Any Onkyo 404 user here (for 480i HDMI) ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-04-2007, 07:25 AM - Thread Starter
c722's Avatar
hi I couldn't find much info abt this player. Is there anyone here using it as a 480i transport ? I'm most keen to know if it has Y/C delay and any pixel cropping in 480i HDMI, and if its menu/chapter speed is fast.
Thanks for your help !
c722 is offline
post #2 of 6 Old 01-10-2007, 01:59 PM
TXST8tj's Avatar
Quoted: 14 Post(s)
BTT.......i am looking into this player (DVSP404) myself. the reviews i've read of it so far have all be great. i'm a fan of onkyo and and the $130 price tag. would be looking to take advantage of the 720p/1080i upconversion via HDMI on my Sony KDF-50E2000.
does anyone have any input on this unit?
TXST8tj is offline
post #3 of 6 Old 01-20-2007, 09:12 AM
jaxxx123's Avatar
any1?
jaxxx123 is offline
post #4 of 6 Old 01-20-2007, 12:45 PM
lsarver's Avatar
Reviews? Where? (Links?) I've found very little so far.
Btw, there's another thread here on the same topic. Perhaps a mod should combine them?
lsarver is offline
post #5 of 6 Old 01-21-2007, 05:24 PM
Nvancitters's Avatar
I have had the 404 for about a week. I am using it in 720p mode and the PQ has been good. Up there with the best of the other upconverting players I have viewed. I demoed the unit side by side with my old Onkyo dvd player and could definitely see the difference.
I have not done anything in the 480i setting as my TV does not like it, so I can't say there. It is a little slow on power up and reading, but I don't think any more than other comparable units. The 404 is pretty small and light. While it doesn't have a lot of "heft", the quality of the electronics is still there.
My only major complaint is with the audio functions. As was noted in the attached post, you need to turn off the audio over HDMI to get Dolby Digital 5.1 out of the coaxial digital output. (Note this unit is also lacking an optical digital output.) As I don't run my AV receiver all the time, this requires going into the menu functions when I do. The other option appears to be to run an additional stereo audio cable to the TV. This is tough for me as the run is long and through the wall with limited room. I also put in the HDMI to have 1 cable that will do it all. I heard other players, such as Oppo, have all the outputs "hot", so I don't know why Onkyo chose to do it this way. As a result, I reluctantly may go another way.
Nvancitters is offline
post #6 of 6 Old 03-09-2007, 03:29 AM
plazma's Avatar
Thanks for this info Nvancitters!! You inspired me to make my first post. This audio issue with the DVSP404 is what i needed to hear to make my decision to go with one of the Oppos. I've been up in the air for a while on the onkyo.
For those not bothered by the audio switching issue with the onkyo, shoponkyo,com now has refurb'd DVSP404 for $84.
plazma is offline
Reply DVD Players (Standard Def)
