Denon DVD-3930 & DVD-2930 w/Realta T2 Chip Coming September- - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #271 of 4957 Old 07-09-2006, 09:02 PM
OCDMedic's Avatar
My kids and I wanted a PS3 anyways. This just kills 2 birds with 1 stone. I always got to put the kids first.
OCDMedic is offline
post #272 of 4957 Old 07-10-2006, 11:54 AM
sjoh's Avatar
Hello Everyone,
Somewhat off-topic, but does anyone know if Denon (or anyone else for that matter) is coming up with a 5 or 6 disk universal DVD changer with HDMI and one of the newer, better scaling/de-interlacing chips?
Sejin.
sjoh is offline
post #273 of 4957 Old 07-10-2006, 12:09 PM
dsmith901's Avatar
Originally Posted by jvernon View Post
Maybe so, but who in their right mind would buy that POS first generation clunker just to play DVDs? I understand your point if you want the HD-DVDs too (I don't), but even then it would seem to make more sense to wait for a second generation player without all the quirks.
And no, I am not a Blu Ray guy. I have no intention of getting either one for several years. I will let you first adapters - read beta testers - have all the fun.
But why spend $1,500 on a SD DVD player, no matter how good, when you can get one almost as good for $200 (Oppo) and save the rest for a 2nd gen HD/BD-DVD player? And who says the Toshiba A-1 is a POS except a Blu-Ray proponent (as if the Samsung BD player was something to brag about)? Or better you you could spend that $1,500 now on a DVDO VP-20/30 and improve PQ on all your digital video, not just DVD, not to mention getting a nice HDMI switcher in the bargain?
"The truth is out there!"
dsmith901 is offline
post #274 of 4957 Old 07-10-2006, 12:58 PM
QuadESL63's Avatar
Some folks here get the 3910/3930 not just for the upscaling SD-DVD playback... they also want to listen to DVD-A/SACD 2ch/multichannel musics as well.
QuadESL63 is offline
post #275 of 4957 Old 07-10-2006, 01:06 PM
zyoung's Avatar
Agreed, most of the extra expense is devoted to the audio section of this player, and to me it is worth it to have a universal player that is on par with a dedicated music transport.
"You know Ed... if I thought you weren't my friend... I just don't think I could bear it"
zyoung is offline
post #276 of 4957 Old 07-10-2006, 06:49 PM
Kevin C Brown's Avatar
Liked: 27
There's also reliability and quality control in addition to sound quality. I don't know if my impression is correct or not, but you'd also get that with the Denon more so than with Oppo.
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #277 of 4957 Old 07-10-2006, 09:07 PM
DavidHir's Avatar
Quoted: 1705 Post(s)
Liked: 1326
I'm not sure if Denon has better quality control or not. But, I will say Oppo's customer service is top notch. Rumor is Oppo is coming out with a higher end player within the next six months or so - should be interesting.
DavidHir is online now
post #278 of 4957 Old 07-11-2006, 08:10 AM
QuadESL63's Avatar
The Denons (at least with my 2900 and 3910) are pretty well built and reliable... at least more reliable than my Pioneer DV-S10A (which died a year after I got it all the way from HK).
One thing I don't like my 3910 is that when you choose to use i.Link audio the coax/optical SPDIF ports are disabled! With my setup I can't connect the SPDIF to my 2ch DAC for CD and the i.Link to my Pioneer Elite for 2ch/multichannels SACD/DVD-A without going through the setup menu to make the change. If the 3930 allow both to be active at the same time I'm all for it After reading more and more on this player it got me seriously tempted I just don't know if I should get another $1000+ Cadn player again at this time esp. when my Toshiba HD-A1 is doing a fine job on SD-DVD movies w/ HD-DVD playback capability, and my 3910 has me covered for hi-res audio.
post #279 of 4957 Old 07-11-2006, 09:52 AM
zyoung's Avatar
Ditto for me, when using MC analog for music/SACD/DVD-A, and DL3 for movies I have to go into the menu to make the switch. It is annoying, but I think it's a pretty common thing with most players to disable one or the other.
zyoung is offline
post #280 of 4957 Old 07-11-2006, 11:47 PM
c722's Avatar
well I think it's not uncommon to have both available. The Pio 59 does. Also, for the 3910 if u set video output to be HDMI, you will have no output at component. You have to set the output either digital or analogue. The pio has both active at the same time.
I hope the new Denons do not have these restrictions. The 5910 has both active. So if they follow the design pattern the new ones should be the same.
c722 is offline
post #281 of 4957 Old 07-12-2006, 12:40 AM
zyoung's Avatar
Well, I was talking about analog vs. digital audio in this case, and I should really clarify. The 3910 will output via the MC analog outs while DL3 is activated, but the AL24 plus indicator doesn't light up until you disable DL3.
As far as simultaneous video output , I don't know, but it's not something I would ever do anyway.
zyoung is offline
post #282 of 4957 Old 07-12-2006, 08:59 AM
c722's Avatar
EDIT: sorry I see how the confusion starts. I was actually referring to Quad's remarks.
Well AL24 plus is an analogue "feature", it *may* make some sense to disable itself when DL3 is enabled, since it thinks you are going to use DL3 to do a digital transport and go whatever DA processing in the receiver. Since DL3 carries both DVDA and SACD now, it probably is excuseable. (i.e. if u can use DL3 in the receiver for DD/DTS , why can't you use it for mc audio ?)
Quad's complaint, which I fully share, is that is disables SPDIF audio out when u select ilink. SPDIF is another digital transport, which is very useful for a 2channel setup. For pure stereo we may have a separate gear in addition to the pre/pro for HT. I think the 5910 doesn't have this restriction. The pio 59 doesn't have either.
I guess it will be very useful when it's connected to multiple displays, say a TV set and a projector at the same time. Not that I have both on at the same time, but I should not need to "select" an output whenever I turn on a PJ or a TV. Again the 5910 has no such restriction so I'm optimistic on this.
c722 is offline
post #283 of 4957 Old 07-12-2006, 09:52 AM
zyoung's Avatar
I could see how that could be a problem, just not one that I've ever run up against because my setup is more conventional: 3910 connected to a 3805 connected to a single 5.1 speaker setup, no additional amplification, no additional display.
zyoung is offline
post #284 of 4957 Old 07-12-2006, 09:58 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 4009
If you guys are just going to talk about the 3910, could you please take it to the 3910 thread? Thanks.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #285 of 4957 Old 07-12-2006, 10:03 AM
s2silber's Avatar
Can anyone report any sightings of the '3930 for sale? I've seen only the following on a pre-order basis.
http://www.newyorkwholesaleaudiovide...3928C1711.aspx
s2silber is offline
post #286 of 4957 Old 07-12-2006, 10:43 AM
Moderator
Moderator
Quoted: 286 Post(s)
Liked: 4009
Cool, now we have a price. (Unless I missed it earlier).
larry
post #287 of 4957 Old 07-12-2006, 10:47 AM
shane55's Avatar
Yes, and a price on the 2930 as well.
shane
"Yes Eve... I like to watch." - Chauncey Gardener.
My HT Setup:
http://www.fototime.com/A0E2793180FB3D0/orig.jpg
shane55 is offline
post #288 of 4957 Old 07-12-2006, 10:50 AM
s2silber's Avatar
larry
Mind you, that's a discounted price from an unauthorized online dealer.
s2silber is offline
post #289 of 4957 Old 07-12-2006, 11:02 AM
BillP's Avatar
Quoted: 259 Post(s)
Liked: 201
Which makes it very risky (I believe Denon does not honor the warranty on unauthorized dealer purchases). I believe the list price is $1500 (same as the 3910).
BillP is offline
post #290 of 4957 Old 07-12-2006, 11:21 AM
Pete's Avatar
Quoted: 219 Post(s)
Liked: 79
Update according to my local Denon dealer:
Denon will ship the DVD-2930CI this month -- probably towards month end. MSRP: $849. The DVD-3930CI ships in August -- end of the month. MSRP: $1499
The DVD-3910 goes away, but the DVD-2910 stays in the line to fill the gap between the DVD-1930 (August/$349) and the 2930CI.
Pete is offline
post #291 of 4957 Old 07-12-2006, 11:57 AM
shane55's Avatar
True 'nuff.
I just called my guy at Magnolia. No date for anything but the 1930 (I didn't ask), but the price for the 2930 & 3930 were list (see above) and they already had a few pre-orders.
shane
My HT Setup:
shane55 is offline
post #292 of 4957 Old 07-12-2006, 01:52 PM
Bill Mac's Avatar
Quoted: 1268 Post(s)
Liked: 1445
Is there any info. on the 2930 as far as audio/ video inputs and outputs? I was wondering if there is a i-link output.
Thanks, Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #293 of 4957 Old 07-12-2006, 02:01 PM
shane55's Avatar
Thanks, Bill
It doesn't appear to.
http://www.avbuzz.com/audio-video/20..._DVD/index.htm
shane
My HT Setup:
shane55 is offline
post #294 of 4957 Old 07-12-2006, 03:24 PM
Bill Mac's Avatar
Liked: 1445
shane
Shane,
Thanks for the link. I wonder if it is HDMI 1.2.
Bill
post #295 of 4957 Old 07-12-2006, 03:49 PM
shane55's Avatar
Shane,
Bill
HDMI 的輸出同時包括多聲道的音頻信號 version 1.1
shane
My HT Setup:
shane55 is offline
post #296 of 4957 Old 07-12-2006, 04:31 PM
Bill Mac's Avatar
Liked: 1445
shane
Shane,
Sorry about that, how could I have missed that! How would you say that by the way.
Thanks again, Bill
post #297 of 4957 Old 07-12-2006, 05:05 PM
shane55's Avatar
Shane,
Thanks again, Bill
Just like it's spelled.
shane
My HT Setup:
shane55 is offline
post #298 of 4957 Old 07-12-2006, 09:17 PM
stereowise's Avatar
I just picked up a referbished Denon DVD-2200. I wanted a universal dvd player with good build quality and excellent audio quality. I have heard good things about the Oppo players, but skeptical about just how good sub 5lb player can be in the build and audio quality. I'd heard some say that companies like Denon just jack up the prices of their units and that is why Oppo is so cheap. I'm not saying that theory is wrong, but I would love to have it proven correct with Oppo coming out with a universal player that will play about every format known to exist, with HDMI 1.2, the new Silicon Optics like the Denon DVD-2930, Burr-Brown DSD-179X chips, isolated construction in a 10lb package, and a <$500 price. THAT would rock!!! Ok...I'll wake up now.
Owner/Editor
Stereowiseplus
stereowise is offline
post #299 of 4957 Old 07-12-2006, 09:28 PM
stereowise's Avatar
shane
Thanks for the link. Loks like they are still using the same Burr-Brown DSD-1791 chips in the 2930 as in my 2200. Getting a lot of mileage out of them. I'll just keep my 2200 for audio and wait for a HD player to use as my video player.
Owner/Editor
Stereowiseplus
post #300 of 4957 Old 07-12-2006, 10:04 PM
Expletive's Avatar
Quoted: 47 Post(s)
Well the new one does that (play all the audio formats) but over HDMI 1.1 which is arguably just as good. As for the BB DACs, if youve got an HDMI 1.1 compliant receiver/processor you have no need for ANY DACs in the player.
Expletive is offline
Reply DVD Players (Standard Def)
Denon Blu Ray Dvd Cd Player
