DVD output to widescreen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-29-2007, 12:03 PM - Thread Starter
randycandy's Avatar
I am sorry but I can't find an answer to this... I have a Sony progressive scan DVD player and a Sony (34 XBR 970) HDTV (480i/p, 720i/p, 1080i). In the menu for my DVD player you can select the TV output type. 4:3 letterbox, 4:3 pan-scan or 16:9. My TV is 16:9 so I selected that. Does selecting this do anything? When the movie is playing and I hit the "display" button it shows that the signal is 480p and 16:9. But what does the 16:9 do? I still have to use the "zoom" screen setting to get rid of the bars. If the screen is on "normal" there are bars on the sides. What does outputting to 16:9 mean? In my manual it looks when you are in 480i/p you can't have unstretched widescreen. I am confused because I thought I've seen Gamecube games that output put to 16:9 without stretching and it's 480i/p. I can't figure this out.
randycandy is offline
post #2 of 10 Old 04-29-2007, 12:39 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2690 Post(s)
Liked: 1921
You have to tell the DVD player the shape of your display. 16:9 is correct in your case.
Black bars: follow the links in the first posting here: http://www.avsforum.com/avs-vb/showthread.php?t=824238
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #3 of 10 Old 04-29-2007, 12:47 PM - Thread Starter
randycandy's Avatar
-Bill
I did tell my DVD player that my TV is 16:9. I don't think you have answered my questions. I still do not get it.
post #4 of 10 Old 04-29-2007, 01:05 PM
Tulpa's Avatar
Liked: 61
The bars will be there unless the DVD has an aspect ratio that matches the 16:9 that your TV is fixed at. DVDs labeled 1.78:1 (I think that's the one. Correct me if I'm wrong) for the aspect ratio will be barless, but not all DVDs will be at that aspect ratio.
If you set your DVD player to 16:9, it will allow the DVD to be displayed with minimal bars (since it is much closer to the DVD's aspect ratio than a 4:3 TV), but it may not get rid of them totally.
There is no way to get rid of the bars on DVDs with other aspect ratios except zooming (which compromises picture quality.) That's pretty much a reality you have to accept, unless you have a custom projection theater that can adjust your screen's size using curtains or something. (As for games, I'm not sure, but they may conform more uniformly to a standard ratio. You'd have to ask the gamers.)
Bottom line, you have your player set correctly. Everything you see is what everyone else with a widescreen TV is seeing.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #5 of 10 Old 04-29-2007, 01:45 PM
wmcclain's Avatar
Liked: 1921
Well, I did direct you to some links which explain black bars in exhaustive detail. Did you read those pages?
-Bill
wmcclain is offline
post #6 of 10 Old 04-29-2007, 03:31 PM - Thread Starter
randycandy's Avatar
i read the links. i am very confident that i get all of that. i get bars on the top and bottom AND on the sides. thats in "normal" mode (not stretched). i can do the zoom and get rid of all of the bars but then what is the point of having the DVD player output to 16:9? and it does seem to be working because the TV reads the signal as 480p 16:9. I don't get it. in the manual of my TV it has 480i/p modes and 720/1080 modes. I think as longs as it is 480 it will have bars on the sides even if the output is 16:9. does this sound right? does anyone have the low end sony prog. scan DVD player and 34xbr970 TV?
post #7 of 10 Old 04-29-2007, 04:13 PM
hall's Avatar
Quoted: 308 Post(s)
Liked: 154
480i, 480p, 720p, and 1080i have NOTHING to do with what you're seeing.
Your first two posts mentioned NOTHING about bars on the sides. Bars on the side does suggest something isn't configured right. Try the different modes on your TV's remote, though "normal" should be the proper one. Next, check your DVD's player's remote. They can normally zoom too. In addition to zooming "in", i.e. making the picture bigger, some will zoom "out" too, which will introduce bars on ALL sides.
hall is offline
post #8 of 10 Old 04-29-2007, 07:43 PM - Thread Starter
randycandy's Avatar
my first post actually does mention bars on the side!
either way i have figured it out. when the TV is in normal mode it does have the bars on the side BUT it is a scrunched picture (it's hard to tell but that one link with the lebowski and the bowling ball was the test i needed). the TV automatically goes to Full (which is right) but i thought it was doing that for some other reason. either way... YAY!
post #9 of 10 Old 04-30-2007, 12:03 AM
cavu's Avatar
Besides setting the DVD player to 16:9, you have to set the TV's "Screen Mode" to "FULL" as outlined on page 31 of the user manual!
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #10 of 10 Old 04-30-2007, 09:46 PM - Thread Starter
randycandy's Avatar
i already figured it out. and it's not upconverted! it's 480p which is on pg. 30.
Reply DVD Players (Standard Def)
