Need advice on component upconverting DVD player - AVS Forum | Home Theater Discussions And Reviews
Old 05-23-2006, 07:01 AM - Thread Starter
MiBz's Avatar
My Sony DVD player just died and I need to pick up a new one.
For now I need a unit that upconverts over component, but that also has HDMI for later. It'll be currently connected to a Toshiba 56"W RPTV at 1080i (component). I'll upgrade to a 50" PDP later this year (HDMI).
I know some of the LG units have hacks to enable upconversion over component even on copy protected DVDs. Here's some of the choices.
LG DV7832NXC , older model, Canadian equivalent to the Zenith DVB318, firmware hacks.
LG LDA-531 more recent model also with firmware hacks and better than the newest LDA-731 which doesnt upconvert over component and has an inferior pic according to most reports on this forum.
I know Samsung has some models like the 841 & 851 that upconvert but can't remember if it's over component.
What do you guys recommend and why? Have I missed something ?
MiBz is offline
Old 05-23-2006, 08:13 AM
archiguy's Avatar
Quoted: 3432 Post(s)
Liked: 3306
The Samsung 841 and 941 will both upconvert over component (disables HDCP which allows the upconverted image to be transmitted over component ouputs) with a simple remote "hack". They're good, inexpensive players.
archiguy is online now
Old 05-23-2006, 03:48 PM
louthewiz's Avatar
Ditto on the samsung hd841 I have one and for 50 bucks you can't beat the value.
http://www.ubid.com/Samsung_HD_DVD_P...800677198.html
louthewiz is offline
Old 05-27-2006, 05:26 PM
scrapdiggs's Avatar
Will this work into a Component input on a projector that is VGA?
scrapdiggs is offline
Old 05-27-2006, 09:54 PM
tattootearz's Avatar
hmmm... I'm an Oppo owner but I have an issue with the fact that I have to use the zoom button to fill the screen on older DVDs. Does the samsung unit have a better screen filling mode? It sucks to have to watch a widescreen movie in the center of the screen.
tattootearz is offline
louthewiz's Avatar
Old 05-27-2006, 09:57 PM
louthewiz's Avatar
