What players support 480i over DVI-D or HDMI? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 240 Old 01-18-2008, 11:16 AM
ashmostro's Avatar
Originally Posted by audiocvk View Post
The New Panasonic DVD-S53 player will allow you to use 480i, 480p, 720p, 1080i, and 1080p with HDMI. It has excellent picture quality. It can be had for under $100. Sadly like most DVD players today..... Panasonic has removed buttons on the unit so you only get play, stop, eject, and power button. Forward and reverse buttons have been removed that have to be used from remote. All these companies are taking this trend to further their profits.
thanks to this post, i picked up one of these units and A/B'ed it against a denon 1740. i returned the 1740 because it doesn't handle layer changes as well as the panny
i am quite happy with the speed and quality of this unit. i'm unhappy with how ugly it is...
ashmostro is offline
post #182 of 240 Old 01-19-2008, 06:31 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 322 Post(s)
Liked: 6391
Originally Posted by THE_COW_IS_OK View Post
Just to confirm. NTSC 480i 4:2:0 out over HDMI?
Also, how about multi zone? Does it read PAL disc, if so, does it output 576i?
I am looking for a DVD player that output 480i & 576i & read mpg2(SD&HD) stored movies on my HDD (via usb or RJ45). Any input?
Tkx, Sam.
No SD player outputs YCbCr 4:2:0 over any output. The output of the MPEG decoder is YCbCr 4:2:2 (possibly 4:4:4). I doubt the HDM players are any different. The chroma upsampling done by the MPEG decoder is, in some cases, the root of the CUE bug (Chroma Upsampling Error).
larry
Eu estou aqui e você é meu sofá
PooperScooper is offline
post #183 of 240 Old 01-28-2008, 02:20 AM
THE_COW_IS_OK's Avatar
larry
K, 4:2:2 is ok.
I was reading about the oppo, it is great cause it can also output SACD DSD, but some members mentioned it have problems with 480i/576i HDMI output and need an SDI to fix. my VP (radiance) doesn't have SDI input so what other player you suggest.
THE_COW_IS_OK is offline
post #184 of 240 Old 01-31-2008, 10:16 AM
M4P
M4P's Avatar
So would it be better to set the DVD player to 480i and let the tv do the upscaling? Does setting the player at 480i as opposed to 480p really make a difference? I have a 1080p tv (Sharp LC-52D62U )
Help Wiki for LG BD570: http://www.dexid.org/wiki/LG_BD570 (thanks Dave_Nedde & thx1138)
LG Executive Services 877-543-8325
M4P is offline
post #185 of 240 Old 01-31-2008, 10:20 AM
ashmostro's Avatar
from what i've recently learned (and it ain't much!) it all depends on the quality of the upscaler being used, regardless of where it's located (in the source, avr, or tv).
in my situation, the best upscaler in my system resides in my avr, so i send 480i to it, let it do the upscaling to 1080p and then let my tv just play the signal without further scaling or deinterlacing. i made that decision after testing all the scalers in the system and chose the one that resulted in the best picture quality. you should do the same experiment and find out which works best in your system.
post #186 of 240 Old 01-31-2008, 01:26 PM
M4P
M4P's Avatar
Thanks for the reply, I appreciate it. Right now I am trying to decide between the Panasonic S53K, the Philips 5982, or the Samsung DVD-1080P7. I have a credit to use at a store and unfortunately they don't carry Oppo, so I am pretty limited. I understand the Philips can't pass DTS, the Samsung has had good reviews as to PQ, but seems they have build quality problems (I did see on their site they have a new firmware out last week, but don't know if it addresses these problems). Back to the Panasonic, are you happy with the PQ? Also, can you play +R/W disks on it?
M4P is offline
post #187 of 240 Old 02-03-2008, 05:08 AM
Moderator
Moderator
Quoted: 322 Post(s)
Liked: 6391
K, 4:2:2 is ok.
I have a 970 that outputs 480i/576i just fine. I've seen one or two people claim the SDI modded outputs a slightly better image, however, I have no idea what screen size is needed to see it or what the differences really are. The only issue is that the Mediatek MPEG decoder suffers from ICP (chroma error, just like almost every other MPEG decoder) but all scalers nowadays have filters to fix it. The Mediatek deinterlacer in the player does and excellent job of fixing the issue.
larry
post #188 of 240 Old 02-06-2008, 08:12 AM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
Seeing that the Denon DVD-2930CI is listed in this thread as a player with 480i output, I should mention that it's not a pure 480i output. The player seems to be doing some sort of processing before outputting 480i. This results in external video processors to severely trip on even the most basic material. Stay away from the Denon DVD-2930CI if you for some reason seek to use its 480i output.
MSmith83 is offline
post #189 of 240 Old 02-17-2008, 06:01 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Guys,
if SDI is not an option and price doesn't matter while picture quality and especially built-quality (= no! oppo) is important, what's the current 480i/576i non-plus-ultra DVD player ? I have looked into reviews for the Marantz 9600 and Arcam DV137 (and similar), but it's hard to find any statements on the digital SD quality, since the reviews (and reviewers) focus on the 1080p quality of the high-end players.
Any recommendations ?
Fudoh is offline
post #190 of 240 Old 02-23-2008, 07:27 PM
bullzeye's Avatar
I just picked up a Toshiba HD-A30 HD-DVD player on clearance from Best Buy, and can confirm that it will output 480i over HDMI. I'm surprised this one hasn't been mentioned. I played a horribly interlaced episode of Star Trek: TNG through my Onkyo TX-SR875's Reon processor, and it looked pristine.
The one downside is if you want to play an HD-DVD, you'll have to go into the setup and switch back to 1080p manually. But I don't imagine too many of us are going to be playing many HD-DVDs in the future.
bullzeye is offline
post #191 of 240 Old 03-10-2008, 02:04 PM
mjg100's Avatar
I am keeping my HD DVD A35 player just for the 480i output. Gefen has a new scaler coming out that has the T2-400 Realta chip in it. This should make an excellent up-converted SD image.
mjg100 is offline
post #192 of 240 Old 03-15-2008, 08:24 PM
ivo welch's Avatar
Quoted: 20 Post(s)
The original list of qualifying DVD players is years old. many of the models are now obsolete and can no longer be found.
Is there a list of *cheap* DVD players with HDMI out that qualify nowadays?
Do any of my local costco or walmart models fit the bill? since all we need is a 3-year old chipset, this should be really cheap today.
ivo welch is offline
post #193 of 240 Old 03-16-2008, 03:57 PM
greyflag's Avatar
Quoted: 29 Post(s)
The Oppo 980H seems to be the most cost effective solution out there. I have an Anthem AVM-50 on order and am deciding between the Oppo or a DV-79AVI demo unit. The new Denon DVD -2500BTCI transport is also in the running...
greyflag is offline
post #194 of 240 Old 03-16-2008, 04:13 PM
moxie1617's Avatar
The list was updated on 1/9/08. Re-read the 1st post again.
moxie1617 is offline
post #195 of 240 Old 03-16-2008, 07:06 PM
ashmostro's Avatar
the panny s53 is cheaper
though the oppo has nicer "features" imo.
i use the panny for compatibility reasons. it's a good transport.
post #196 of 240 Old 04-07-2008, 03:52 AM
kkpro's Avatar
Quoted: 136 Post(s)
Liked: 73
Does the S54 also output 480i? I went to Panny's website but it does not say.
kkpro is offline
post #197 of 240 Old 04-07-2008, 08:54 AM
ashmostro's Avatar
the downloadable manual says no, only 480p+
post #198 of 240 Old 04-07-2008, 09:02 AM
kkpro's Avatar
Quoted: 136 Post(s)
Liked: 73
Thanks, I'll try and get the S53 then
kkpro is offline
post #199 of 240 Old 06-04-2008, 07:59 AM
jackculb's Avatar
The S54K does in fact output 480i over HDMI.
jackculb is offline
post #200 of 240 Old 06-25-2008, 10:34 PM
Ultimateherts's Avatar
JVC XV-N652S/XV-N650B supports 480i HDMI.
Ultimateherts is offline
post #201 of 240 Old 11-01-2008, 11:01 PM
uderman's Avatar
Quoted: 108 Post(s)
Liked: 51
I am looking for a DVD player which can play region 2(ntsc/pal) movies from europe and japan. My current tv is a Sony XBR2 LCD which wont do PAL so I am going to need a pal to ntsc converter but soon I am buying a Pioneer 141FD which can use Pal/Ntsc/Secam. 480i over hdmi to denon 5308ci's hqv realta then pioneer 141fd.
there are a few options
i can buy a european player or version
or us player or version with region code hack
it could be a blu-ray player which can do 480i over hdmi (in a decent way thats mentioned in above posts) and a european player or version (region b and region 2) ntsc/pal
which do you think would be better?
note: i am not interested in watching region 1 dvds on this dvd player, i will be using a different one for that purpose. the reason i am looking for a transport is to take advantage of the realta in denon and spend less on the player
Wanted:
HD-VMD Discs
Muse/Hi-Vision Discs - Mint/Complete Only!
uderman is offline
post #202 of 240 Old 11-02-2008, 05:32 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3238 Post(s)
Liked: 2524
The Oppo 980 at $169 meets your criteria.
Blu-Ray: I'm not sure. I thought there were no such players for SD-DVD NTSC and PAL region free (without a soldering iron?) but I haven't kept up.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #203 of 240 Old 11-02-2008, 01:36 PM
uderman's Avatar
Quoted: 108 Post(s)
Liked: 51
-Bill
seems like its going to be an oppo 980h for me. in case i want to upgrade to something a bit better, what options would i have? again it could be a region 2 only player but i want the ntsc playback for japanese dvds.
would a pioneer 79avi be a much better transport than 980h?
Wanted:
HD-VMD Discs
uderman is offline
post #204 of 240 Old 11-02-2008, 01:47 PM
uderman's Avatar
Quoted: 108 Post(s)
Liked: 51
can I set oppo 980h to output native (ntsc or pal) system? There is a big chance that pioneer 141fd handles pal and ntsc signals better than oppos pal/ntsc converter.
and how is the Denon DVD-2500BDCI European edition(region B,region 2) comparing to oppo 980h on DVD playback? denon outputs 480i over hdmi and its a pal/ntsc player. I read some somehow negative feedbacks about denon dvd players like 3930 and 2930 in previous posts(they output 4:4:4 vs oppos 4:2:2) but denon must have a better mpeg decoder and interlacer than oppo. i know its much more money but it can play region b blu-rays for that reason i would be willing to spend more money on it.
thanks
Wanted:
HD-VMD Discs
uderman is offline
post #205 of 240 Old 11-02-2008, 07:27 PM
wmcclain's Avatar
Liked: 2524
Yes.
-Bill
post #206 of 240 Old 11-12-2008, 02:18 AM
Barneys's Avatar
Barneys is offline
post #207 of 240 Old 11-19-2008, 11:30 PM
mariajohn's Avatar
Arcam DV79
Marantz DV9600
Classe CDP-300
SigmaTek XMB-510
LG LDA-511
Hidef players:
Sony BDP-S1
Pioneer BDP-HD1
Toshiba HD-A2
I believe the Sony's do it. So do the Pioneers, but they are more expensive than your budget
mariajohn is offline
post #208 of 240 Old 12-01-2008, 03:28 AM
adesio's Avatar
fairly sure any dvd player that has dvi out and hdmi will also upscale... interested in what your application is here.
adesio is offline
post #209 of 240 Old 12-01-2008, 04:26 AM
wmcclain's Avatar
Liked: 2524
http://www.avsforum.com/avs-vb/forum...aysprune=&f=37
-Bill
post #210 of 240 Old 12-08-2008, 08:23 AM
greeno's Avatar
Liked: 25
Along with passing 480i via DVI/HDMI, I'd like to see a list of players that do not clip BTB and WTW via HDMI. From the display calibration sub-forum HERE there's some discussion of the clipping and Mediatek-based players. I have no colorspace control on my display (toshiba 36AV500U LCD) so I couldn't test that.
LG DN898 via HDMI (480i, 480p, 720p, 1080i (1080p not tested) clips BTB and WTW.
Philips 59xx via HDMI also clips BTB and WTW.
Note: BTB = blacker than black, WTW = whiter than white.
greeno is offline
Reply DVD Players (Standard Def)
