OPPO Digital Presents: DV-980H (1080p, SACD DSD, 7.1 Surround, USB 2.0) - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #61 of 6393 Old 07-24-2007, 02:55 PM
dobieck1's Avatar
Liked: 27
Originally Posted by Chris Gerhard View Post
If it is connected via 5.1 analog, I say no. Others may have a different opinion however. I don't have any equipment to do any objective tests but I find the DVD-V performance and HDMI 1.2a are the big upgrades. You might wait until some objective data can be presented regarding audio performance. I have both players and I am with you, the DVD970HD is a great sounding budget CD/SACD/DVD-A player.
Chris
I use HDMI. It appears the DAC's are different. Also, DSD output.
Guess we will see.
Here to help and learn. Thanks AVS.
XBL: HoosierInOhio
dobieck1 is offline
post #62 of 6393 Old 07-24-2007, 03:06 PM - Thread Starter
Neuromancer's Avatar
Quoted: 78 Post(s)
Liked: 285
Originally Posted by 70MM View Post
Do we have a new remote with this model?
Yes, but it is a slightly modified remote that OPPO has been using for the past year and a half.
Neuromancer is offline
post #63 of 6393 Old 07-24-2007, 03:08 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 285
Guess we will see.
The DACs has been greatly improved, especially when it comes to the capacitors used (they hand picked a new capacitor maker).
post #64 of 6393 Old 07-24-2007, 03:10 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 285
Originally Posted by jgdempsey View Post
The question for those of us who are still stuck with component input HDTVs, is there a possibility that a firmware hack will be available (and how soon) to do 1080i or 1080p via component.. I was more or less sold on the 970, but might as well wait for the 980 if the same capabilities are going to be there (ala 1080i via component) with the added features that the 980 provides..
This is completely up to the software hackers. OPPO has no firmware which will do component based upconversion of copyrighted media.
post #65 of 6393 Old 07-24-2007, 04:04 PM
sbavnut's Avatar
Neuro - hope you have answers to these:
1. I am hoping that they haven't abandoned the DSD to PCM conversion feature as an option (needed for those HDMI 1.1 receivers). In other words, they have an option in setup that allows users to choose between PCM and DSD for SACD output over HDMI.
2. Unit has 7.1 out - any way to "copy" the side surrounds to the rear surrounds for analog out - that way you can have all 4 rear speakers (of course, the levels have to be lowered) going without using any processing in the receiver/pre-pro.
3. How about a even higher end unit with "better than Faroudja" scaler for under $350?
sbavnut is offline
post #66 of 6393 Old 07-24-2007, 04:12 PM
dasher123's Avatar
what I really want to know is: will this have the same sound quality for CDs and SACDs like the oppo 970 was supposed to?
i also notice that 970 had "downmix" and L/R outs for the 5.1; seems the 980 only has downmixed front L/R.
dasher123 is offline
post #67 of 6393 Old 07-24-2007, 04:15 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2580 Post(s)
Liked: 1764
Originally Posted by joltdudeuc View Post
Yup, even for not supporting it, it plays back PAL just fine usually.
Compared the 971/981, I've found PAL playback on the 980 to be poor. I only have three titles, but they all show the same thing. This is both for PAL native and PAL->NTSC.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #68 of 6393 Old 07-24-2007, 04:16 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 285
The dedicated Mix outputs were removed due to redundancies in the design.
The sound stage should be equal to, if not better than, the DV-970HD due to higher quality components (OPPO switched to new capacitors and resistors), a better DAC layout, and a new Cirrus Logic DAC and MTK solution.
post #69 of 6393 Old 07-24-2007, 04:17 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 285
-Bill
The performance is not as good as the DV-981HD, but it is far better than the DV-970HD, which could not even pass a single test pattern from Peter Finzel test patterns. The DV-980H passes the first two tests without errors.
post #70 of 6393 Old 07-24-2007, 04:20 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 285
There is a menu option for SACD. You can either set it to DSD or PCM. They have not removed the ability to do a DSD to PCM conversion for HDMI 1.1/1.3 receivers without DSD functionality.
This functionality does not exist to my knowledge, though I have done little testing with the audio performance of the player.
There is nothing from OPPO in the forseable future with this kind of functionality.
post #71 of 6393 Old 07-24-2007, 04:40 PM
gonk's Avatar
The DSD to PCM is still an option (and the default, if I remember correctly).
This is something that I inquired about a fair bit during the beta tests - either an optional matrix processing mode or simply a way to redirect side data to the rears along with an appropriate level adjustment. The sample that I tested didn't offer the capability, but I have an early sample and I know that this was something that they hadn't ruled out the last I heard. It'll be pretty much the first thing I try when I get an updated sample.
gonk
Beta tester: BDP-83 / BDP-80
gonk is offline
post #72 of 6393 Old 07-24-2007, 04:46 PM
dasher123's Avatar
just got this email from oppo; it confirms what neuromancer said:
[i]The tonal qualities of the DV-980H should surpass that of the DV-970HD. The main reason for this is that we hand selected new capacitor and resistor manufacturers, redesigned the DAC layout, are using an improved Cirrus Logic CS4361 DAC and the latest, heavily modified MTK solution for increased audio decoding fidelity. The end result is a system that is more robust and refined over our previous DVD player designs.
Best Regards,
Customer Service
OPPO Digital, Inc.
post #73 of 6393 Old 07-24-2007, 04:55 PM
mbalari's Avatar
Hello, one question, i will use the OPPO with a 42" LCD 1366x768 and I want to have a very Good quality in matters of audio in SACD and DVDA, which is my best option .....
DENON/OPPO/POLK/LG
mbalari is offline
post #74 of 6393 Old 07-24-2007, 04:59 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 285
I would go with the DV-980H.
post #75 of 6393 Old 07-24-2007, 05:14 PM
dasher123's Avatar
i wonder if this pre-order price will remain the same after it becomes available for "regular" ordering, or will it go up? I hope oppo doesn't do anything of the kind.
post #76 of 6393 Old 07-24-2007, 05:16 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 285
OPPO has never dropped or increased their prices. It will retail for $169.99 at OPPO and all other retailers.
post #77 of 6393 Old 07-24-2007, 05:16 PM
bnm81002's Avatar
I'm more confused than ever for my DVD player purchase, I have the Sharp LC-37GP1U LCD that up-converts to 1080p, I was going to purchase the Oppo DV-981HD, till I saw the new DV-980HD player and now Pioneer is coming out with their new player as well the DV-48AV, so between the 2 Oppo players, which would be a better fit with my Sharp LCD? obviously I will wait till there are reviews on both the 980HD and 48AV players before making a final decision, thanks for the help
bnm81002 is offline
post #78 of 6393 Old 07-24-2007, 05:28 PM
mbalari's Avatar
Thanks for your answer.
An aditional question: Can I use the HDMI ouput from 980, to connect the 3806, for audio (DVA, SACD), and the 3806 ouput HDMI to connect my LG LCD at 740P?
It is correct?
DENON/OPPO/POLK/LG
mbalari is offline
post #79 of 6393 Old 07-24-2007, 05:35 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 285
Yes, you can use a single HDMI cable into your receiver, and a single HDMI cable out to your display, for all audio and video decoding.
post #80 of 6393 Old 07-24-2007, 05:46 PM
JohnAV's Avatar
Quoted: 285 Post(s)
Liked: 422
Its actually $169.00 as listed on the Oppo site.
Oppo Beta Group
JohnAV is offline
post #81 of 6393 Old 07-24-2007, 05:48 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 285
Depends on the what you are looking for in picture quality. The DV-981HD will produce a more film-like, softer picture with little to no interlacing or aliasing errors.
The DV-980H, on the other hand, will produce a sharper image, but may exhibit picture errors such as aliasing and interlacing.
post #82 of 6393 Old 07-24-2007, 06:32 PM
SirDracula's Avatar
Quoted: 172 Post(s)
You're not alone. Besides the ones you mentioned, I was also looking at the Onkyo DV-SP405 and Denon DVD-1740, they are also brand new on the market, about $150 shipped. Can't find any reviews on them.
I think I'll go with the DV-980H in the end. I prefer a sharper, more vivid looking picture (I won't notice the artifacts anyway unless they are really bad) and I'd like to have USB and component out for when I retire the Oppo to another room where equipment that gets upgraded goes.
SirDracula is offline
post #83 of 6393 Old 07-24-2007, 07:13 PM
Chris Gerhard's Avatar
I think you will be happy with the DV-980H. I have Faroudja FLI23xx players and like them, but the sharper picture with the DV-980H is really impressive to me. I don't expect the DV-SP405 or Denon DVD-1740 to be comparable.
Chris
Chris Gerhard is offline
post #84 of 6393 Old 07-24-2007, 07:18 PM
TonyS's Avatar
Quoted: 12 Post(s)
If one were only interested in DVD-video playback of mainstream movies, TV shows, etc. is this unit comparable to or better than, say, the Oppo 970H or the Sony DVP-NS75H/77H?
TonyS is offline
post #85 of 6393 Old 07-24-2007, 07:40 PM
dasher123's Avatar
all previous oppo dvdp's could be converted to multi-region players by a few clicks of the remote. This was one of the main reasons I got interested in oppo dvdp's.
does this simple all region hack apply to this model as well? I sure hope so.
post #86 of 6393 Old 07-24-2007, 07:46 PM
wmcclain's Avatar
Liked: 1764
Yes, same code as always.
-Bill
wmcclain is offline
post #87 of 6393 Old 07-24-2007, 07:48 PM
dasher123's Avatar
cool thanks!
post #88 of 6393 Old 07-24-2007, 09:03 PM
For region 1 DVD-V, the DVP-NS75H is much less expensive and the better deal. Performance is possibly slightly better with the DV-980H, but we will have to see what Secrets of Home Theater and High Fidelity find with their objective analysis. I would recommend you get into DVD-A/SACD, nobody should miss out on those great audio formats.
Chris
post #89 of 6393 Old 07-24-2007, 10:31 PM
JohnAV's Avatar
Quoted: 285 Post(s)
Liked: 422
Chris
I was wondering about that comparison, but this should be against the DVP-NS77H (also 1080P), hopefully both the Sony and Oppo do well on the DVD shootout. I just wonder how long it will take Secrets of Home Theater to get around doing this?
Oppo Beta Group
JohnAV is offline
post #90 of 6393 Old 07-25-2007, 04:20 AM
wmcclain's Avatar
Liked: 1764
The 981 review did not appear for many months. Kris Deering has to do the work and then the review appears on the web some unknown time later, beyond his control.
No one has mentioned yet: this machine was in beta for months and there was not a hint of a rumor about it at AVSForum.
-Bill
wmcclain is offline
Reply DVD Players (Standard Def)
