Tosh A3 or Oppo 980 for SD dvd? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-24-2007, 04:10 PM - Thread Starter
rw71's Avatar
I have a Pany 53k DVD player in the box at home. I have a Toshiba 42HL167(1080P/24). I was wondering if the A3 and Oppo 980 will produce the same picture quality for upscaled DVDs(better) over the Panasonic. Obviosly, the HD of the A3 would be a plus. Since the A3 is only 1080i, does setting it to 1080i produce the best picture for a 1080p LCD?
rw71 is offline
post #2 of 3 Old 11-24-2007, 04:39 PM
markabuckley's Avatar
Quoted: 101 Post(s)
Liked: 34
not sure about the A3 specifically -but I found the A20 better at upscaling than the Oppo 980.
I have both - because the 980 can play multiregion.
Oppo 980 is excellent - no doubt - but the A20 is marginally better.
this is for PAL DVDs.
markabuckley is offline
post #3 of 3 Old 11-24-2007, 04:45 PM - Thread Starter
rw71's Avatar
Thanks Mark. I believe the A20 is a different chip and a little different than the A3.
rw71 is offline
Reply DVD Players (Standard Def)
