Philips DVP 5960 HDMI DIVX player - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 409 Old 04-08-2007, 05:11 PM
kortik's Avatar
interesting
did you plug your cable into the hdmi port on the dvd?
kortik is offline
post #272 of 409 Old 04-08-2007, 05:25 PM
wildthing_UK's Avatar
Originally Posted by kortik View Post
interesting
Yes, but viewing menu via scart connection.
wildthing_UK is offline
post #273 of 409 Old 04-09-2007, 02:15 PM
nogasbiker's Avatar
I have the DVP5960 hooked up to a Vizio 47" lcd via hdmi.
I noticed that edges and lines are cleaner in 1080i upscaling mode, but the image is slightly squashed vertically. On a 47" lcd, it is about an inch or two vertically. The images appear to be correct at 480p, but upscaling thru 576, 720, and 1080 causes a successively more vertical squashing.
No one noticed around here, but I noticed and it bugs me. I checked with the scientific thumb on the LCD while cycling thru the different upscaling settings.
Is this a player problem, or a monitor problem?
nogasbiker is offline
post #274 of 409 Old 04-09-2007, 04:06 PM
Huey's Avatar
I believe this is a Mediatek chipset problem apparent on Oppo 970, Sony 75H, and Phillips Divx/DVD players (even the newest 5982). It's not your display. 480p is fine but 720p and 1080i have this vertical aspect problem.
Huey ;-]
Huey is offline
post #275 of 409 Old 04-09-2007, 05:22 PM
nogasbiker's Avatar
Thanks for the info. No workaround or fix. right? That would be a shame if I can't use 1080i upscaling, as the image is somewhat better (on Phantom of the Opera dvd)
post #276 of 409 Old 04-09-2007, 11:26 PM
dr0s's Avatar
Huey: the image is not squashed on the Sony, since that player does postprocessing to re-expand the image (though some say that it softens the image).
Nogasbiker, you are not missing any of the image, it is simply vertically compressed by a negligible amount. You wouldn't even have noticed if you didn't have a thin blank band across the bottom of the screen. If you think that the image is clearest at 1080i, then just leave it there, and ignore the band the same way you ignore sidebars on 4:3 images. - DR
dr0s is offline
post #277 of 409 Old 04-10-2007, 11:34 AM
ppwi's Avatar
I need some advice on upscaling. I have a 5960 and recently bought a HDMI cable to connect the 5960 to the receiver. I have a Sanyo Z4 projector connected to the receiver with component cables. I haven't seen any improvement in watching DVDs. Do I need to connect the projector to the receiver using HDMI cable as well? Thanks for any help.
ppwi is offline
post #278 of 409 Old 04-10-2007, 11:58 AM
piturra's Avatar
I would think so since Component video signals is not the same as HDMI digital video signals.
Just for kicks, connect the HDMI directly to your Sanyo Z4 projector and see what that looks like!
Phil
piturra is offline
post #279 of 409 Old 04-10-2007, 12:35 PM
karlw2000's Avatar
You may not seen an improvement. If you TV does a good job of upscaling from the 480p, then you very well not see any difference.
karlw2000 is offline
post #280 of 409 Old 04-11-2007, 04:51 PM
nogasbiker's Avatar
Originally Posted by dr0s View Post
The "shift bug" is an upscaling characteristic of the mediatek chipset, not the particular player. It (a) should not happen at 480p, and (b) does not represent a loss of any image, just a slight vertical compression. - DR
I measured the image for fun
Phantom of the Opera 2-disc collectors edition, upc 012569702998. Correct aspect is 2.35.
Image width is 41" for all resolutions
480p 18.5 2.22
576p 18.75 2.19
720p 17.63 2.33
1080i 16.63 2.47
17.6" to 16.6" is a big deficit, about 6% loss. The characters don't look quite right. You get used to it 10 or 15 minutes into the movie, but I think I will keep it at 720p for accurate reproduction. Amazingly, running it at 576p for 6% stretch actually nice.
post #281 of 409 Old 04-12-2007, 11:06 AM
ppwi's Avatar
Thanks piturra and Karl. Unfortunately, I have the component cables buried behind the wall and it won't be a simple matter to connect the HDMI cable to test it. I was hoping I had just overlooked something simple.
ppwi is offline
post #282 of 409 Old 04-12-2007, 12:42 PM
apaulct's Avatar
480p 18.5 2.22
576p 18.75 2.19
720p 17.63 2.33
1080i 16.63 2.47
I tried to duplicate your test this rainy afternoon ... I only have the Phantom single disk edition, upc 0 85393 89512 9. It also should have a aspect ratio of 2.35. Displayed on my Toshiba 62HM116 the width is 54", the height should be 23".
480p 24.625" a/r 2.19
720p 22.75" 2.37
1080i 22.75" 2.37
On my TV, looks like 720p and 1080i are more accurate. I see no size difference between 720p and 1080i and are very close to correct. Wonder if it is the display ... the 62HM116 is a native 1080p display.
Allen
apaulct is offline
post #283 of 409 Old 04-12-2007, 01:16 PM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
480p 18.5 2.22
576p 18.75 2.19
720p 17.63 2.33
1080i 16.63 2.47
Please note that the larger picture size (smaller aspect ratio) you get in 576p and 480p is probably due to overscan from your display and not the mediatek scaling. I know that is the case for my panasonic plasma. The squishing at 1080i is directly due to the mediatek scaling.
zoyd is offline
post #284 of 409 Old 04-12-2007, 08:38 PM
chaarlieee's Avatar
How does the 5960 compare to the s52s? I just bought a 5960, but knew nothing of the s52s until just a few minutes ago. Did I make the right purchase?
I know about the divx/xvid/mpeg playback, so that's all just a plus.
But the most important features to me are picture quality, sound quality, and if it's region free. How do the 5960 and s52s compare in these three areas?
chaarlieee is offline
post #285 of 409 Old 04-13-2007, 12:35 AM
kortik's Avatar
what is s52s never heard of it
kortik is offline
post #286 of 409 Old 04-13-2007, 01:18 AM
piratehunter's Avatar
Do these Philips players handle native PAL? Is there actually a setting for PAL in the menu?
piratehunter is offline
post #287 of 409 Old 04-13-2007, 02:21 AM
dr0s's Avatar
The 5960 does handle PAL.
chaarlieee. if you mean the Panasonic s52s, the PQ should be about the same, the Panasonic is probably slightly better built, but the Philips has much more functionality as it can be made region-free (the US version of the Panny is region-locked). - DR
dr0s is offline
post #288 of 409 Old 04-13-2007, 06:05 AM
chaarlieee's Avatar
That's great if the picture quality is about the same. How about the sound quality?
post #289 of 409 Old 04-13-2007, 09:21 AM
SteveCaron's Avatar
Quoted: 85 Post(s)
Liked: 54
PAL DVD's play flawlessly on this machine.
SteveCaron is online now
post #290 of 409 Old 04-13-2007, 10:04 AM
antexit's Avatar
Hey guys,
I just got this DVD player, and with it I bought an HDMI-->DVI converter cable to take advantage of the upscaling, since my TV doesn't have an HDMI input. And it doesn't work at all; the image is grainy and all green, as though it's missing the blue colour element. I've returned the cable already and replaced it with no change; do you think this is a problem with the DVD player or with one of the ports or the TV itself, or what? It's very frustrating.
Luc
antexit is offline
post #291 of 409 Old 04-13-2007, 02:27 PM
Mr. Music's Avatar
Do you still have the component cables connected to the player?
Mr. Music is offline
post #292 of 409 Old 04-13-2007, 03:10 PM
antexit's Avatar
No, that's not the problem, unfortunately.
antexit is offline
post #293 of 409 Old 04-13-2007, 08:47 PM
unleashed's Avatar
Back in stock at the employee store.
Only $54 shipped.
unleashed is offline
post #294 of 409 Old 04-13-2007, 11:44 PM
dr0s's Avatar
chaarlieee, sound is not a strong point for the 5960; for example, high-resolution audio is not supported (but this is true for the Panny as well).
antexit, I am no expert on the Westinghouse sets (but such experts do exist on the board!), could it be that the dvi port is set to the PC colorspace instead of TV colorspace, or that there is a handshaking setting turned off? Alternately, was your replacement cable/adapter the same brand, or did youtry another brand? - DR
dr0s is offline
post #295 of 409 Old 04-14-2007, 04:28 AM
Bud-man's Avatar
Did walmart ever sell these?, i got a 3960 there.
Bud-man is offline
post #296 of 409 Old 04-14-2007, 11:14 AM
chaarlieee's Avatar
What do you mean? Sorry about not being specific, I just meant how does the sound quality of the Philips 5960 compare to the Panasonic S52S in DVD's with DTS, etc.
post #297 of 409 Old 04-16-2007, 08:56 AM
nogasbiker's Avatar
720p 22.75" 2.37
1080i 22.75" 2.37
That's weird. My Vizio 47" lcd is also a native 1080p. For what it is worth, ff the air 1080i looks fine on my lcd.
post #298 of 409 Old 04-16-2007, 10:15 PM
thumperxr69's Avatar
I have a file with the following settings:
I have a couple of Divx files that are being viewed from a USB flash drive and the TV is showing bars on the bottom and the sides (squished on all sides). These DIVX files play in widescreen mode fine from my PC.
General #0
Format : AVI
Format/Info : Audio Video Interleave
Format/Family : RIFF
File size : 231 MiB
PlayTime : 43mn 4s
Bit rate : 743 Kbps
Video #0
Codec : XviD
Codec/Family : MPEG-4
Codec/Info : XviD project
Codec settings/Packe : No
Codec settings/BVOP : No
Codec settings/QPel : No
Codec settings/GMC : 0
Codec settings/Matri : Default
PlayTime : 43mn 4s
Bit rate : 602 Kbps
Width : 704 pixels
Height : 400 pixels
Aspect ratio : 16/9
Frame rate : 29.970 fps
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.071
Writing library : Lavc51.29.0
Audio #0
Codec : MPEG-1 Audio layer 3
Codec profile : Joint stereo
PlayTime : 43mn 4s
Bit rate : 128 Kbps
Bit rate mode : CBR
Channel(s) : 2 channels
Sampling rate : 48 KHz
Resolution : 16 bits
Ideas???
username should now be "ThumperYZ69"
Yamaha RX-V867
EMP Tek R55Ti/R56Ci
Outlaw Ultra X-12
thumperxr69 is offline
post #299 of 409 Old 04-17-2007, 10:37 AM
cheer's Avatar
They should be identical. The DVD player is just passing digital bits to your receiver which does the decoding.
Christopher D. Heer
Disclaimer: I neither speak for nor represent my employer or its views.
Originally Posted by Oscar Wilde
Work is the curse of the drinking classes.
cheer is offline
post #300 of 409 Old 04-18-2007, 04:48 AM
Bud-man's Avatar
Width : 704 pixels
Height : 400 pixels
that says it all thumper, xvids are all custom made i've made many, you can adjust the size to anything you want, black bars are very common, most xvids are extremely squished compared to the standard 720x480 dvd size.
Bud-man is offline
Reply DVD Players (Standard Def)
