31-2005, 06:17 PM - Thread Starter
david8613's Avatar
Quoted: 192 Post(s)
Liked: 48
hey guys i just checked the denon site and i see version -8 firmware, is this the denonlink/sacd firmware upgrade we have been waiting for...i thougt the the last announcement was for the next generation recievers using sacd 2.0... if its not then what does this firmware fix on the 3910? kris your input would be great, thanks david...
david8613 is offline
post #2 of 7 Old 01-31-2005, 07:21 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
I upgraded my 3910 with ESS6609-8.
According to the Denon information, this firmware "Corrects for black level adjustment and range in Normal Mode".
Sam S is offline
post #3 of 7 Old 01-31-2005, 07:36 PM - Thread Starter
david8613's Avatar
Quoted: 192 Post(s)
Liked: 48
oh, thank you very mucho...do you notice a difference? does everything seem to work the way its supposed to?
post #4 of 7 Old 01-31-2005, 07:43 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Everything seems to be the same. Of course I reset all my settings after initialization. Didn't notice anything different in the menu settings (still no DL3).
Picture-wise, seems fine. I haven't sat down for critical viewing, but I'm interested in others' opinions.
Sam S is offline
post #5 of 7 Old 01-31-2005, 08:05 PM
BillP's Avatar
Quoted: 259 Post(s)
Liked: 201
Does this fix the fact that it resets to Enhanced whenever you change the resolution or turn squeeze mode on?
BillP is offline
post #6 of 7 Old 01-31-2005, 10:12 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Bill,
I only use analog 480p via component, so I'm not sure if I can answer this question. I never noticed a problem like this via component before.
Sam S is offline
post #7 of 7 Old 02-01-2005, 07:26 PM
BillP's Avatar
Quoted: 259 Post(s)
Liked: 201
I think it's only a DVI/HDMI problem. Denon emailed me that V. 8 will solve this bug. I'll have a chance to download it tomorrow, and will try it out.
BillP is offline
Closed Thread DVD Players (Standard Def)
