New LG-DN191H - AVS Forum | Home Theater Discussions And Reviews
post #1 of 260 Old 05-16-2006, 10:16 AM - Thread Starter
5555's Avatar
5555 is offline
post #2 of 260 Old 05-16-2006, 09:56 PM
WaldorfSalad's Avatar
Does it have the same suction loader as the 511 or a tray like the 418? Can't tell from specs on LG web site.
Can it be made region free easily?
Does it have a PAL-to-NTSC converter? Can't tell from specs on LG web site.
Can it play MP3s from a DVD or just from a CD?
According to specs on LG web site it does DVD-Audio but as there are no 5.1ch analog outputs then it is probably via HDMI like the new Panny S52.
WaldorfSalad is offline
post #3 of 260 Old 05-17-2006, 08:23 AM
iqwertyi's Avatar
Looks like a tray from the pic.
iqwertyi is offline
post #4 of 260 Old 05-17-2006, 04:32 PM
Dreamcat's Avatar
I found another website where a person who bought this model already said it has a slot loader and the upscale over component code does not work on it.
Dreamcat is offline
post #5 of 260 Old 05-18-2006, 06:39 PM
I saw this player in BB today.
On the box it states that is has a slot loader but it definitely has a tray (plugged it in, powered it up, opened the tray and put a DVD in it).
Hooked it up to a TV using HDMI and put in a region-free PAL DVD. It played it just fine so that would imply that it has a PAL-to-NTSC converter like previous models.
I have no idea if the player can be made region free though using publicized hacks.
It definitely does not have 5.1ch analog outputs so DVD-Audio would be over HDMI like the new Panny S97.
I would not expect upconverting to work over component without the hack.
post #6 of 260 Old 05-18-2006, 07:25 PM
zrdb's Avatar
Here's the story on this player-none of the 418 or 511 hacks except the one for the information screen work on this unit, it will upscale xvid/divx and unprotected dvds through the componet output, it has a Zoran Vadis 888 chipset, my experiance was that the 12 bit 110mhz video dacs didn't really make much of an improvment in the picture quality. It appears that it doesn't support as long of xvid/divx file names as the 511 or 418. I took it back and will continue to use both my 418 and 511. What I really want is a player that handles h.264. And it isn't a slot loader, it has a tray.
zrdb is offline
post #7 of 260 Old 05-19-2006, 11:21 AM
Mofongo's Avatar
Zrdb,
The Zoran Vaddis is the same chipset line that Samsung has used for years, since it has the "ZoranZoom" feature which I believe Samsung's EZ-View feature makes use of. I really want something like EZ-View, but have been disappointed in Samsungs DVD players otherwise. I would really like to know if LG made use of this feature of the Vadis 888. Did you happen to check the DN191H to see if it can zoom to get rid of the black bars above and below a 2.39:1 movie, but still maintain image quality?
I tried downloading the manual from LG's website, but none of their DVD player manuals will download for me. (very weird).
Mofongo
Mofongo is offline
post #8 of 260 Old 05-19-2006, 06:02 PM
zrdb's Avatar
Yes it does-although LG calles it by a different name (can't remember what is called though as I only had the player for 2 days).
zrdb is offline
post #9 of 260 Old 05-23-2006, 09:18 PM
Mofongo's Avatar
zrdb, since you also post to the Sony DVP-NS75H board, do you also have a Sony NS75H (or 85H)? If so, how would you compare it to the DN191H and/or LDA-511?
Mofongo
Mofongo is offline
post #10 of 260 Old 05-24-2006, 07:39 AM
zrdb's Avatar
To be honest I use my LDA-511 and 418 primarily for xvid/divx which is where they excell, I use my 85 for most of my regular dvd watching because it'll play just about any thing that you can load in it, it has a really nice picture on my 27" crt hdtv, it'll play every home made dvd that I've put in it. Don't get me wrong-both of the LG's are excellent players-they display upscaled avi excellently.
zrdb is offline
post #11 of 260 Old 05-24-2006, 09:10 PM
Mofongo's Avatar
Thanks! Another quick questions (sorry to keep asking, but if LG would put a manual on their #!#!@ website, then I could look this up myself).
I just got my Samsung DVD-HD960 (1080p output) in the mail today. It does a really good job except with "mosquito noise". It has a noise filter setting, but it still does not seem to tackle the noise as well as my laptop can with ffdshow filters.
I know that the Sony has settings for two different kinds of noise (mosquito and something else). Do you remember what kinds of settings the DN191H had for noise reduction?
Thanks again!
Mofongo
Mofongo is offline
post #12 of 260 Old 05-24-2006, 09:38 PM
zrdb's Avatar
None.
zrdb is offline
post #13 of 260 Old 05-25-2006, 08:12 AM
Bud-man's Avatar
Hey zrdb, your say your sony plays everything?, well we know it doesnt play xvid, what about PAL?
Bud-man is offline
post #14 of 260 Old 05-25-2006, 06:56 PM
zrdb's Avatar
Nope-strictly NTSC.
zrdb is offline
post #15 of 260 Old 05-25-2006, 10:33 PM
I tossed a region-free PAL DVD into an LG191 at BB and it played it just fine.
Edit: Oops, never mind, looks like this thread drifted into discussion of Sony players (which don't do PAL).
post #16 of 260 Old 05-29-2006, 06:05 PM
Tweak48's Avatar
I needed a down and dirty replacement for my 7 year old Toshiba that puiked yesterday morning. I went for the LG-DN191H because BB had a $10 instant rebate on it, an additional 10% coupon at the door, and it's one of the few DVD players out there that will do upscaling via the component video jacks. It's driving a 37" Panny ED industrial plasma, and as you may know industrial Pannys don't come with a ton of inputs (like no HDMI or DVI jacks; you want one you pay for one).
Pros:
*good color balance
*fairly sharp at 1080i through the component outputs (I don't know why it would be given the ED's native resolution is lower than that)
*good sound in the simulated surround mode (it's in a 2 channel system)
*easy to use remote
*cheap to buy
Cons:
*cheap loading tray
*cheap remote
*image seems slightly dark on some movies
Tweak48 is offline
post #17 of 260 Old 05-29-2006, 06:46 PM
jliles's Avatar
For those of you who've used this player, can you answer a few questions?
I have a player with the previous version of the upscaling Zoran chip (the 778, I think), and it is capable of playing Nero Digital MP4 files with standard profile. Can this player do that? Do .mp4 files even appear in the file browser? Also, since the previous version of the chip properly handled divx/xvid aspect ratios correctly, I'm guessing this one does too, but if someone would confirm this for me that would be great.
Does this new chip play DivX 6 ultra features like menus and chapter stops (not really necessary for me, just curious).
Also, when playing commercial DVDs using HDMI and 1080i or 720p resolutions, does it pillarbox 4:3 material or stretch it on a widescreen TV? My current player stretches the image and it is incredibly annoying.
Thanks for your help...
Julie
jliles is offline
post #18 of 260 Old 05-29-2006, 07:28 PM
Huey's Avatar
Dear Tweak48, you mean to tell me that the LG-DN191H can upconvert via component on copy-protected DVD's without any hacks? If so it's truely unique.
Huey ;-]
Huey is offline
post #19 of 260 Old 05-29-2006, 08:07 PM
scrapdiggs's Avatar
Nope. It only upconverts to 480p...unfortunately I just found that out after just buying it.
Dammit!
Does the 511 do this as well?
scrapdiggs is offline
post #20 of 260 Old 05-29-2006, 10:11 PM
scrapdiggs's Avatar
Anyone know if there is a HACK to get this upconvert to work to 720p on the DN191H? I must say that it does kick out the nicest 480p picture ive seen yet however. I did buy it for the upscaling though.
post #21 of 260 Old 05-29-2006, 10:14 PM
Tweak48's Avatar
So far I've played a couple of DVDs and they've worked great at 1080, but I don't know what ones are copy protected and what ones are not.
On the other thread it mentioned that Disney discs are protected, so I'll give that a try.
Tweak48 is offline
post #22 of 260 Old 05-30-2006, 07:24 PM
HD-Dummy's Avatar
I'm thinking of buying this DVD player tomorrow. I just saw it at BB today and it's on sale so I figured I'd give LG a shot. I'm not a videophile, not in the least, but I do want a smooth picture on my 5067w.
I plan on connecting it via HDMI cable and hooking my STB up via components since my box outputs 720p over either component or HDMI.
I'll post my impressions of it tomorrow evening but I doubt it plays protected disks via component even though it has 480i, 480p, 720p, and 1080i written right under the component output. I'll let you guys know.
HD-Dummy is offline
post #23 of 260 Old 05-30-2006, 07:56 PM
scrapdiggs's Avatar
As ive already said, this does not upconvert protected discs to anything more than 480p, ive got one right now in my theater.
post #24 of 260 Old 05-30-2006, 08:11 PM
HD-Dummy's Avatar
Chilli Fries (or, as is more common, cool beans).
I'm still getting this player tomorrow, tho, and I hope to find some hacks for it. I doubt the 511 hacks work (I believe someone posted they didn't) so I'll have to keep my ear to the ground and try and find someone who knows the hacks for this model.
HD-Dummy is offline
post #25 of 260 Old 05-30-2006, 08:16 PM
scrapdiggs's Avatar
mmm...ya.....they dont exist. But ive only spent a week trying to find them, if you do find them let us all know.
post #26 of 260 Old 05-31-2006, 06:03 AM
zrdb's Avatar
See my earlier post on my impressions of this unit.
zrdb is offline
post #27 of 260 Old 05-31-2006, 11:34 AM
HD-Dummy's Avatar
Well, I've only had it hooked up for about an hour but I really like this player. It's connected over HDMI at 720p (I couldn't see a difference between 720p and 1080i so I left it on the HL-R5067w's native resolution).
The PQ is really good; much better so than my old Panasonic (it was about 5 years old and wasn't even progressive scan, tho).
The sound is so-so, but I'm not complaining. I have not connected it to my receiver yet so I don't know if it will have lip-sync issues. I'll test that out when I get a digital coax cable (I somehow broke mine).
I'd give the player 4 out of 5 stars and, for the price, you can't really beat it.
HD-Dummy is offline
post #28 of 260 Old 05-31-2006, 12:12 PM
Does this DVD player have an option to pillar-box (Normal mode) 4:3 content at the DVD end to accomodate the case whereby your TV won't let you choose Normal mode when sending 720p or 1080i over HDMI? Unfortunately the manual is not yet available on the LG web site so I can't RTFM to get the answer.
post #29 of 260 Old 06-05-2006, 08:57 AM
HD-Dummy's Avatar
I guess nobody's figured out any hacks for this player yet.
I've done Google searches but I cannot find anything. I know that LG is a rebranded something else (maybe Zenith???) so if anyone knows maybe we can find some hacks for the player it's rebranded from. I'm not an expert on this, far from it, but I'd like to customize my player with a few hacks if they're available.
Anywho, I hope someone finds some soon.
HD-Dummy is offline
post #30 of 260 Old 06-05-2006, 09:17 AM
scrapdiggs's Avatar
LOL.....as we already said.
Reply DVD Players (Standard Def)
