LG DN191H Intermittent Switch Off - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-05-2007, 10:16 AM - Thread Starter
sriv's Avatar
Hi All,
I have an issue with LG DN191H. While playing the dvd, it is switched off and on Its happening a lot of times. It used to work good for couple of days before. It started happening from yesterday.
Did anyone else faced similar issue with this DVD player? Please do reply.
sriv is offline
post #2 of 4 Old 05-05-2007, 11:35 AM - Thread Starter
sriv's Avatar
I called up LG customer service to find out what options i have. They said it costs 69$ for labor. I bought this new one for 70$ after 30$ rebate.
I honestly recommend NOT to buy LG DN191H though its 30 bucks cheap. The lifetime of this dvd player is just 5 months.
sriv is offline
post #3 of 4 Old 05-05-2007, 06:32 PM
Huey's Avatar
Try taking the cover off and take it out of your AV rack (if applicable) as it may be overheating. Add a quiet 80 mm 12v PC fan using a 12v AC/DC wallwart and see if it fixes your problem.
Huey ;-]
Huey is offline
post #4 of 4 Old 05-07-2007, 08:08 AM - Thread Starter
sriv's Avatar
Thank you Huey,
I will give it a try and let you know.
sriv is offline
Reply DVD Players (Standard Def)
