Sony DVP-CX995V owner's thread - Page 74 - AVS Forum | Home Theater Discussions And Reviews
post #2191 of 2215 Old 03-13-2012, 07:30 AM
Paulb's Avatar
putox1051,
I'm familiar with the firmware upgrade but as near as I can tell your link just points to a seller on Ebay with a remote to hawk. The link to the Firmware is here:
DVP-CX995V Firmware Upgrade
Well, I had a CX985V working well for quite a few years. The laser head went south and I picked up a CX995V reasonable priced on Ebid.
Have to say Sony didn't do a good job designing the UI on this thing. It''s probably even clunkier than the CX985V.
It is possible however to force it to go to the exact DVD you want.
first stop it if it's playing. Then
Hit the "Display/File" button to bring up the first Control Menu Display Screen.
The top most Tab shows the Disc being played.
With that tab in focus hit Enter. That will clear the Disc number and allow you to type in the specific DVD you want to navigate to. After entering the number hit PLAY and then immediately hit Enter. Done correctly that will over ride the CX995V's brain-dead behavior of trying FOREVER to play the current disc--either from the beginning or from wherever it left off. It still takes forever to load whatever you want but with the ability to force it to go directly to any disc on the carousel, bypassing everything in between, whenever YOU want---it's tolerable.
The CX995 is a convenient way to store DVD's but I certainly wouldn't recommend it beyond it's function as Plastic Warehousing. I got even attempting to load and track information on the 400 DVD's it holds well out of my system with it's predecessor. That feature isn't worth bothering with--even with a wireless keyboard hooked up--which is the only way to go if you want to use that "feature". I just keep track with a Word file now---I originally wrote an Access database but can't be bothered keeping up with that anymore.
One issue I haven't been able to resolve---other than I think it's just a gotta with the CX995. The 985V responding to a lot of Sony codes besides those on it's remote. Specifically it would recognize OBC 042 in various Sony remote protocols as a code to take it directly to A-B repeat, without the necessity of traversing the Control Menu Display Screens.
I've tried every conceivable Sony protocol and likely code that I know of and nothing gets the CX995 to go directly to A-B Repeat. Anyway, I already know the code in the Sony26.73 remote protocol that should work is OBC 043, EFC 112, HEX 54 59. At this point I'm assuming it been gelded out of the somewhat changed Navigation functionality of the CS995. If anyone else has confirmed this let me know. I'll stop plugging every code possible through a JP1 interface.
Paulb is offline
post #2192 of 2215 Old 08-15-2012, 05:18 AM
clarkpaul's Avatar
I have had a Sony DVP-CX995V DVD player for about 5 years now. A couple of years ago I made the mistake of downloading and installing an update. Since that time, and after re-downloading the update and multiple attempts at re-installing it, the remote control has ceased to operate the unit. The supplied remote no longer controls it and it also does not respond to any universal remotes. I contacted Sony probably 3-4 times regarding this issue, the last time a lady said I would get an update disc in the mail. This had been more than six months ago. What gives??
Paul Clark
clarkpaul is offline
post #2193 of 2215 Old 04-24-2013, 08:58 PM
Tony Cristaldi's Avatar
Hopefully someone can help out a noob. I bought a dvp-cx995v off of Craigslist several months ago and I am making absolutely NO progress in trying to label the CDs/DVDs I placed into the machine. I followed the instructions, pressed LOAD to where it read all of the 360+ discs I put in there, and then went to the instructions on how to label a disc or folder and get nowhere.
The instructions on page 48 say...
To label a disc...Select the disc on the Disc Explorer (for details, see steps 1 to 3 of "Searching for a disc on the Disc Explorer" on page 44). So I flip over to p44 and see...
Searching for a disc on the Disc Explorer...
1) Slide the TV/DISC EXPLORER/DVD switch to DISC EXPLORER, then press FOLDER.
The Disc Explorer display appears.
2) Press C/c to select the folder with the disc you want to play.
OK, I can't even get to number 2) because when I press FOLDER, the display says "FOLDER ALL", and I can't get the player to respond to any other commands on either the remote or the front of the player.
I have my PS2 keyboard all hooked up and ready to type in the ginormous list of titles that I transcribed to paper (most of the discs in the player are CDs)
Can anyone help? Thanks in advance.
I would like to apologize to the group for my first post being in complete ignorance of the fact that I needed to have my television on for the labelling to work. eek.gif
Tony Cristaldi is offline
post #2194 of 2215 Old 04-29-2013, 02:26 PM
Paulb's Avatar
Well I believe I've encountered and solved this issue. Unfortunately I'm a little sketchy on the details all these years later. It Should go to folder setup UNLESS you are not defaulted to display ALL in folder setup. This is where I would need to go parsing through the manual. You can have it configured to only display Music CD's or Videos and if you get that wrong it may NOT pull up the Folder Menu as expected. You should hunt that down in the instructions---I think that's where your problem lies. I'll do the same when I have some time.
I remember reading a lot of unhappiness with the way the 995 Navigation was changed from the 985. It does seem to have a mind of it's own and also seems intent on scanning through all 400 of your DVD's as it decides what it should do next. I've been pretty successful at brute forcing it beyond that stage. 100 years working with MS Windows prepared me well for brain-dead UI's.
As I mentioned in my previous post here--I long ago decided that whole feature wasn't worth the effort. I did at one point program my Palm IIIxe (which has an IR broadcaster and works with an app Called Omniremote) to MACRO the entire set of information. I also Macro'ed ALL my other programming on this Sony and a 300 CD changer I have. The Palm has 8Mg of memory which is a LOT of macro space. Anyway, if I lost power and lost programming I could just point the Palm at the Changer, hit a couple of buttons and go to the Opera. The palm would sit there streaming every code to reprogram the gizmo's to exact way had them.
In the end it's more convenient for me to maintain the contents of these multi-changers in Excel and I don't bother setting up categories and playing lists. 16TByes of my own Streaming Media to organize, plus PLEX, Play-ON, iTunes and other ways to organize media on my intranet--these Plastic Dispensers are too far off the beaten track now.
Paulb is offline
post #2195 of 2215 Old 06-13-2013, 04:04 PM
RobAGD's Avatar
PaulB
As a suggestion, and depending on your collection size, I highly recommend DVD Profiler for collection management.
I have 5 995's almost full. I do a few things using the DVDP software from Invelos.
All discs have a unit and slot # assigned which is viewable in the titles profile.
I also use the reports function to have a printed list of titles and disc locations I keep in a binder.
And they just released an android app so you can have the collection on your phone/tablet ( they have had a iOS app for a while )
And with some of the plugin's you can even use an IR blaster to load discs from the carousel players.
Just some thoughts
-Robert
RobAGD is offline
post #2196 of 2215 Old 07-15-2013, 01:57 PM
DWPC's Avatar
I've had a 995 for many years and its been trouble free. I originally used the component video out and a coax digital audio out to a DAC. Later I went to HDMI without changing anything in Setup. I kept the coax out for CD listening along the HDMI connection for video...no problems. Last month, I disconnected and moved the AV system for room painting, and now I can't get an HDMI output from the 995. No HDMI light. It reads CDs and DVDs fine; audio and component video out is good. Any suggestions? Is there a setting I'm missing?
DWPC is offline
post #2197 of 2215 Old 07-15-2013, 02:18 PM
cwmont13's Avatar
I had the same problem after storing mine for a few months. HDMI fine before and gone when I hooked it back up.
I went to Sony's support site and there was a firmware update to correct HDMI issues. Download and burn to a disc to run the update. Mine wouldn't take at first I was confused as to why. Found out the disc has to be in "slot 1" or the update won't be applied.
Did the update and mine has been perfect ever since.
Hope this helps .
cwmont13 is offline
post #2198 of 2215 Old 07-15-2013, 08:00 PM
DWPC's Avatar
Hope this helps .
DWPC is offline
post #2199 of 2215 Old 07-15-2013, 08:05 PM
cwmont13's Avatar
Glad it worked and glad I could help. I really like the 995v so far its been a real workhorse for me.
There's a person in my area selling one and I've been debating grabbing it so I can have a spare for backup or parts down the road if needed.
cwmont13 is offline
post #2200 of 2215 Old 08-01-2013, 02:45 AM
ccrider2's Avatar
Quoted: 25 Post(s)
Hope this helps .
Did the update...now mine is a brick. Guess I did something wrong. Sony says I can ship it to them for an exchange +200 bucks....= trash it. biggrin.gif
Chris C
ccrider2 is offline
post #2201 of 2215 Old 08-04-2013, 05:56 AM
tongzijb's Avatar
very nice,I unplugged the unit for 30 minutes and my entered data was still saved.thanks 10.gif
tongzijb is offline
post #2202 of 2215 Old 10-24-2014, 09:04 AM
Liked: 0
Player not reading media
My DVP-CX995V has been going strong for years, but it now giving me a problem. It no longer reads the media in the player. Dvd, cd, nothing works. It just says it can't play the disc and advances to the next, repeat. I've tried unplugging it for hours, and it doesn't help. The SA-CD light is always on, which makes me think it is stuck in that mode, but that may not be important at all. It no longer lets me go to the list, since it is constantly in disc change mode. Any ideas?
Mark Lindsay is offline
post #2203 of 2215 Old 11-23-2014, 01:35 PM
cmotomn's Avatar
Here's a link to the DVP-CX995V service manual that contains all schematics and replacement part numbers.
http://www.scribd.com/doc/18164879/Service-Manual
cmotomn is offline
post #2204 of 2215 Old 03-18-2015, 10:38 AM
DWPC's Avatar
My trusty ol' 995 just started doing the same thing. All three blue lights stay on, the screen says "Cannot Play" then it advances to the next disk where the error just repeats, and it will not go back to a disk that it's rejected. Maybe this time someone can respond.
DWPC is offline
post #2205 of 2215 Old 04-05-2015, 07:38 AM
1989civic's Avatar
Quoted: 20 Post(s)
I've had my CX995 since 2008. I used it very sporadically. I just bought a new Samsung plasma tv so I have been using it more now as I wanted to play movies that are in the 1.85:1 aspect ratio to break the tv in.
I was underwhelmed with the picture quality on the Samsung. I have it set to 720p via the hdmi output.
I got into the picture settings menu of my player and found that the default setting for Sharpness if Off. The options were OFF, 1 or 2. Setting it at 1 made a big difference. Comparing OFF to 1 you can see the picture shifting from out of focus, to in focus.
I've read this thread from the beginning and there are often complains of mediocre picture quality. I don't know why Sony defaults the sharpness to OFF which basically seems to defocus the picture.
I'm much happier now that the player is set to 1. I did find that 2 seemed slightly harsh.
I'm enjoying using my old jukebox again.
1989civic is offline
post #2206 of 2215 Old 04-06-2015, 07:30 PM
Liked: 0
It turned out that the laser component was no longer functioning. I found a local place to repair it, so it's up and running again.
post #2207 of 2215 Old 05-03-2015, 05:46 PM
DWPC's Avatar
How do I know my optical pickup is bad?
My 9 yr old 995 is telling me "cannot play disk" for every disk in sequence, even after repeated unplugged periods. I cleaned the laser, with a q-tip and alcohol, and noticed that when I loaded a disk, it seemed to spin with a little radial wobble (i.e., run-out). Still reads "cannot play disk" after spinning the disk for a few seconds. I tried to use the 995's onboard diagnostics with the service manual for automatic disk adjustment test for CD and for DVD, but I don't know what the results data mean and didn't want to mess with the manual adjustment test. I can probably get the optical head replaced but don't know if that's the problem. Is there any way to know for sure that's the problem? Is it a DIY replacement, or is special skill needed to align the head?
DWPC is offline
post #2208 of 2215 Old 05-11-2015, 04:31 PM
danothemano's Avatar
Originally Posted by tom_o View Post
I had the same problem. After cleaning the media and rebooting the player 5x nothing changed.
But the tip with alcohol solved it. Now everything works fine on my side. Can you post here the diagnostics data?
Great news, but in my case that did not work. I ended up dumping it. I did find a used one on Amazon but when I tried to use it, same thing. I really miss that DVD player would love to find another one.
danothemano is offline
post #2209 of 2215 Old 05-14-2015, 03:04 PM
DWPC's Avatar
Here are the diagnostics screens;
DL = DVD Auto Adjust results
CD = CD results
They should be assessed with Sec. 6.1 in the Service Manual but I couldn't make much sense of the results; I assume none the "06" values mean anything good.
Repair shops are extinct. If I can't fix it by installing a new optical pickup; assuming I could find one; I guess it's off to the recyclers. There's nothing like it on the market now; I'll have to spend more than a replacement would cost; plus many, many hours of time ripping CDs; to move my collection to a hard drive.
ID:	717258   Click image for larger version
DWPC is offline
post #2210 of 2215 Old 07-02-2015, 12:32 PM
guho's Avatar
Does anyone know how these Sony DVD changers store the disc information (as obtained from loading the discs and keyboard entries)? In the service manual, it mentions the presence of EEPROM, NAND-flash and SDRAM. I suppose it is volatile storage since people lose data from long outages. How does the data survive short outages? Is there some sort of battery or large capacitor on board for data retention?
I have one of these and every once in a while after I have not used it, it wants to reload all the discs even when there has been no power outage so I am wondering what is defective. In the diagnostics menu I ran the memory-related tests but got no error messages.
guho is offline
post #2211 of 2215 Old 11-29-2015, 07:05 PM
Liked: 0
My changer recently started dropping audio over HDMI. The video is fine but the audio drops for about ten seconds every four seconds or so. It seems to be a handshaking issue but there is no signal degradation with the video. All diagnostics pass and the latest firmware (144) is installed. The optical output works and I am tempted to feed the component output with the optical into a converter to multiplex HDMI, thereby, in essence, bypassing the changer's HDMI interface. One thing I have seen in the diagnostics is that the "Venc" test occasionally returns "NG." I am fairly electronics-savvy but where would I start with the internal troubleshooting if I were to repair the unit?
Fanatical is offline
post #2212 of 2215 Old 03-03-2016, 05:17 PM
Liked: 0
can anyone suggest a solution??
I just bought a used DVP-CX995V it was shipped along way, Cal to ON, arrived today, plugged it in and the unit comes on displays "sony dvd" and then powers off. It was packed well and shows no signs of damage. The seller had pic's of it working, I have no reason to believe it wasn't.
Could this just be something simple like a connector came loose, or is it bound to be more serious?
I really do not want the aggravation of returning it...
7.2.4 Denon 6200 Emotiva XPA3 Denon DPT 1713 Klipsch RF800 fronts, RC62 center, RS 400 front and rear heights soundstage
handymandic is offline
post #2213 of 2215 Old 05-17-2016, 11:13 AM
cmotomn's Avatar
FYI- I've been using my DVP-CX995V on a regular basis for 10+ years and it still performs very well! I now have it connected to a new Sony KDL-75W850C HDTV and it's amazing how good upscaled DVD's can look at 75 inches!!
cmotomn is offline
post #2214 of 2215 Old 05-22-2016, 10:20 AM
darylfoot's Avatar
How should I burn dvd-r's so that the CX995V can read the title info? I saw it somewhere but I can't find it now. Thanks!
darylfoot is offline
post #2215 of 2215 Old 05-29-2016, 02:44 PM
Liked: 0
Title DVD
Darylfoot,
Use a program called Titlewriter ....http://www.videohelp.com/software/TitleWriter
You can also create a folder Jacket_P and place a jacket in MP2 format ... when paused it will display the cover art
http://forum.videohelp.com/threads/1...KET_P-Pictures
I have been doing this for years........
email me if you need more details
Devoir
Devoir666 is offline
Reply DVD Players (Standard Def)
Sony Dvp Cx777es 400 Disc Dvd Cd Changer , Sony Dvp Ns710h B 1080p Upscaling Dvd Player Black , Sony , Sony Brand , Sony Corp , Sony Corporation , Sony Electronics
