Pioneer Elite DV-58AV - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 1057 Old 01-09-2008, 05:41 PM
AndyGood's Avatar
Considering that the Pioneer 95 bluray player was trashed for SD playback, I am wondering how this player will differ with SD, particularly what chip. I'd consider this player as a compliment to my 95 if it offered an improvement with SD.
AndyGood is offline
post #32 of 1057 Old 01-10-2008, 09:23 AM
ohrbrcko's Avatar
Quoted: 36 Post(s)
Liked: 34
I am interestd to know how this player differs from its cousin DV-48AV- besides the heavier base. I am on the fence between this, the 48av and the mythical Oppo 983 to be used a 'bridge" player until I transition to Blue Ray or HD. I am not pulling the trigger on a Blue Ray until the format wars show definite signs of coming to an end and there are more affordable choices. Seeing that Marantz has come out with one costing $2K is silly.
ohrbrcko is offline
post #33 of 1057 Old 01-10-2008, 01:30 PM
swestbom's Avatar
What are the bass management options for the DV-58AV?
swestbom is offline
post #34 of 1057 Old 01-10-2008, 05:38 PM
AndyGood's Avatar
Nobody seems to know anything significant about this player it appears.
AndyGood is offline
post #35 of 1057 Old 01-10-2008, 05:48 PM
Haseeb's Avatar
Looks like Elite DV-58AV is a mystery. There is not much available on it, it is not listed in the Pioneer website, no reviews, no specs...
Haseeb is offline
post #36 of 1057 Old 01-10-2008, 06:52 PM
Kevin C Brown's Avatar
Liked: 27
Is it actually available yet?
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #37 of 1057 Old 01-10-2008, 06:54 PM
AndyGood's Avatar
I believe so, ABT electronics and Sound Pros have it "in stock".
AndyGood is offline
post #38 of 1057 Old 01-10-2008, 09:42 PM
bettyfordallstar's Avatar
It's available! I can get the unit here in Ontario Canada none of my local dealers have this unit in stock at this time. According the sales rep that briefly called the Pioneer Representative to determine availability, the 58av is almost identical to the DV-78avi unit, (except for the price).
Anyways, that's my 2 cents.
P.S. the DV-58AV is listed at www.pioneerelectronics.ca
take care,
bettyfordallstar is offline
post #39 of 1057 Old 01-10-2008, 09:52 PM
pisay87's Avatar
I got mine in early December.
pisay87 is offline
post #40 of 1057 Old 01-11-2008, 09:19 AM
Upgrade's Avatar
Not sure if it will post properly in here, but there is a spec sheet for this player on the Best Buy website:
http://images.bestbuy.com/BestBuy_US...58AV.pdf?h=488
Also not sure how much information it will provide that is not already out there, but it is the only piece of information from Pioneer I have seen on this unit.
Upgrade is offline
post #41 of 1057 Old 01-11-2008, 10:46 AM
swestbom's Avatar
take care,
The 58 has better dacs (pcm-1796 versus 1738) and better video, hdmi 1.2 versus 1.1, DSD over HDMI instead of an iLink. The DV-79avi has been discontinued, they are just selling off the inventory (at a steep discount, below the cost of the 58).
swestbom is offline
post #42 of 1057 Old 01-11-2008, 10:53 AM
Haseeb's Avatar
Does DV-48AV has the same 1796 DACs too? What is the real upgrade from 48 to 58?
Haseeb is offline
post #43 of 1057 Old 01-11-2008, 12:23 PM
swestbom's Avatar
Better output stages for analog audio, probably better video processing too but who knows on that, my main reason for interest in it is the analog audio. With my Pioneer VSX-56TXI and DV-47ai (same dacs as the 79) the DVD player has much better SACD sound than the receiver has using the iLink connection but the video quality is marginal.
swestbom is offline
post #44 of 1057 Old 01-11-2008, 02:48 PM
swestbom's Avatar
DV-58av Signal to noise ratio: 118 db, Dynamic Range 108 db
DV-48AV Signal to noise ratio: 115 db, Dynamic Range 100 db
That is the output section upgrade, power supply upgrade, the reason for the 5~ lbs weight for the 48 versus 11~ lbs. weight for the 58. I had to go to the Japanese site for the DV-58 numbers (DV-800AV there)
http://pioneer.jp/press/release600-j.html
http://www.pioneerelectronics.com/pi...ctions0706.pdf
swestbom is offline
post #45 of 1057 Old 01-11-2008, 03:17 PM
Donnie 1's Avatar
ive been trying to find the differences between the dv-58av and the dv-79avi can anyone help me out?
i picked up a new dv-79 in a factory sealed box for what i think was a good price. not sure if i want to open and use it or sell and get the dv-58
Donnie 1 is offline
post #46 of 1057 Old 01-11-2008, 04:06 PM
Haseeb's Avatar
This helps and provides much clarity. Thanks.
One more question: If both DV-48AV and DV-58AV can output SACD 5.1 signal over the HDMI connection and your receiver can handle it then why would you use analog 5.1 connections and why would bigger power supply or better DACs make any audio differnce between the two???
Am I missing something assuming video on both is same or pretty close?
Haseeb is offline
post #47 of 1057 Old 01-11-2008, 04:35 PM
swestbom's Avatar
As long as the HDMI output stream is buffered and clocked in the player the slightly better transport would be a mute point so probably no difference whatsoever if you use the HDMI DSD feed to the receiver for DAC.
I plan to use the analog output because you have to get up to the $2k plus level in a receiver or controller to get an DAC output stage as good as this DVD player has. For instance the Integra DTC-9.8.
swestbom is offline
post #48 of 1057 Old 01-11-2008, 05:08 PM
Haseeb's Avatar
Thanks again for explaining. Looks like one has to deal with DACs anyway whether in DVD player or receiver. So why not go with the one which has better DACs.
Now can both of these players (48 and 58) play PAL DVDs by converting the signal to NTSC? I have some PAL DVDs and I would like to play them on the player.
Haseeb is offline
post #49 of 1057 Old 01-11-2008, 09:27 PM
KramerTC's Avatar
Quoted: 47 Post(s)
Liked: 31
Bingo. That's the roadmap I set for myself a couple of years ago. I use the analog outputs of my 59avi into an Outllaw 950. It's much cheaper to get a high-end player and use it's analog outputs than replace your pre-pro/receiver if you want the best DACs every two years. The 59avi's analog output sounds better than the 950's processing.
KramerTC is offline
post #50 of 1057 Old 01-12-2008, 11:24 AM
Dan Hitchman's Avatar
Quoted: 3413 Post(s)
Liked: 1766
So, is this Pioneer Elite player built significantly better than, let's say, the Oppo 980H? I have an Oppo 970 and although it's cool for the money, it feels as flimsy as a $40 player in regards to build quality and is starting to make some funny transport noises.
How does it compare to the new Marantz mid level universal player?
Yes, the 980H does do DSD bitstreaming and PCM bitstreaming, but its channel output level adjustment also affects the bitstreamed data (and it's not accurate)... you want the undecoded bitstream to remain untouched if bypassing the player and going straight to an outboard DAC system. That leads me to believe that the Oppo is getting in the way and not sending a pure data signal out if you can adjust the channel trims and bass management, and have it set on HDMI bitstream out. Something doesn't smell right.
Perhaps that's why DSD bitstream output didn't sound as good as using the PCM conversion inside the Oppo.
That's why, besides build quality, I'm interested in the DV-58AV or something similar from Denon, Marantz, Yamaha, or others (that also does DSD 5.1 bitstreaming via HDMI).
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #51 of 1057 Old 01-12-2008, 04:36 PM
Liked: 27
I don't have the link at the moment, but there's some belief out there that converting DSD to PCM can improve the sound quality because all the high freq noise that's present in the SACD signal (that some people believe actually makes SACD sound more like analog) is removed.
But it is all "digital" too. So unless you believe that jitter affects sound quality, then I'm not sure there *can* be a difference.
post #52 of 1057 Old 01-12-2008, 09:38 PM
swestbom's Avatar
I am not sure what you are saying, what post were you referring to? My Pioneer receiver does DSD to PCM conversion for DSP when I use the iLink and any DSP setting, it sounds pretty bad, why add the extra chance to screw things up?
You cannot recover information that isn't there in a conversion from DSD to PCM. DSD does have a bad signal to noise ratio as you get up above the dog whistle territory but who really cares? There isn't anything in the source material to be concerned with and the high order harmonics are inaudible anyway. It sounds far more natural below that point than DVD-Audio at 24/96 does with my DV-47ai, the PCM is strident sounding in comparison, artificially edgy. DSD has some theoretical issues tracking square waves but it isn't a real issue with music and with the sampling frequency it uses it wouldn't be audible anyway, not that I want to listen to that.
In short DSD works really quite well for acoustic music, probably partly because there is no temptation to "improve" the mix. It sucks for pop music because you have to convert everything to PCM to trash it in the mixing software anyway assuming there was anything analog in the source material to begin with.
swestbom is offline
post #53 of 1057 Old 01-13-2008, 01:28 AM
Liked: 27
This is what I was referring too.
post #54 of 1057 Old 01-14-2008, 05:42 PM
cleanguy1's Avatar
Originally Posted by Blindamood View Post
Haven't seen much on this one yet, except a picture on the 'Secrets' coverage of CEDIA 2007, as well as pre-order listings on a couple of online vendor sites. What's interesting about this player is that is upscales to 1080p, and is able to pass multi-channel DVD-A and SACD via HDMI (1.2a). Since support for iLink seems to be dwindling, this will be a nice alternative for those who want to send high-res music digitally to their processor/receiver.
CEDIA Pictures on Secrets
(Sorry, tried to post link to spec sheet, but could not link to online retailer site. A quick search will turn it up.)
What is the differnece between the pioneer DV58A & the pioneer BDP-95FD, I just bought the new BDP-95FD now I see you have the other unit, which unit better overall?
cleanguy1 is offline
post #55 of 1057 Old 01-14-2008, 06:20 PM
swestbom's Avatar
The blu-ray player cannot handle DVD-Audio or SACD the 58 can. Why sell one player when you can sell two. No one makes a blu-ray player that supports SACD and DVD-Audio except the ps-3 for SACD's DSD format converted to PCM. Also some early Panasonic units supported the (almost) dead DVD-Audio format.
If you were wondering, DVD-Audio is confined to pop music because it can be mixed with PCM based software, SACD is mostly Classical and other acoustic music (jazz for the most part) because you cannot really play with it in the digital domain very much.
swestbom is offline
post #56 of 1057 Old 01-15-2008, 03:01 PM
Donnie 1's Avatar
O.K. lets ask this a different way, which one of these is better?
Donnie 1 is offline
post #57 of 1057 Old 01-15-2008, 03:55 PM
mrkeeling's Avatar
To be more specific (at least that is what interests me) which of the two (Elite DV-79Avi and Elite DV-58AV) performs better in ANALOG 5.1 audio performance - especially with Hi-Res discs (DVD-a and SACD).
There was the mention somewhere in this thread that 58AV is superior in that department (ANALOG 5.1 audio out) and I wander if anybody actually compared them side by side.
I share the same philosophy as a few other members in this thread in liking my player to do all the work - keeps the upgrading much simpler and more cost effective. It is definitely time to replace my aged DV-45a.
mrkeeling is offline
post #58 of 1057 Old 01-15-2008, 04:10 PM
mrkeeling's Avatar
It very much depends on your needs.
In video department 58 probably outperforms 79 as it does 1080p upconversion, but if you are after 480i feeding some kind of video processor - that might be insignificant.
In audio department 58 has newer DAC's, but newer doesn't necessarily means better.
Overall 58 is more up to date player. But it is also full 7 lbs. lighter, which may indicate less built quality, smaller power supply and who knows what else. All that of course doesn't mean that it can not perform better.
On top of that I have absolutely no experience with either one.
post #59 of 1057 Old 01-15-2008, 07:20 PM
KramerTC's Avatar
Quoted: 47 Post(s)
Liked: 31
I've had the 59avi for a couple of years. No direct experience with the 79 you just bought but the consensus was (and still is) that the 79 was better than the 59 in analog audio output quality. The video? This is where it gets interesting...everybody that bought the 79 was gushing about this player and then Secrets (www.hometheaterhifi.com) did a review and found a flaw in the video processing. Bam! 180 degree turn-around in people's perception of this player. If you want to see what I'm talking about find the review at Secrets then go find the posts in the 79 owners thread around the time the review was published. Look at the before and after. Bunch of sheep!
There are no direct comparisons between the 58 and the 79 because the 58 is so new. But you can check the Denon 2930 owner's thread and get an idea of the capabilities of the DACs since that player uses the same chip for internal audio. There's a lot more that contributes to the quality of the sound output but at least you have a starting point over there for reference.
KramerTC is offline
post #60 of 1057 Old 01-16-2008, 09:15 AM
steck's Avatar
keep the DV-79. especially if you got it for a cheap price - as i assume you did. the thing is a tank.
i bought the DV58 cause it was cheaper...but i did notice the weight difference between the two. if they would have been the same price, i woulda bought the 79.
as far as the 58 goes, its better than the $200 toshiba it replaced !! (although the SD-3800 was a definite over achiever)
i noticed the video to be alot brighter (the whites are so bright) on my (already non-state of the art) 1080i 52" RPLCD.
it looks nice in my rack - as opposed to an el-cheapo plastic POS.
it gets pretty technical around here, and i'll stay out of that talk, but i'm generally happy with my 1st pioneer product i've ever owned.
i find it hard to believe the AV48 is as good as the AV58 (on paper) but having said that, realistically, i doubt i'd see or hear a difference between the two!! but i'm not a big fan of slim players...they look so insubstantial and cheap.
steck is offline
Reply DVD Players (Standard Def)
