Oppo Digital DV-970HD FAQ / Brain dump - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 6318 Old 05-31-2006, 09:05 AM
Steve L's Avatar
Originally Posted by PooperScooper View Post
One thing I forgot to mention, the 970HD no problem switching resolutions and sending 480i via HDMI to the DVI input on my display. Some HDMI players have various issues talking to a DVI input.
Larry,
Any HDCP issues setting up this way? My P5040XHAUS does not support HDCP via DVI.
Does HDCP come into play at 480i? It's not supposed to, but I seem to recall Oppo telling me they were enforcing it at all resolutions.
/steve
Steve L is offline
post #92 of 6318 Old 05-31-2006, 09:25 AM
Dntblnk22's Avatar
I am considering this player for use in a 2-Channel setup that sees some light video use as well. I am particularly interested in the DACs in this player as I'll be sending all information to an analog receiver. Would someone be willing to speak to the performance of the 970HD regarding audio?
A great many thanks.
Dntblnk22 is offline
post #93 of 6318 Old 05-31-2006, 09:29 AM
c722's Avatar
Originally Posted by LEVESQUE View Post
The CUE is usually not a problem with a good scaler.
.. well, the ICP is a problem. The VP30 cannot filter the pio's ICP. So does this new Oppo suffer from ICP ?
btw, can it output HDMI and analogue at the same time ?
c722 is offline
post #94 of 6318 Old 05-31-2006, 09:57 AM
bobloblaw's Avatar
According to Kris's benchmark test, ICP is not a problem when using the VP30 (with ABT102 installed). I could be missing something in the test results though...
BDP-83 EAP (first 50)
bobloblaw is offline
post #95 of 6318 Old 05-31-2006, 10:15 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 4030
Originally Posted by Steve L View Post
Larry,
/steve
My DVI input (the only digital input) on my P50 is HDCP compliant. I had no problems. I don't know if 480i wants HDCP or not. HDCP is "free" with HDMI chips and I don't know if it's always on or not, or implementation dependent. I could see where switching it on and off when changing resolutions would cause nightmares with various displays.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #96 of 6318 Old 05-31-2006, 10:20 AM
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
The DV970HD does not pass ICP fully, but it is still fairly watchable. I will see if I can't run it through a VP30 this afternoon and see what developes.
Yes, the analog and the digital outputs are live at the same time.
Neuromancer is offline
post #97 of 6318 Old 05-31-2006, 10:40 AM
MikeSRC's Avatar
The 970HD uses the same audio DACs as the 971H (Cirrus Logic CS4360). However, the engineers have tweaked the audio section for optimal performance so CD, SACD and DVD-A playback over analog is quite good.
Regarding CUE, it was addressed with the 970HD prior to the production models being released, so you shouldn't have a problem with it.
Enjoy!
Mike
Surf Remote Control
MikeSRC is offline
post #98 of 6318 Old 05-31-2006, 10:41 AM
DavidHir's Avatar
Quoted: 1706 Post(s)
Liked: 1329
Originally Posted by Josh Z View Post
I've been testing this player for a couple of months. As mentioned, the deinterlacing is not quite as good on video material as the 971H, but it provides a very clean 480i/576i signal via HDMI, which will be very appealing to those using video processors.
I always felt that the 971H's picture was a little soft, likely due to the Faroudja processing. The 970HD is indeed slightly better in this regard, though I still prefer my Denon 1600 via SDI overall.
Not mentioned in the thread so far is that the subtitle and angle mark bugs that plagued the 971H have been fixed for the 970HD. I've been told that these will be back-ported to the 971H in a future firmware upgrade.
When I tried the 971, the image was too soft for me. However, I did like the colors and filmlike look...does the 970 have the same colors and filmlike appearance too?
DavidHir is online now
post #99 of 6318 Old 05-31-2006, 10:42 AM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3035
WOW!
Hats-off to Larry, Paul, Josh, Neuro, and the other testers that threw up a wall of silence regarding the 970.
Very impressive keeping it all quiet, guys.
oink is offline
post #100 of 6318 Old 05-31-2006, 10:44 AM
MikeSRC's Avatar
For those using URC PC-programmable remotes (MX-700 and up), I've attached an MXF file with the 970HD commands (including discrete On/Off). This can be used with the Universal Browser to drag in any or all commands.
Oppo970HD.zip 6.1611328125k . file
Enjoy!
Mike
Surf Remote Control
MikeSRC is offline
post #101 of 6318 Old 05-31-2006, 10:52 AM
gonk's Avatar
Thanks for the remote file, Mike - the discrete on and off commands are a nice touch. I'm guessing that the 971 and 970 use the same basic code set (the black remote), but a 971 could be set to use the old "white remote" codes and allow the two players to be set up side-by-side without having the remote commands "fight." That'd make for a handy way to compare the two units' performance.
And thanks also for this. I'm going to sit tight for the moment and wait for some more user feedback before I commit to anything, but I am starting to seriously consider selling off my Yamaha and getting a 970 as my universal player...
gonk
Beta tester: BDP-83 / BDP-80
gonk is offline
post #102 of 6318 Old 05-31-2006, 10:58 AM
DAB
DAB's Avatar
Quoted: 26 Post(s)
I have gone through this treat, but haven't found these Q? Answered.
PQ- is great
Q?- how does the SACD sound? I Have a have a dedicated SACD player, however, with my living room/HT the acoustic issue really can justify a $1000+ player for just music and a $$$$ for DVD --though I would like one.
2). How is the sound Quality for Movies
DAB is offline
post #103 of 6318 Old 05-31-2006, 11:02 AM
Quoted: 81 Post(s)
Liked: 287
Paul,
One thing you should add to the "known bugs" list is that SACD is 2.0 channel Stereo only when using 480p and the HDMI output. All other resolutions do not have this error.
post #104 of 6318 Old 05-31-2006, 11:04 AM
Quoted: 81 Post(s)
Liked: 287
Unfortunately both units use the same IR codes. You can use the White Remote commands for the OPDV971H, but you have to make sure that the buttons you use do not somehow conflict with the Black Remote commands (such as Play changing the DVI modes).
post #105 of 6318 Old 05-31-2006, 11:11 AM
Dntblnk22's Avatar
I'll second Gonk here. Thanks very much for the information. I think I am going to go ahead and take the plunge on this one. I am so very pleased with my 971 for video duty that I am willing to give Oppo the benefit of the doubt on the 970 for audio. I am needing to replace my Pio 563 and this may just be the way to do it.
Thanks again.
post #106 of 6318 Old 05-31-2006, 11:12 AM
gonk's Avatar
Ah, interesting... Thanks.
gonk
gonk is offline
post #107 of 6318 Old 05-31-2006, 11:30 AM
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 56
Guys please keep this on topic. If you have questions on another player please start a new thread as it will only take this one off course.. Thank you.
Alan Gouger is offline
post #108 of 6318 Old 05-31-2006, 11:31 AM
Moderator
Moderator
Quoted: 286 Post(s)
Liked: 4030
In a discussion over in the video processor forum Stacey Spears mentioned that all players have ICP of some form. If really bad, it's tough to filter completely.
The 970HD can output to both outputs at the same time, IIRC.
larry
post #109 of 6318 Old 05-31-2006, 11:39 AM
Grayson73's Avatar
Quoted: 12 Post(s)
Thanks again.
Can't wait to hear your audio comparison between Pio 563 and 970.
How does the Pio 563 compare to your 971 for DVD-A?
Grayson73 is offline
post #110 of 6318 Old 05-31-2006, 11:39 AM
Moderator
Moderator
Quoted: 286 Post(s)
Liked: 4030
For digital output, if a player is competent, the colors will be whats encoded on the DVD and should look fine as long as your display is properly calibrated. For analog output, without taking measurements, the 970HD is no slouch especially for its price.
larry
post #111 of 6318 Old 05-31-2006, 12:17 PM
MacG's Avatar
Does the 970HD offer any bass management for the SACD/DVD-A? I don't think my receiver has bass mangagement for the analog inputs.
MacG is offline
post #112 of 6318 Old 05-31-2006, 12:19 PM
MikeSRC's Avatar
For those who have asked this question or are about to, the 970HD will only be available direct from Oppo for a few weeks. The reason is to get some direct feedback from customers before releasing the player to their resellers.
Yes, it does.
Enjoy!
Mike
Surf Remote Control
MikeSRC is offline
post #113 of 6318 Old 05-31-2006, 12:24 PM
Keenan's Avatar
Quoted: 2208 Post(s)
Liked: 1990
Pages 11,12 and 13 in the manual.
Keenan is offline
post #114 of 6318 Old 05-31-2006, 12:25 PM
Quoted: 81 Post(s)
Liked: 287
There is no "true" bass management controls on the DV970HD (this is the same as the OPDV971H).
EDIT: That is, the bass is designed to be directed to the subwoofer only when the speakers are set to "Small". When the speakers are set to "Large", all bass information is relayed to that channel and never sent to the subwoofer, even if it falls below 80Hz (OPPO's predesigned speaker cutoff).
As such, you can't set specific bass cutoffs for your speakers and subwoofer.
post #115 of 6318 Old 05-31-2006, 12:28 PM
Steve L's Avatar
Originally Posted by sspears View Post
I believe it is better than the Pio players. I still prefer the image from the RP91/82 via SDI. The Oppo is a lot faster in terms of responsivness though.
Hi Stacey,
I'd like to ask you the same question I asked Josh. Do you think the RP91/82 SDI image looks better because there's no post processing being done on the SDI output, whereas 480 over HDMI is still passing through the 970HD's image enhancement circuitry on the way out?
Or is the difference attributable to superior performance by the MEI decoder vs. the Mediatek, and any add'l processing that Oppo is doing is irrelevant? Thx.
/steve
Steve L is offline
post #116 of 6318 Old 05-31-2006, 12:30 PM
Grayson73's Avatar
Quoted: 12 Post(s)
Typically, resellers sell below MSRP. I assume that this means we'll be able to get this below MSRP once this happens.
post #117 of 6318 Old 05-31-2006, 12:33 PM
Keenan's Avatar
Liked: 1990
On the manual pages I posted above it shows some management controls, although, they appear to rather rudimentary, Large, Small or Off, with delay settings being based on the distant difference between Center and LF/RF, and if surround speakers are closer than your fronts you're out of luck there as delay cannot be set lower than the front distance.
Keenan is offline
post #118 of 6318 Old 05-31-2006, 12:35 PM
Quoted: 81 Post(s)
Liked: 287
Typically, yes. But with OPPO, no one has been below the 199 MSRP (Amazon.com always tries, but they are quickly stopped from doing so).
And if you look at the press release: "The DV-970HD is available from OPPO Digital and OPPO authorized resellers for $149.00."
post #119 of 6318 Old 05-31-2006, 12:39 PM
WaldorfSalad's Avatar
I would prefer to buy it from Amazon so as to benefit from free next day shipping (or $3.99 for next day) due to prime club membership. Plus, Amazon has a 30 day no-hassle return policy.
WaldorfSalad is offline
post #120 of 6318 Old 05-31-2006, 01:01 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Mike of Surf Audio deserves our support when you consider where to get your 970. He has made great helpful posts and is a senior member of this fourm.
rwestley is offline
Reply DVD Players (Standard Def)
