Pioneer DV-400V Owners Thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
post #811 of 1139 Old 03-19-2008, 12:06 PM
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
Originally Posted by Jim_Bassett View Post
Hi folks,
Just picked one of these up, and so far I'm liking what I see. Just wondering if anyone knows how to have the front panel display "time remaining" rather than "time elapsed". I know I can see the remaining time by using the "Display" button, but the OSD stays on, so not optimal
Mainly just a convenience thing that I've gotten used to from my "old" Panny RP-62.
Jim
it wont
aasoror is offline
post #812 of 1139 Old 03-19-2008, 12:11 PM
Jim_Bassett's Avatar
Originally Posted by aasoror View Post
it wont
Sigh, I was afraid that was the answer. Not a huge issue.
Thanks for the reply, aasoror.
Jim_Bassett is offline
post #813 of 1139 Old 03-19-2008, 12:25 PM
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
no problem,
its good that this issue isn't bugging you much,
check post #645
for other more annoying limitations,
aasoror is offline
post #814 of 1139 Old 03-19-2008, 12:55 PM
no problem,
check post #645
Thanks. I have scanned through the thread, and did see that.
Coming from a player that had no Dvix/WMV/etc support, the issues in that post are minor to me (at this point ). And some aren't relevant to what I usually watch (I've never had a need for subtitles, for instance). But, who knows?
Anyhoo, I've only had it for ~4 days, so I'm still getting used to it.
Cheers.
post #815 of 1139 Old 03-19-2008, 05:31 PM
iatacs19's Avatar
Quoted: 229 Post(s)
Liked: 146
Originally Posted by bburtin View Post
Thanks for the fast reply! Looks very likely that my TV (Sony Bravia KDL-40V2500) is affecting the way that the content is being displayed. The Bravia does have options for rendering 4:3 content, but strangely enough, these options are only enabled when the DVD player sends 480p. In 1080p, it will only zoom or stretch.
So here's where I stand now. When the Pioneer sends 480p:
* 4:3 DVD's display at the correct aspect ratio
* 16:9 DVD's display at the correct aspect ratio
* 16:9 AVI's display as 4:3 (go figure)
When the pioneer sends 1080p:
* 4:3 DVD's are stretched
* 16:9 AVI's display at the correct aspect ratio
So it looks like there's no "set it and forget it" option. From what I can tell, I have to switch to 480p when watching 4:3 content. A little annoying, but I can live with it. Is there another Bravia owner out there that has a better solution?
Choose "16:9 compressed" and it will display 480i/p content correctly.
XBR65X930C, AVR-X4200W, NVIDIA ShieldTV, SVS SB12-NSD, RF-42 II, RC-52 II, RB-41 II
iatacs19 is offline
post #816 of 1139 Old 03-20-2008, 12:09 AM
kmil's Avatar
I have the Pioneer 400V and will be getting 50 inch panny tv with 720P. If I set the DVD to 720P I gather my dvds will play 16:9 widescreen and 4:3 (square in middle)for regular SD broadcasts correct?
kmil is offline
post #817 of 1139 Old 03-21-2008, 07:15 AM
iatacs19's Avatar
Quoted: 229 Post(s)
Liked: 146
I haven't tested 720p, what I said applies to 1080p output.
iatacs19 is offline
post #818 of 1139 Old 03-21-2008, 01:05 PM
kmil's Avatar
Hey "iatacs 19":
Could I trouble you to test that for us? Would sure appreciate it and thanks for temporarily inconveniencing yourself for us.
kmil is offline
post #819 of 1139 Old 03-22-2008, 12:12 PM
Jackanory's Avatar
I have the 50pc77u and so far have found that 480i output allows the pannys scalar to do a great job with both DVDs and with all resolutions of AVIs. I'd be interested to hear your experiences.
Jackanory is offline
post #820 of 1139 Old 03-22-2008, 12:36 PM
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
Sorry for my post not being so informative, but I wonder if 480i is satisfactory (not even 480p) and leaving the upscaling to the TV set, why one should bother with upscaling and HDMI players?, you can get region-free 480p avi/dvd players for as low as $23 these days.
aasoror is offline
post #821 of 1139 Old 03-23-2008, 06:42 PM
badmeng's Avatar
I was able to flash the Hakan firmware to make the player region free (thanks for the help everyone), question, is anyone's player noisy? When I play a DVD movie I can clearly hear the player especially during quiet scenes of a movie (at 8 feet away). Does anyone else have this problem? Should I try another pioneer? Also is it best to use 480i over hdmi for a Panny Plasma?
Samsung 60F8500 Plasma
Samsung 51F300B Plasma
Panasonic 42PX80 Plasma
badmeng is offline
post #822 of 1139 Old 03-24-2008, 11:49 AM
splinter1's Avatar
Nooobie here.
Looking to pick the dv-400v up to go with my soon to be purchased HDTV. I will want to run HDMI to the TV and then run digital audio from the player to my receiver for surround sound(receiver doesnt have HDMI).
I thought i had read somewhere in this thread that people had problems with this because the player would read the HDMI connection and then disable the digital audio out to the receiver.
There must be some type of workaround for this or do i have it all wrong??
splinter1 is offline
post #823 of 1139 Old 03-25-2008, 12:46 PM
orin04's Avatar
hello all. reviews seem to be good for this player. but i was wondering if it would make a big difference for me to get a upconverting dvd player. i have a faroudja chip inside my monitor. its a gateway hd2200. and dont know if thats better than whats in most of these players
orin04 is offline
post #824 of 1139 Old 03-25-2008, 05:12 PM
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
at 22" the Faroudja would do so fine, I recommend to get the player from a store with a good return policy though.
aasoror is offline
post #825 of 1139 Old 03-25-2008, 06:12 PM
Mr. Miami's Avatar
Originally Posted by M4P View Post
I have the Harmony 670 and just got a Pioneer DV-400V DVD player. With the DVD player's remote, when you press Display, the display comes up on screen. Push it a second time, and you get a screen that shows more info about the DVD such as bitrate. Push it a third time, and the Display screen closes.
I programmed my Harmony 670 for the Pioneer DVD player. However, when I push Display on the Harmony, the Display screen comes up. But, when I push the Display button on the Harmony a second time, nothing happens. I can push it several times and the Display screen will never go to the Display screen with the more DVD info, nor will it close the Display screen.
I tried doing an IR learning for the display button on the Harmony, but it sill won't work properly.
Has anyone who has this player and a Harmony remote got this to work properly?
I have the same remote. I just made the remote learn the "Display" function in "raw mode", and then it worked as it should..
Mr. Miami is offline
post #826 of 1139 Old 03-25-2008, 09:08 PM
badmeng's Avatar
Guys - should I pickup and try another Pioneer player? Is anyone's noisy during playback? My ps3 is quieter.
badmeng is offline
post #827 of 1139 Old 03-26-2008, 07:52 AM
houseofmouse's Avatar
I am planning on buying the DV400 as a budget stop gap until blu ray machines drop. i am in no hurry to spend $400+ on a dvd machine.
Just wondering how pleased DV400 owners are with their machines. Of course i can't be too picky over an $80 machine.
Reason i want pioneer is that my receiver is Pioneer and i can eliminate 1 remote by staying with the same brand.
By the way, my display device is a Sanyo Z2000 1080p PJ on a 98" DIY screen.
houseofmouse is offline
post #828 of 1139 Old 03-26-2008, 11:05 AM
iatacs19's Avatar
Quoted: 229 Post(s)
Liked: 146
Yes, it uses a noisy motor. I can really tell when it's changing chapters or going to menu, but not noticeable so much during regular playback.
iatacs19 is offline
post #829 of 1139 Old 03-26-2008, 07:48 PM
callous's Avatar
the noise will change depending on the media you put in. I found for this player for dvd+r some brands made the player noiser than other media brands - this might be because the reader has problems reading from some media.
callous is offline
post #830 of 1139 Old 03-26-2008, 08:58 PM
badmeng's Avatar
I bought another Pioneer from BB (they have a great price on this item on-line) and compared the two units. This one is much quieter on playing DVD movies.
badmeng is offline
post #831 of 1139 Old 03-27-2008, 02:42 AM
substance001's Avatar
hey all
1st post and i have a quick and easy question about this dvd player.
whats the maximum xvid resolution that it will support?
ive tried to google the question but cant find anything specific..
thanks all!
substance001 is offline
post #832 of 1139 Old 03-27-2008, 02:58 AM
Hkan's Avatar
Hi
It supports up to 720x576 (PAL) /720x480 (NTSC).
PioneerFAQ
@Twitter
Has "everything" for your Pioneer!
!!We need your support!!
Hkan is offline
post #833 of 1139 Old 03-27-2008, 03:04 AM
Originally Posted by Hkan View Post
Hi
cool thanks for the quick reply!
actually 1 more..
1. is the a firmware upgrade available that changes or fixes up the interface? as your aware you can only see like 13 characters of each xvid file and thats a bit crappy.
thanks again.
post #834 of 1139 Old 03-27-2008, 11:58 AM
ppoikk's Avatar
Thanks to Hakan and crew for the firmware update. I just found this today and installed v2.0, so now I can play Region 2 discs with PAL conversion!
One issue with the install, though: the first time I put in a PAL disc, the front panel of the DV-400V read "576P" as the output mode, and I lost signal on my TV through HDMI ("Unsupported video format"). Apparently, one of the default settings after the update made it think I had a PAL TV and sent out native signal format.
I hooked up through only the yellow component out and saw that it was in fact generating video. Moreover, the logo screen read "Pioneer PAL". If I put in an NTSC disc it would change "modes" and read "Pioneer NTSC", and then back to "PAL" after swapping back. After trying different settings on the TV and DVD player, I walked away for a while to get actual work done.
When I came back, I decided to mess with some NTSC discs for a bit, trying different output resolutions. Unplugged the player to rewire cabling, then more messing around. Finally walked away once more, then came back and tried the PAL discs again... and it worked!
I wonder if the complete power-down might have something to do with it, but I see now that my video output settings would up on "16:9 Compressed" and "NTSC Video". I *think* it might have originally defaulted to "480p" and "Multisync", which I suppose would've given the player the option to output any format it wanted, including the native PAL 576P. (Makes sense, in hindsight!)
At any rate, I just wanted to say "thanks", and to record this experience for anyone that might follow with similar problems. Great unit, great firmware hack!
ppoikk is offline
post #835 of 1139 Old 03-27-2008, 01:01 PM
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
- m
From the firmware readme.txt :
- TV-Type NTSC, PAL or Multi, [restart your player to accept the new settings]
so I guess that might be what you were missing (which was triggered by unplugging the player eventually)
aasoror is offline
post #836 of 1139 Old 03-27-2008, 03:15 PM
ppoikk's Avatar
Actually, I did restart it: was necessary, in fact, to get the region-free feature working. Or maybe the "hold down Enter until unit shuts off" method isn't a full restart? However, I also restarted a few times after that to find out that the logo screen changed depending on which region/format disc was in at the time.
Likely I just left it on Multi on the initial restart, then only later I'd managed to switch it to NTSC before powering down for the rewiring. Hard to track all the changes I did after the fact from memory, so unfortunately I can't give a recipe to reliably reproduce what I saw.
Whatever the case, it's certainly a good thing to repeat for others that might have similar difficulties.
ppoikk is offline
post #837 of 1139 Old 03-27-2008, 03:35 PM
M4P
M4P's Avatar
Thanks, Mr. Miami. That's what I ended up doing with my Harmony 670. For some reason the first time I did it, it didn't work too well. So I removed the DV400 as a device, and then re-added it, did the learning in raw mode and now it works fine
Help Wiki for LG BD570: http://www.dexid.org/wiki/LG_BD570 (thanks Dave_Nedde & thx1138)
LG Executive Services 877-543-8325
M4P is offline
post #838 of 1139 Old 03-29-2008, 10:15 AM
moranhoresh's Avatar
Can I use the component video output and the hdmi as an audio output simultaneously on the dv-400?
(my TV doesn't have HDMI input, and I want to enjoy the sound through HDMI on my a/v receiver)
moranhoresh is offline
post #839 of 1139 Old 03-29-2008, 12:19 PM
iatacs19's Avatar
Quoted: 229 Post(s)
Liked: 146
Just tested this, it works perfectly.
iatacs19 is offline
post #840 of 1139 Old 03-29-2008, 02:02 PM
70Strat's Avatar
I saw the post on pg 1 regarding clock drift. Wondering if that's my problem or?... I have a new Toshiba Regza 1080p LCD.
When playing back 1080p from the Pioneer DV-400 the video goes scrambled right away. 1080i plays fine until after 30-45 min into the movie there are horizontal lines along the bottom that grow, and after some more minutes it will almost show a split screen effect. Have tried two diff. HDMI cables - same. The TV works fine using other 1080i/1080p inputs.
Questions
- is this the clock drift issue and if so are there any work-arounds?
- is my DVD player bad?
Mark
Acceptable HDMI formats as per Toshiba manual:
...............V. Freq.............H. Freq..................Pixel Clock Preq
1080i......59.94/60Hz.......33.716/33.75kHz......74.176/74.25MHz
1080p.....23.976/24Hz......26.973/27.0kHz.......74.176/74.25MHz
1080p.....59.94/60Hz........67.433/67.50kHz.....148.352/148.50MHz
70Strat is offline
Reply DVD Players (Standard Def)
