Raw vs PCM? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-19-2007, 06:48 AM - Thread Starter
btran33's Avatar
Quoted: 51 Post(s)
Hi All:
I just got the OPPO 971HD and don't know what to set for the audio in the audio setting. Should I use Raw or PCM to send the audio signal to my Marantz SR8200 receiver vs the optical cable? My old Sony DVD player doesn't have "RAW" setting only PCM. Thanks for all the help!
bt
btran33 is online now
post #2 of 3 Old 03-19-2007, 07:46 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2684 Post(s)
Liked: 1920
Originally Posted by btran33 View Post
Hi All:
bt
Try the 971 thread: http://www.avsforum.com/avs-vb/showthread.php?t=491306
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #3 of 3 Old 03-19-2007, 07:55 AM
gonk's Avatar
The 971H's "raw" setting is equivalent to the "bitstream" setting on other players. If you are connecting to a surround receiver, you want to leave this set to the default of "raw" - that tells the player to pass the Dolby Digital and DTS bitstreams on to the receiver for decoding.
gonk
Beta tester: BDP-83 / BDP-80
gonk is offline
Reply DVD Players (Standard Def)
