Can I connect DVD player to LCD monitor? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-27-2007, 12:37 PM - Thread Starter
TomX's Avatar
I don't think you can connect a regular DVD player to a LCD monitor (not LCD TV, but the one you use with your PC). Is there any special DVD player can do that? I don't watch TV, just DVD movies. So if there is an such special DVD player, I'll be interested in it.
Tom
TomX is offline
post #2 of 11 Old 04-27-2007, 02:30 PM
UWisconsin97's Avatar
What inputs do you have? Because I have HDMI inputs on my 23" monitor...
UWisconsin97 is offline
post #3 of 11 Old 04-27-2007, 03:16 PM - Thread Starter
TomX's Avatar
Mine is Dell 1907FP. I don't think it has HDMI, but it has DVI. Does it help?
TomX is offline
post #4 of 11 Old 04-27-2007, 03:25 PM
Tulpa's Avatar
Liked: 61
You can get a DVI/HDMI cable if the DVD player outputs using HDMI. I'm not 100% certain it will work, as I'm not as familiar with LCD monitors, but I don't offhand know a reason why it wouldn't. You would have to have an A/V receiver or some such to handle the audio, though.
There is a special DVD player that can be used with a computer monitor. It's called a computer with a DVD drive. (But I'm assuming you don't have one available, hence the question.)
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #5 of 11 Old 04-27-2007, 03:28 PM
louthewiz's Avatar
You must be sure that the monitor is hdcp compliant to display any picture if you are going to use a dvi to hdmi adaptor,
if not then you will need a transcoder.
louthewiz is offline
post #6 of 11 Old 04-27-2007, 03:51 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2697 Post(s)
Liked: 1923
Tom
I've done it with the Oppo 971, which has DVI without HDCP. The aspect ratio wasn't quite right,as my monitor, a little Viewsonic, doesn't expect 4:3 or 16:9 images.
There is a patch for disabling HDCP on the Oppo 970 and 981 HDMI: http://www.avsforum.com/avs-vb/showthread.php?t=832356
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #7 of 11 Old 04-28-2007, 05:08 AM
dr0s's Avatar
Yes, there are several - many of the Chinese brands (Kingwell, Neodigits,...) have VGA out. - DR
dr0s is offline
post #8 of 11 Old 04-30-2007, 12:49 PM
wile666's Avatar
I have a Sony DVPNC85H/B 5-Disc HDMI DVD/SA-CD/CD Progressive Scan Changer and wanted to use my 19" flat panel monitor with DVI to watch movies. I tried the HDMI to DVI cable but it wouldn't work. I found out that the monitor was not HDCP compatible. I just bought a Sceptre X20WC Gamer which does have HDCP and still cannot get a picture on the screen. They just won't recognize each other.
I've just ordered the optional DVI to component RCA cable from Sceptre and am hoping it works.
wile666 is offline
post #9 of 11 Old 04-30-2007, 01:01 PM
rbmcgee's Avatar
Don't you folks already have a PC hooked up to these monitors? Why would you want to hook up a DVD STB as well?
Bob
rbmcgee is offline
post #10 of 11 Old 04-30-2007, 01:53 PM
wmcclain's Avatar
Liked: 1923
Inquiring minds want to know if it works, and how well.
I used it for early experiments in scaling and progressive scan, and to convince myself that I would be happy with the LCD "look" as compared with my little CRT TV.
-Bill
post #11 of 11 Old 04-30-2007, 02:02 PM
louthewiz's Avatar
That cable will not work ,you need a transcoder for that...
Reply DVD Players (Standard Def)
