Denon 1930 SACD is now Static?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-13-2007, 09:14 AM - Thread Starter
The_Nephilim1's Avatar
Quoted: 33 Post(s)
Hi, I would like to point out I had this Player since last Christmas and the SACD worked fine until Monday the 8th?? I just got back from a 2 Week vacation and was having Surround sound withdrawls so I popped in AIC SACD and there was nothing but static.
Has anyone else who has this Player had their SACD goto static or had a similar problem was there a fix?? The DVD-A works fine so I don't think it is my Reciever??
I will call Denon Tech support Monday, but they are Not open during the Weekends so I figured try here as somebody else may of had this happen to their Player as well and know of a Fix??
EDIT: I also had the unit unplugged during my vacation. I checked the SACD setting and it is on 6 CH It worked for like a minute then it went back to Static??
Gerald
The_Nephilim1 is offline
post #2 of 6 Old 10-14-2007, 04:20 AM
Chris Gerhard's Avatar
Gerald
Are you using HDMI? What receiver?
Chris
Chris Gerhard is offline
post #3 of 6 Old 10-14-2007, 08:53 AM - Thread Starter
Quoted: 33 Post(s)
Oh Sorry Should of posted that info. I am using the 5.1 Analog Input and a Sony STR-DE898 Reciever.
post #4 of 6 Old 10-15-2007, 07:34 AM
T-smith's Avatar
can you play SACD through HDMI on this player?
If you havent listened to it yet can you really say its not better?
T-smith is offline
post #5 of 6 Old 10-15-2007, 08:36 AM
I don't own it, but it is my understanding that it does convert to PCM for use with HDMI 1.1 receivers. No direct DSD is also what I understand. I do own the DVD-1920.
Chris
post #6 of 6 Old 11-11-2007, 02:57 AM - Thread Starter
Quoted: 33 Post(s)
Sorry for the long Delay But I had already sent the Player for Repairs so I didnt Post!! Hmm Seems we really are Neighbors as I live down in Woolwich next to Swedesboro?? Do you own the Denon 1930ci??
I was also Curious does anybody else out there have this Unit that had Problems with it Like the SACD Playing Static??
Reply DVD Players (Standard Def)
