HELP! Samsung DVD player won't play DVDs... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-15-2008, 04:43 PM - Thread Starter
ValentineMina's Avatar
Help! I bought a Samsung DVD/VHS player about two months ago:
And now I have a problem, it won't play DVDs! Here is what happens, when I stick a DVD in, the TV will show the Samsung Loading screen and then all of a sudden it goes blue. Meanwhile, the DVD player face just shows 0:00. It is not the disc, because I've tried multiple discs. It is not the connection, or else it would not show the Samsung Loading screen or even the blue screen. It is not set on VCR, so that's not the problem either.
The only thing that I can think of that might have caused this is that I recently unplugged the DVD player and accidentally touched the metal part of the plug while it was partially in the socket and that gave my finger a minor electric shock. But I don't think that could be it?
Also, I bought this in cash, did not keep the receipt or box as I threw them away after successfully watching a couple of movies.
Am I screwed?
ValentineMina is offline
post #2 of 3 Old 02-15-2008, 05:46 PM
louthewiz's Avatar
Static charges are the biggest killers of electronics , so you have a doorstop for sure.
louthewiz is offline
post #3 of 3 Old 02-15-2008, 06:09 PM
budeone's Avatar
Quoted: 82 Post(s)
Liked: 78
Did you try a master reset?
I don't know your model number but if you google it it will show how to do it. I would try it and just see what happens before you prop your door open with it.
OLED65E6P/4 Martin Logan ElectroMotion IC In-Ceiling
Marantz Av8802a/2 VMPS Super towers/Paradigm sub
OPPO UDP-203/4 M&K rear speakers/Paradigm center
Marantz MM8077/3 Adcom amps
Sony BDPS6200 /Toshiba HD-A2 HD DVD
Request AudioReQuest N.Series
budeone is offline
Reply DVD Players (Standard Def)
