I purchased a DV-400V from Best Buy yesterday. I was shopping for a DVD player that featured USB flash drive support and was capable of playing AVI files encoded with the Xvid codec. Based upon that criteria, the DV-400V was an excellent fit.
I tested AVI playback using DVD+R DL media and a 16GB Corsair Flash Voyager USB 2.0 drive. So far it has played every AVI file that I have thrown at it, including those using external subtitle files.
Interestingly enough, although Pioneer makes no mention of this in their specifications, I was able to successfully play a multi-region PAL DVD. The DV-400V itself is region locked.
One quirk that I discovered is that my unit appears to suffer from video clock jitter. When connected to my Samsung SPN4235X/XAA EDTV plasma and set to 1080i output, the horizontal and vertical sync signals fluctuate sufficiently to cause a band of distortion along the right side of the display. The Samsung reported frequencies alternating between 33.76 kHz H / 60.08 Hz V and 33.84 kHz H / 60.22 Hz V.
My Westinghouse LVM-42W2 HDTV LCD did not appear to be affected by the clock jitter and was able to display all signals, including 1080p, without distortion.
