OPPO Digital Presents: DV-980H (1080p, SACD DSD, 7.1 Surround, USB 2.0) - Page 213 - AVS Forum
 3Likes
Old 02-15-2014, 11:38 AM
scorpio333's Avatar
I've had this player for quite a few yrs now. Never had any issues until the other day. My daughter likes to leaves dvd's in it and on. I heard a faint rotational noise and it was the Oppo. Turned it off and didn't think much of it. Now today she's having a fit because Baby Einstein won't load. It spins and squeaks for a few mins then "Unknown disc" appears on screen. Tried a few different discs, same result.
My assumption is something inside needs a little cleaning or light machine oil. Any guesses? I know I could replace it with a $100 BD player, but I'd like to get some more miles out of it if possible.
scorpio333 is offline
Old 02-15-2014, 01:39 PM
Saturn94's Avatar
Quoted: 87 Post(s)
Liked: 393
I don't know about fixing it yourself, but I've read Oppo will fix their players at a very reasonable flat rate.
Do you strictly use it as a DVD player? If so, I'd be tempted just to replace it.
Saturn94 is online now
Old 02-15-2014, 03:07 PM
blairy's Avatar
Have you tried unplugging it and leaving it for a few hours? No promises but that has worked for me in the past with this player and the BDP-93 when this sort of thing happens.
Good luck
blairy
blairy is offline
Old 02-16-2014, 10:11 AM
scorpio333's Avatar
Considering it's age and what a new player would cost, it's either I fix it or it gets recycled.
Good luck
blairy
Going to try that. If that doesn't help, I'm opening her up.
Old 02-16-2014, 10:24 AM
Saturn94's Avatar
Quoted: 87 Post(s)
Liked: 393
It certainly won't hurt at this point to open it up and see what you can do. Maybe shoot Oppo an email for tips on what to try?
Do you use it's SACD/DVD Audio features? Mine is primarily used for playing SACD/DVD Audio.
Old 02-17-2014, 11:02 AM
scorpio333's Avatar
AppleMark
Opened it up and I was amazed at the simplicity. I did send Oppo an email, but I don't expect much in the way of advice. Pretty rare to have a manufacturer suggesting to remove cover and start poking around, but we'll see.
So here's what happens. Power it on and insert a disc. The disc does NOT spin. My best guess is the motor here is the issue. The part in question is straight up from dead center in the second pic, right above the laser. It sometimes gives a little jerk like it wants to spins, then stops and the squeal starts. All parts seem to move freely, I don't see any dried up grease. I'll have to research that motor a bit.
Old 02-17-2014, 11:38 AM
Saturn94's Avatar
Quoted: 87 Post(s)
Liked: 393
AppleMark
Thanks for the updates and pics. I wonder how much it would cost to replace the drive? Perhaps Oppo could send you a drive?
Old 02-17-2014, 12:40 PM
scorpio333's Avatar
I forgot to answer the use question…it's 99% used as a DVD drive for my 2 3/4 old daughter. She knows how to put discs in, take them out, put them away, etc. She, nor my wife doesn't know about turning it off when not in use. I'm an analog man nowadays so I listen to mostly vinyl at home. While some people are trying to get albums onto to CD, I'm trying to CD onto albums!
I unmounted the motor and sprayed some deoxit down in there. Let it simmer a bit and remounted it. It didn't want to spin when I put a disc in so I helped it along and it spun right up to speed. Let a disc play for a bit. Stop it, open, close, spins right up.
Now back to playing Baby Einstein and Disney discs.
Smarty-pants likes this.
Old 02-17-2014, 12:49 PM
Saturn94's Avatar
Quoted: 87 Post(s)
Liked: 393
Sweet!
Sounds like maybe dust or gunk built up in the spindle motor. Glad to hear it was an easy fix. smile.gif
I'll have to remember this should I ever run into the same problem.
Old 09-08-2014, 02:47 PM
drlopezmdfacp's Avatar
Originally Posted by bhrvatin View Post
<div class="quote-container"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>bhrvatin</strong> <a href="/forum/post/13447405"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif" style=""></a><br><br>
Update: I don't think the Oppo is the problem. I did some further listening tests today between the HDMI multichannel PCM and the analog outputs. I used a disc that was SACD 5.0 multichannel. The Oppo is definitely reading the multichannel layer. So for some reason, the Anthem is not acknowledging the center/surround tracks. (When I tested yesterday, I was using a 5.0 disc that had a weak center channel mix and that's why I thought the Oppo was playing the SACD stereo layer.)<br><br>
BTW, I listened to some 5.1 SACDs after I discovered that the Oppo is working as expected. I A/B'd the Oppo multichannel analog vs HDMI output. I was surprised that I could not distinguish a difference between the two outputs. I think this demonstrates the quality of the analog outputs on the Oppo, as well as the A/D and DSP sections of the Anthem D2.</div>
</div>
<br>
I spoke with both Anthem and Oppo tech support today. Anthem said they have heard of the HDMI hi-res multichannel problem between the D2 and the 980H and that Oppo has a firmware update to resolve the issue.<br><br>
When I spoke with Oppo, although they confirmed the error is in the 980H and that they had seen issues with DVD-A, they had not verified the problem with 3.0, 4.0 and 5.0 channel SACDs and asked me which discs I tried so that they could have their firmware engineers test with them. There is no firmware update currently available to resolve the D2/980H issue and it sounded like an update was not going to be ready in the immediate future.<br><br>
Bart
was this resolved? Any way to fix?
drlopezmdfacp is offline
Old 10-05-2014, 05:57 PM
clemdog's Avatar
I'm thinking of picking up one of these players used for a SACD and DVD-Audio player. Does it play these formats back thru HDMI or do you need to hook up analog cables?
Thanks in advance for any info.
clemdog is offline
Old 10-05-2014, 06:35 PM
Saturn94's Avatar
Quoted: 87 Post(s)
Liked: 393
I'm pretty sure it does play through HDMI without having to use the analog connections. The owners manual shows connecting via HDMI only when using a HDMI equipped AVR.
Mine is connected via analog since my pre/pro lacks HDMI.
Old 10-05-2014, 07:13 PM
Digiti's Avatar
Both analog connection and HDMI will work for SACD playback on the 980H
mhobart likes this.
Digiti is offline
Old 10-06-2014, 08:42 AM
clemdog's Avatar
Thanks folks!
clemdog is offline
Old 10-07-2014, 12:21 PM
rtart's Avatar
Yep, HDMI and/or analog.
I've had one for many years, and never had a hiccup. I use it mostly for SACD and DVD-A playback. It's a screaming deal, since you can usually find one for less than $100 on eBay. Make sure to set it up for 1080i or better playback, though to make sure you get the full audio resolution for hirez disc formats. I forget why, but its necessary. I'm sure the reason is here in the thread somewhere.
I'm finding that I'm smarter than I thought, but dumber than I need to be.
PSN ID: rtart, alt Ginsuyou2
rtart is offline
Old 10-07-2014, 06:27 PM
Saturn94's Avatar
Quoted: 87 Post(s)
Liked: 393
Good catch on the 1080i or better thing. You're right (it's mentioned in the manual). I had forgotten about that.
I also use mine primarily for SACD and DVD Audio, and you're right, it is a great deal!
Old 11-17-2014, 08:42 AM
skads_187's Avatar
Quoted: 39 Post(s)
i currently have the oppo connected to my receiver via hdmi, watch mostly movies with it.
When I play audio cd's I usually play in surround.
however, if I want to play in stereo, is using the hdmi cable the best option? and switch my receiver to stereo mode?
is there a better way to play stereo for audio cds using the oppo?
thanks
skads_187 is offline
Old 11-17-2014, 09:26 AM
Saturn94's Avatar
Quoted: 87 Post(s)
Liked: 393
thanks
Good question. I use the analog outputs since my older pre pro lacks HDMI.
Old 11-17-2014, 09:48 AM
skads_187's Avatar
Quoted: 39 Post(s)
yeah, this is what im wondering, what will sound better hdmi or analog output?
Old 11-17-2014, 11:25 AM
Saturn94's Avatar
Quoted: 87 Post(s)
Liked: 393
I guess just try it and see if you can hear a difference.
The analog outputs sound great to me.
skads_187 likes this.
Old 11-17-2014, 11:37 AM
skads_187's Avatar
Quoted: 39 Post(s)
yup will do, once the room is complete and I hook up all my equipment, unfortunately, that can be awhile.
Old 12-20-2014, 01:13 AM
Tomdabomb9's Avatar
Just picked up one of these bad boys off ebay. I'm connecting it to a Music Fidelity V-Dac II via coaxial cable. The V-Dac is connected to a stereo receiver. Can anyone tell me the best settings to use? I just want pure audio output. No changes made or anything.
Also, I noticed when reading the manual there's an 'audio-only mode' button on the remote. Unfortunately the remote didn't come with my DVD player. Is there a way to turn on this mode w/o the remote or would I need a remote to do it?
Thanks in advance!
P.S. If any of this has been covered already I apologize, but this is a very long thread! A quick search also didn't come up with anything. If someone could point me in the right direction that would be lovely
Tomdabomb9 is offline
Old 12-21-2014, 08:12 AM
rtart's Avatar
At the expense of being a smarta**, the Audio Setup section of the manual should shed some light on your questions. Pages 23 and 24 to be specific, talks about connection via Coax. Also, here's a link to the Support page for the 980: http://www.oppodigital.com/dv980h/dv980h_support.aspx, which has a lot of useful info.
I found it to be very helpful when setting up my 980, and certainly can answer your questions easier than searching this entire thread.
BTW, pretty much any universal remote will support the 980H. Harmony in particular does a great job.
I'd also check out the manual for the Dac, since you weren't specific about how it is connected to the audio signal chain.
Good luck! You'll love the 980H...I've certainly enjoyed mine through the years.
rtart is offline
Old 12-21-2014, 08:48 AM
Saturn94's Avatar
Quoted: 87 Post(s)
Liked: 393
Thanks in advance!
Perhaps it's possible to buy a 980h remote from Oppo?
BTW, If anyone is interested, I might be selling my 980h now that I have a 103.
Old 12-21-2014, 02:32 PM
grantb3's Avatar
If you scroll back a couple of pages you will see that I got a new remote from them last year for peanuts!
GB
grantb3 is offline
Old 12-24-2014, 11:07 AM
Tomdabomb9's Avatar
Thanks for the responses guys. I used the manual in the original setup, still there were some things that weren't clear. I'll check out the support site. I have since done some switching between the V-DAC connected via coaxial and the Oppo connected via RCA. I was really surprised I could barely tell the difference. So barely in fact that I'm not sure the small difference I heard wasn't in my own head. Perhaps most surprising is that I actually preferred the Oppo! Slightly clearer and more open. I'm currently listening to the Oppo directly connected to the receiver and using the V-DAC for computer listening.
Old 12-31-2014, 07:42 PM
Liked: 0
Somewhere in this thread, they discuss listening to a cd through hdmi, only 2 icons show up on the avr. If you have the avr set for auto it plays through all speakers. This is what mine does so I listen to a cd through the digital for stereo only and hdmi for everything else. Best $65 I ever spent.
Icerider62 is offline
Old 01-04-2015, 12:53 AM
Mkard's Avatar
Icerider62 and Tomdabomb9,
I am still enjoying mine after almost 8 years. Very capable unit. Though the humblest of offerings from OPPO, this unit can stand tall next to the current generation of wonder-boxes. I know I've learned a lot from AVS on this and other threads. You will find some good stuff here. Try the 980's R/L analog outs for your Stereo listening, pure direct thru your amps.
Originally hooked up to a non-HDMI Yamaha AVR, using analog audio, optical out and HDMI to display. Player could be set to deliver LPCM or Bitstream to Yamaha in just the right way (I've forgotten) to get the absolute most out of my then very modest system for audio performance movies and music. The analog performance was un-equalled until I had spent over 2X $. THEN I discovered that this is the only player for user-generated MLP lossless rips from both CD and USB. Outstanding!
Still a great player. Still in my stack adjacent to a BD-95. Still used to spin disks or deliver USB files for casual music to my main sound system. Even gets the odd few hours playing imported Chinese DVDs for my wife when she wants to luxuriate in Mom's Theater whilst catching up on soap-operas in a language I don't understand.
An AVS member said on another thread: ' I'll not be separated from my OPPO until one of us dies '. I can identify with that sentiment when it comes to the DV-980h.
Mike
mhobart likes this.
Mkard is offline
Old 01-04-2015, 01:21 AM
Mkard's Avatar
Tom,
When you set up Audio Only on OPPO, the 980's DAC's to output direct analog via R/L and output to the dedicated inputs of your receiver to purely amplify= NICE. Today's DACs are better, but OPPO executed old '980 VERY WELL.
I agree with the earlier suggestion that you send an inquiry to OPPO. Or, call them. They likely have a way to get a replacement remote to you, which will ease a lot of things for an only small amount of coin.
btw: the "Audio Only" selection is very likely to yield a discernable result when listening critically on a competently amplified setup. There is a way to set it via push buttons on face of unit I think, but you will have to redo that multi-step process regardless every time you power on. Get the remote. Please enjoy your OPPO.
Mike
Mkard is offline
