AVS Members DVD Players and Displays (Look here for player/TV opinons) - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 167 Old 06-24-2007, 10:50 PM
ManilaByNight's Avatar
DVD player: Oppo DV981-HD
Resolution: 1080i
Connection: Digital Coaxial
Display: Sharp LCD LC-32PX5M
Comments: Great!
ManilaByNight is offline
post #152 of 167 Old 07-24-2007, 12:26 PM
exHuman's Avatar
DVD player: Marantz DV6001
Resolution: 720p/1080i
Connection: HDMI
Display: Philips 32PW9551
Comments: Great picture, stunning color!
exHuman is offline
post #153 of 167 Old 09-01-2007, 11:44 AM
albymack's Avatar
DVD player: Sony NS77H
Resolution: 1080P
Connection: HDMI
Display: Toshiba 46LX177
Calibration: Eyeball
Comments:
Very very nice upconverting DVD player. Combined with the 120HZ refresh rate of this TV and it's reduce judder capabilities, and the pictures I'm getting from regular TV's are so sharp it looks like I'm looking out my window. The DVD player works well with a Panasonic 42inch plasma as well.
albymack is offline
post #154 of 167 Old 09-01-2007, 03:23 PM
Totalimmortal's Avatar
DVD Player: Yamaha DV-S5860
Resolution: 480P
Connection: Component
Display: Panasonic TH-42PX75U
Calibration: Cinema w/ a normal color temp.
Comments: The player does an excellent job of deinterlacing Makes me second guess buying an upconvert.
Totalimmortal is offline
post #155 of 167 Old 01-04-2008, 07:38 AM
overly under me's Avatar
DVD Player: Samsung DVD-M301
Resolution: 480i
Connection: component
Display: Sharp Aquos 42D64U
Calibration: None
Comments: Lots of artifacts on live action movies. Animated (Pixar) movies are much clearer except for the moving parts. Most movies just look horrible. Tried S-video first and then component, neither provided a great picture.
overly under me is offline
post #156 of 167 Old 01-25-2008, 09:30 PM
Mac11700's Avatar
DVD player: Oppo 980hd & Toshiba XA-1KN
Resolution: 1080p
Connection: HDMI
Display: Sony 60" SXRD XBR 2
Calibration: UMR
Comments: No issues with the Oppo...the picture is stunning for an up converting SD player...The Toshiba provides the best HD-DVD picture I have ever seen....but slow to boot up and eject...The Toshiba is good at up converting...but to my eyes the Oppo does as well if not a little better on some titles..
Mac
Mac11700 is offline
post #157 of 167 Old 02-22-2008, 07:08 AM
RalphArch's Avatar
DVD player: IODATA Linkplayer2
Resolution: 480i,p 720p, 1080i
Display: SONY KD36xs955 direct view crt
Calibration: none
Comments: Mostly used at 1080i for streaming recorded ATSC files on the wired network. For DVDs must view at 480i as I have updated firmware; this is superb on my display as I invoke the SONY's DRC controls set for cinemotion (upscaling). Although upscaling is blocked for commercial DVDs with latest firmware; many others have flashed to previous fw which will upscale. Speed control on the DVD (f, slow, v slow); I leave at default. The zoom modes accomodate a 4:3 HDTV very well w 1080i in.
RalphArch is offline
post #158 of 167 Old 02-22-2008, 09:27 AM
RalphArch's Avatar
DVD player: IODATA Pro-HD Kuro-Obi (SRDVD-100U)
Resolutions: 480i,p 720p, 1080i, 640v480, 800x600, 852x480, 1024x768
Connection: DVI-RGB
Display: RCA MM36100 direct view crt
Calibration: none
Comments: As above post , mostly used for streaming recorded ATSC files on the wired network, but for this display I use the analog out of DVI at 800x600. For DVDs I must view using component out at 480i; however with an HDCP display (commercial DVDs will not output over DVI without HDCP display) it would output up to 1080i as above over the DVI out. Don't watch many DVDs on this setup due to the need to switch and lack of upscaling on the display so scan lines are distracting, but its nice to have a built in RGB transcoder in a DVD player for those with older analog displays.
post #159 of 167 Old 06-07-2008, 06:56 PM
totallytweeked's Avatar
DVD player: Oppo 983hd/ Denon 2900
Resolution: 1080i/480p
Connection: HDMI>DVI/component
Display: Mits 55WS-813
Calibration: ISF
Andy Lorenz
Lynchburg, VA
"Anybody that cares about cinema or music or any of these kinds of art forms becomes concerned about the quality of the presentation."
---George Lucas
totallytweeked is offline
post #160 of 167 Old 06-10-2008, 11:17 PM
Spoonsey's Avatar
Quoted: 35 Post(s)
Liked: 24
DVD player: Oppo DV-981HD
Resolution: 720p
Connection: HDMI
Display: Panasonic Viera plasma TH-42PV700
Calibration: DVE, THX Optimiser
Overall much happier with my latest set-up. I was previously running a Denon 1920 into a Panasonic 32" LCD. I had the on/off issues with the 1920 as others have noted in these forums. The LCD I thought was very good but I wanted something bigger with greater HDMI connectivity and the Panny plasma fit the bill. Here in New Zealand you can get Panny LCDs up to 37" but I decided to go bigger and plasma was the best solution so upgraded to a 42" Panny Viera plasma. As far as plasmas go, I would only consider Panasonic or Pioneer and, for the price, decided that Panasonic was better value for me.
My Oppo is having some issues playing some of my PAL discs on the recommended Video 2 setting, which can be annoying. PQ with the Oppo is very good, though my Panny will only handle 720p so I can't really see what the Oppo is truly capable of. That said, for NZ$400 I'm confident that it's performance easily matches some of the more expensive players.
Spoonsey is offline
post #161 of 167 Old 06-15-2008, 06:02 PM
Blacklac's Avatar
DVD player: Oppo 983/Toshiba A35, A2, XA1/Pioneer 410k
Resolution: 1080i
Connection: HDMI
Display: Samsung HP-S5053 1366x768 Plasma
Calibration: DVE
They are all nice players. I haven't done major comparisons between any of them. Just going off memory after running each player for a short period of time. (Atleast a couple weeks, minus the Pioneer, it was a gift to my Dad. Just gave it a trial on my setup.)
The A2, XA1 and Pioneer are pretty much equal on my setup. The A35 was slightly better. Better colors, just a picture I prefer over the XA1, A2, Pioneer. Slightly sharper. The Oppo is clearly better than all the others, as it should be! It isn't much sharper than the A35, just a little. However the picture is SO clean. It really is a pleasant picture. On the Toshiba's, it was hit or miss depending on every movie how the picture turned out. With the Oppo, most DVD's look nice, very few look bad. Many look incredible!
I really love the Oppo! I highly suggest it if you have a large collection of DVD's and can justify the cost... and a large enough screen to take advantage of it. Anything smaller than my 50" and I don't think it would be worth it.
Blacklac is offline
post #162 of 167 Old 06-24-2008, 09:02 AM
smallhometheater's Avatar
DVD player: Sony DVP-CX995V 400 disc Changer
Resolution: 720P
Connection: HDMI
Display: Sharp LC46D64
Calibration: AVS Forum Members settings
Comments: I"m not a video file by any means but I have been very impressed with the PQ of the Sony through HDMI. With the help of AVS forum members posting their settings for the Sharp I am very happy with this combo.
smallhometheater is offline
post #163 of 167 Old 07-04-2008, 08:01 PM
westgate's Avatar
Resolution: 720P
Connection: HDMI
for a list of my equipment please see 'public profile' after clicking on my user name at left of screen.
westgate is offline
post #164 of 167 Old 07-08-2008, 03:00 AM
GSB
GSB's Avatar
DVD player: OPPO Digital DV-983H
Resolution: 1080p
Connection: HDMI
Display: Sony Bravia KDL-46V25L1 (46" 1080p LCD flat panel, same as KDL-46V2500)
Calibration: DVE / Avia
Comments: A/V Nirvana! Unparalleled performance for the money. Handles NTSC and PAL material extremely well. Here's my DV-983H Review.
Gary
GSB is offline
post #165 of 167 Old 05-18-2009, 01:05 AM
Justinas's Avatar
Ok thanx for best picture of killer
Justinas is offline
post #166 of 167 Old 07-22-2010, 10:01 AM
Super Moderator
markrubin's Avatar
Quoted: 1039 Post(s)
Liked: 2286
this thread will soon to unstuck because it is old
it will remain open
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #167 of 167 Old 07-22-2010, 10:39 AM
jonnyozero3's Avatar
i threaded yur forum?
i can haz pixels?
- Jon
"010 Meh"
jonnyozero3 is offline
Reply DVD Players (Standard Def)
