Playing ripped DVDs through USB of DVD player? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-30-2007, 01:57 PM - Thread Starter
TH3_FRB's Avatar
Quoted: 156 Post(s)
Liked: 30
Short of building a HTPC, is there a simple way to play ripped DVDs from an external USB hard drive? Can I just plug the HDD into the USB port of a DVD player like the Oppo 980H and access the ripped DVDs directly through the DVD player?
TH3_FRB is offline
post #2 of 4 Old 09-30-2007, 05:23 PM
Stimby's Avatar
I think the Oppo 980H can do this. I'd give them a call. I've never done it myself.
Stimby is offline
post #3 of 4 Old 09-30-2007, 05:58 PM
moviegeek's Avatar
I read a thread the other day that said the HDD has to be FAT32(4GB limit) and the player only supports 700 files(MTK limit).
There may be a max HDD size as well,better contact Oppo.
moviegeek is offline
post #4 of 4 Old 09-30-2007, 08:15 PM
Arvy's Avatar
Quoted: 94 Post(s)
Liked: 84
You'd want a player HDD enclosure with USB 2.0 also. USB 1.0 is way to slow, at least it is with the Oppo 970H.
Arvy
Arvy is offline
Reply DVD Players (Standard Def)
