Oppo Digital DV-981HD FAQ/Brain Dump - Page 174 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #5191 of 5215 Old 03-31-2010, 12:13 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3170 Post(s)
Liked: 2453
Originally Posted by Heuristix View Post
Any opinions about the upscaling quality (regular DVDs) of DV-981HD vs the new BDP-80?
If not based on an actual comparison, what can be expected, based on the quality and specs of the chipsets etc.?
The BDP-80 looks sharper to me, although not so much as to be unnatural.
The 971/981 could enhance macroblocking, although this was mostly reported by DLP owners. The other players don't have that risk.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #5192 of 5215 Old 04-01-2010, 07:23 AM
Heuristix's Avatar
-Bill
That's good to hear; in that case I can replace the two boxes I currently have (981HD + Blu-ray player) with a single player without taking a hit on DVD quality, for much less than the cost of the BDP-83. (To my eyes the 981HD is better than my Magnavox Blu-Ray on a 100" projection screen). I am reluctant to splurge on a Blu-Ray player right now because of the 3D capable players due out soon.
Heuristix is offline
post #5193 of 5215 Old 06-11-2010, 10:09 AM
syphon00's Avatar
my 981HD seems to have trouble handling larger xvid/divx files in the 1.5-2gb range
anyone experience this?
syphon00 is offline
post #5194 of 5215 Old 06-11-2010, 11:16 AM
wmcclain's Avatar
Liked: 2453
Are they within standard def resolution? 720x480@60hz or 720x576@50hz max.
-Bill
post #5195 of 5215 Old 06-11-2010, 01:42 PM
Neuromancer's Avatar
Quoted: 95 Post(s)
Liked: 360
Make sure you have the most recent firmware installed. I believe one of the older firmwares had issues related to files being larger than 1.2GB in size. This was resolved in a firmware release.
Neuromancer is offline
post #5196 of 5215 Old 07-31-2010, 01:01 AM
blacklion's Avatar
I saw Oppo 981 units advertised as 'brand new' on Amazon. Are these actually refurbs?
Denon X4000: Yamaha AS500;TS500;CDS300: Pioneer BDP62FD;BDP23FD;DV58AV;DV610: Panasonic DMP-BDT500; Sony BDP-S790; Samsung PS60E6500
blacklion is offline
post #5197 of 5215 Old 07-31-2010, 10:11 AM
CruelInventions's Avatar
Quoted: 606 Post(s)
Liked: 745
At those current Amazon Marketplace seller prices, does it even matter?? May as well get one of the Oppo blu-ray models if you're willing to drop 3+ bills.
CruelInventions is offline
post #5198 of 5215 Old 08-30-2010, 11:01 AM
syphon00's Avatar
yeah these file are all 720x480 or less, firmware hasn't been updated by oppo since 2008, my cheap philips player from Walmart could play these just fine
syphon00 is offline
post #5199 of 5215 Old 08-30-2010, 12:56 PM
Quoted: 95 Post(s)
Liked: 360
Ensure that you are using the latest firmware. Check your Batch Number (eject the tray then press OSD. What is your Batch Number). Update as necessary.
post #5200 of 5215 Old 08-31-2010, 03:58 AM
purpleshorts's Avatar
Oppo DV 981HD (DV-981HD) won't eject. tray stuck. tray stays in. Doesn't eject. Wont eject. doesnt eject. cannot eject. cant eject. (ejectile dysfunction?)
Sorry for the bad grammar, I put it in for search engines. I found a solution, and I wanted you to, as well. I put this answer in this forum because this is where Google took me when I first searched for a solution to the eject problem.
I unplugged the Oppo for 20 minutes, then plugged it back in. I don't think this did anything, but I saw it in another thread, and since it matches my basic method of "unplug it, plug it back in," it is part of the voodoo.
Symptoms: When I pressed eject, the little LED said "OPEN" and I could hear some mechanism attempt to engage, but the tray remained in.
To me, the tray was simply stuck, and needed a pull. But how to get a grip on the flush-mount tray without hurting anything? I had two plastic laminate cards on my desk, and decided to try them. I inserted a flexible plastic card between the bottom of the tray (slides easily) and top of the tray (hard to slide) and slid them to the left of center, where the top card started to bind. I sort of squeezed the top plastic card and bottom plastic card together as close as possible to the front of the tray to get a good grip on the tray itself. I pressed eject, and pulled.
It worked. The stuck tray slid out, powered by motors, and now goes in and out just fine.
purpleshorts is offline
post #5201 of 5215 Old 08-31-2010, 11:38 AM
Quoted: 95 Post(s)
Liked: 360
When you press Eject, do you hear any motor noise? If no, then either the entire mechanism is bad, or the rubber band which spins the cogs, which ejects the tray, has broke.
If you hear mechanical noises, then the tray may just be stuck. Try the following:
1. Disconnect the DVD player’s power cord from the power source for no less than 15 minutes.
2. Ensure that the tray is not sticking to the front of the tray opening by running a small flat object along the entire edge of the tray.
3. Gently shake your DVD unit.
4. Reconnect the power cord.
5. Press Eject. If the tray does not Eject, make any note of any mechanical noises.
6. Press Eject and press in the tray.
7. Press Eject again.
post #5202 of 5215 Old 01-29-2011, 02:10 PM
BeauCharles's Avatar
Hello all. I finally retired my old Trinitron for a 40" LCD (run of the mill Vizio, but it was cheap!). I kicked around the idea of a Blu-Ray, but I have so many DVDs and continue to buy them in the future so I bought an Oppo DV-981HD. I did a lot of research and it seems like a good deal for what I plan to use it for. I want to set it region-free for all the imported DVDs I have. I think with my smaller HDTV screen it should look pretty good. I know Blu-Ray would be better of course, but I don't think I'll sacrifice too much (I have to sit about 8 feet away given the layout of my living room).
Oh, and I got it for $125 on eBay. Its brand new in a sealed box - still has the Oppo Fed-Ex label intact over the box opening. I'll post back later once I have it. I know this is a really old thread and there must not be any interest in the player, but I'm excited none the less!
BeauCharles is offline
post #5203 of 5215 Old 01-29-2011, 02:17 PM
blacklion's Avatar
Just to share in your excitement - I got a very gently used 981 for $115 on amazon marketplace late last year. Snapped it up within minutes of the seller posting it. I'm using it as a region free player with a 32" LCD in a bedroom and its been a great bargain I think
post #5204 of 5215 Old 12-05-2011, 09:21 AM
pwdennis's Avatar
I've had a Oppo 981HD for four years. It has been a great DVD player. Last night when I switched on our entertainment system to watch cable the Oppo powered on , started making a chunk-chunk sound, all of the panel lights came on. I went to check it out and power it down... would not power down. Disconnected the cables and pulled it from the shelf... It was hot as heck on the left by the dvd drawer -- not good. I tilted the unit left and right and can hear what sounds like a ball bearing rolling around in the bottom... must be what caused the over heating...
Farewell my fine friend!
Now a question... any Oppo fans here have a recommendation on a replacement BD player? Moderate price, network etc. that can be made all region? Thx
pwdennis is offline
post #5205 of 5215 Old 12-05-2011, 05:40 PM
moxie1617's Avatar
The problem with BD is the lack of region free at a moderate price. I'd call Oppo and see what they charge for repair of your 981. They have flat rate pricing for repairs. Keep it for region free DVD 's and anime and buy an inexpensive Blu-ray player if your interested in that format.
moxie1617 is offline
post #5206 of 5215 Old 12-05-2011, 05:48 PM
pwdennis's Avatar
Thx Moxie. I'll check it out!
I popped the top to check out the interior. The problem is a blown cap. The thing rolling around was the metal cylinder blown off the base. I also still have a DVD stuck in the tray and no way to apply power... don't want to pry it out.
Hopefully a local repair shop can replace the cap and all will be well... Here's to hoping!
pwdennis is offline
post #5207 of 5215 Old 12-06-2011, 06:45 AM
moxie1617's Avatar
Do call Oppo, it should be around $50 plus one way shipping no matter what the problem.
post #5208 of 5215 Old 01-10-2012, 12:10 PM
Rondog32837's Avatar
Quoted: 26 Post(s)
I recently resurrected my Oppo DV-981HD from the basement. I hooked it up thru HDMI to my new amp and could not get any sound or video. I could also not get into the setup menu. I can't remember how I had it hooked up to the previous amp -maybe not HDMI. How can I reset the Oppo to get access thru HDMI?
Dumb me - I had the input on the wrong HDMI. Nevermind.
Rondog
Rondog32837 is offline
post #5209 of 5215 Old 02-23-2013, 02:50 PM
deepblue's Avatar
My SDI modded 971 just died.
I bought a used 981 to replace it.
I have installed the PMS BT656 SDI Kit with the data lines tied to the same pins on the Mediatek MT1389 as had worked on the 971.
I have clock and an SDI stream, but no picture.
I applied the HDCP hack in case the picture was being blanked ... Still no picture.
Does anybody know if the 981 still produces a BT656 stream to the Genesis FLI2310 chip?
I can see that Oppo is sending the data from the MT1389 to a different port on the FLI2310 from what they used in the 971. Unfortunately I can't find documentation on the FL2310 IC to figure out what that data stream might be.
Any ideas about what's different in the 981 that might change the SDI mod?
Eric
deepblue is offline
post #5210 of 5215 Old 09-24-2014, 04:19 PM
Jeffredo's Avatar
Still using my DV-981HD regularly! Starting to wonder if I'm ever going to retire it. On a 37" TV it still performs great.
Jeffredo is offline
post #5211 of 5215 Old 03-30-2015, 09:27 AM
Anthony1uk's Avatar
Liked: 0
Can someone possibly help.
I have the Oppo 981HD. It has developed an issue where the DVD drive door wont open. But it is saying it is open on the display.
I was wanting to take the lid off to look at it. But for the life of me I cannot take the lid off.
I have took out all the screws. But it seems stuck at the front part where the display is. I am not sure what to do to get the lid off and am worried about using any type of force incase I snap something.
Is there any guides or instructions on how to do it?
Anthony1uk is offline
post #5212 of 5215 Old 03-30-2015, 11:04 AM
wmcclain's Avatar
Liked: 2453
Welcome to AVSForum.
You remove the scews in the rear, then lift the rear of the top cover up slightly and pull backwards. It should slide off.
Contact OPPO if you need help. They'll have instructions.
-Bill
post #5213 of 5215 Old 06-13-2015, 06:51 AM
JimWinVA's Avatar
Quoted: 104 Post(s)
Liked: 114
Just got a 981 to replace my dying Denon 2930- very impressed w/ the picture so far, no problems noticed on my LED DLP (Sammie HL67A750) going thru my AVR. But I got this player for sacd/dvd-a capabilities; so great to finally get sacd over hdmi and be able to utilize Audyssey. Sounds superb!
A couple questions:
1- My f/w is not up to date: batch 08-0910A. I see on Oppo's support page what the final update corrected, but would like to be able to access a list of the updates and what revisions they made, as I'd just as soon not update f/w if I don't have to (it's worked fine w/ every sacd I've played so far). Is such a list available and if so, where? I've been reading this thread and am up to p.58, where the colorspace beta f/w revision was just introduced.
2- There are some items added to the general setup page that aren't in the manual:
*ALT RC CODE: I assume this is an alternate code for the remote? I have this off, which I assume is the correct position unless there is a need for a different code (like running another Oppo)?
*OSD MODE: Stumped on what this does- what is the difference between normal and silent? I'm currently running normal.
Very happy to be an Oppo owner- wish I'd have done better homework back in '09; I'd have bought this model back then.
JimWinVA is offline
post #5214 of 5215 Old 07-29-2015, 09:17 PM
jc46's Avatar
Thumbs down dissapointed
Do not get this version. Get the DV-980 older version. There is one feature that I value more than a fancy video processor or multi-channel analog outs and is the Memory and Automatic Resume feature. I never sit through 2 hours watching a movie, and sometimes I swap out the disk. With the new version, you have to eject the disk! And it won't remember after a power off. The stop button is useless, it behaves just like Pause.
It does not save position and remember it after power off like it should.
jc46 is offline
post #5215 of 5215 Old 10-15-2015, 11:44 AM
dregan23's Avatar
I was on the fence about having my DV980 repaired--not sure that I wanted to spend $40 to fix something seven years old that was selling for $40 on ebay.
The loader stopped working, and the front panel lights had given up a few years ago.
I bit the bullet, sent it in to Oppo, and they replaced the power board, loader, and front panel. Plus the new firmware. No charge to me beyond shipping it up to them.
Great customer service, made me appreciate Oppo more than ever.
NCCaniac likes this.
dregan23 is offline
Reply DVD Players (Standard Def)
