Netflix streaming quality - Page 202 - AVS Forum | Home Theater Discussions And Reviews
 601Likes
post #6031 of 8755 Old 07-21-2014, 06:52 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 623
Originally Posted by michaeltscott View Post
Not unless they've upgraded it. Amazon's 720p has always been <= 3000 Kbps in the past, including audio. Netflix's highest bit rate 720p is 3000 Kbps. Netflix's 3K 720p is also encoded with eyeIO technology (awarded THX certification at 5800 Kbps), which claims to deliver the same PQ in 50%-60% the bandwidth used by other AVC encoders.
The following is a graph of bandwidth consumption of Ong Bak 2: The Beginning (a very encoder-challenging sequence of martial arts combat in the rain), as streamed from Amazon to a Roku 2 XS:
Spoiler!
(I'd usually crop and re-scale the graph, adding labels, but I don't feel like it ). The data was acquired on 10/13/2012. Sadly, it's not Prime anymore or I'd ask one of you running router firmware with a bandwidth monitor to take a look at it now.
Re Tubetwister
I'm just going by the post I linked,
I haven't seen any other info on that that's why I said "I believe Amazon is using ....." and mentioned encode efficiency at the end . I'll leave the science of that to to you ☺☺☺looks like it works pretty good though
OTOH Amazon HD 1080p/720p on the Roku seems to be looking better than B4 now .
I'm using a Stock ATT U Verse 3801 RGW WIFI thingy so no bandwith monitering or jail breaking software there it would be interesting to see what Roku throughput on Amazon instant is though I would like to see that .
OTOH with bandwidth caps Netflix is the place to be and also they have much more content and TBH it looks fine
2 me in any of the 1080p steps .
tubetwister is offline
post #6032 of 8755 Old 07-21-2014, 06:58 PM
undecided's Avatar
Quoted: 123 Post(s)
Liked: 80
Originally Posted by tubetwister View Post
In my experience here Amazon HD looks pretty good often better than Netflix super HD but not always that much
Thing is Amazon instant uses a much higher 720p bit rate than Netflix something like ~ 9.7 Mbps (on supported devices)
I believe Amazon Instant (on supported devices ) uses something like 12-13 Mbps on 1080p HD instead of the usual ~5-6 Mbps on Netflix super HD
Agreed Amazon 1080P HD does indeed look better than Netflix 1080P
Sorry I may have mislead you on the 720P rates on the Fire TV. Those were my measurements on Rubicon. I am now pretty sure the 9.75 Mbps average over the entire two episodes was 1080P. When the Fire TV was released it would show a 1080P logo when streaming at 1080P from Amazon Instant. For the last month or so the 1080P logo has disappeared - but not I think the 1080P streaming.
Yes as you quote I have seen 12 - 13 Mpbs (and higher) 10 minute averages on some Amazon Instant titles - although again to get a more accurate number I think I need to play the entire movie and divide the data downloaded by the length of the movie. The 10 minute averages are a snapshot - but may not represent the average over the movie. When I have time to do a complete movie I may try this.
Attached is the first 10 minutes of Marvel's Avengers on a Fire TV on Amazon Instant. As you can see it averages a surprisingly high 14.8 Mbps - but does include filling the buffer at the start of playback. The average streaming late is likely to be somewhat lower.
Name:	Marvels Avengers Fire TV.jpg
undecided is offline
post #6033 of 8755 Old 07-21-2014, 08:00 PM
michaeltscott's Avatar
Quoted: 2844 Post(s)
Liked: 1516
If you can, try constraining the output to 720p and see what you get.
I was running Tomato on a venerable old Linksys WRT45g, but my housemate/landlord moved out, taking his cable modem and router with him. I bought a cheap ASUS RT-N16 because you can load custom firmware into it, but I've been too lazy to research the capabilities of the various options.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #6034 of 8755 Old 07-22-2014, 03:41 AM
Liked: 623
Re Tubetwister
Thanks for hooking us up with what you have so far I had no clue at all about Amazon Bit Rates B4 today
seems like you know a ton more about this stuff (plenty ) ,more than I do probably than I thought at first !
I owe you one ..............but I did get 5800 kbs pretty regular on a 6 mbps over provisioned service .
it did surprise me though .... I about fell out of my chair when I first saw it !
My 18 mbps is like that it hangs out in the 20 - 21's I don't think ever seen it much below 20 mbps
Netflix is taking longer to ramp up to 5800kbps last couple of days maybe it was the weekend thing .
Sometimes If I can score a prime movie or free show @ 1080p on Amazon instead of Netflix I watch it there usually stays where its supposed to and can look a little better sometimes and they don't make you wait much ramping up usually
I like the new genres they added on the front page sometimes they have a lot of decent watchable stuff on prime you can't find any where else also lots of PBS stuff also probably almost as much as PBS has tons .
Amazon 720p feed worked out well also . Not the place 2B if U have bandwidth caps though
Netflix is looking better lately though and they have lot of stuff between those 2 its a good set up .
regards
post #6035 of 8755 Old 07-22-2014, 08:32 AM
reddice's Avatar
Quoted: 602 Post(s)
Liked: 117
Tried to watch The Twilight Zone on the Roku 3 last night at 7 PM but like Sunday night it did not look so great. Had bad micro blockage and banding which I can tell was in there crappy 720p encode. I tried the ATV3 and I was shocked that it ramped up to 1080p no micro blockage and it was clearer. After I watched Alias and the 4400 which stayed in Super HD most of the time with only a couple of small dips to 720p or SD but a quick ramp up. As I said traffic is up the last few days. Also since everyone of my streaming devices now connects to Atlanta I see it goes through three Level 3 hops but when it hits Atlanta Level 3 I get timeouts. I really wish I would connect me back to NYC even though the difference was small as it still went though crappy Level 3 at least it was only one hop.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-138 K26ARM USB VPN-64K.
My Primary Streaming Devices: Fire TV Box (2nd Gen), Roku Premier (2016).
Cats are the best pets.
reddice is offline
post #6036 of 8755 Old 07-22-2014, 09:09 AM
mgkdragn's Avatar
Quoted: 1962 Post(s)
Liked: 2296
http://money.cnn.com/2014/07/21/tech...html?hpt=hp_t2
Uncle Willie
Oddball: Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?
mgkdragn is online now
post #6037 of 8755 Old 07-22-2014, 10:26 AM
Mr.G's Avatar
Quoted: 685 Post(s)
Liked: 382
...36 million subscribers in the U.S. and they were all watching something Sunday night.
Brian Conrad likes this.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #6038 of 8755 Old 07-22-2014, 11:44 AM
Brian Conrad's Avatar
Quoted: 1626 Post(s)
Liked: 898
My "ancient" Sony player with Amazon has the interface which shows how much is buffered. Some of the Hulu+ TV episode when they return to the episode from an ad will often show the buffer full or nearly full for a 6 minute segment. For Amazon the FX shows often have a promo for another show up front and by the time it's finish the buffer is way ahead. Some of the shows do indeed look like they are 1080p including FX shows which I would have expected to be just 720p. And this is a rather recent development. Netflix on that player got the new interface but still doesn't interface well with the Sony API to do much more than 720p (though I'm sure the API supports it). For Netflix I use the Chromecast which supports SuperHD.
Brian Conrad is offline
post #6039 of 8755 Old 07-22-2014, 12:10 PM
Westly-C's Avatar
Quoted: 346 Post(s)
Liked: 220
I'd like to know what device they used for the video loop playing in the background at the 2 min mark. The previous PS3-style app that was playing on the screen behind the anchor and guest, was moving smooth and fast. There were 2 ''Recently Watch by'' rows, each with different names. And small Facebook pictures in the title summary column underneath the description.
None of the title covers were anything that I recognized as recent additions though. Perhaps it was just some video that had been recorded years ago and simply selected for playback.
Name:	CNN Video screencap Netflix app.JPG
ID:	174866   Click image for larger version
Name:	CNN Video screencap Netflix app2.JPG
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is online now
post #6040 of 8755 Old 07-22-2014, 12:25 PM
Liked: 1516
It's obviously on a PS3 which hasn't been updated to the latest Netflix UI. All of those features were in it, though I'm not sure about the "Recently Watched By ..." with different names. Are those the names of Profiles on the account or of Facebook friends? I only recently enabled Facebook integration (to get a custom Profile icon); I only have a Facebook account because some businesses have had offers, etc, which require it. I've also used it to log into some sites without going through the trouble of creating an account, when I wanted to post a comment. I never log into it, but I think that my ex-housemate became my Facebook friend somehow and I think that she's the only one and if she has a Netflix account, she doesn't watch anything that I've come across.
post #6041 of 8755 Old 07-22-2014, 03:02 PM
reddice's Avatar
Quoted: 602 Post(s)
Liked: 117
Michael that is what I use Facebook only for to log into sites like Vevo without having to create a account. I don't have or want any friends on Facebook.
reddice is offline
post #6042 of 8755 Old 07-22-2014, 03:16 PM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
Post
It's obviously on a PS3 which hasn't been updated to the latest Netflix UI. .
Or a smart TV. That looks like the UI on my Panny S60.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #6043 of 8755 Old 07-22-2014, 04:19 PM
Liked: 1516
If you look closely you'll see it's like this:
Spoiler!
with SELECT for "Just for Kids", TRIANGLE for "Search". You'll notice in the one above includes SQUARE for "Profiles" (and it says "Netflix Kids" instead of "Just for Kids"); this would seem to be a pre-Profiles version. SELECT, TRIANGLE and SQUARE are PS3 controller face buttons. There are versions of that UI many other platforms, but they generally have "Search", "Netflix Kids" and "Profiles" in a row of buttons above "My List" which you scroll to like it was one of the genre rows, like this:
Spoiler!
The buttons can be scrolled off screen, like any of the genre rows. My Panasonic and Sony Blu-ray players and my WD TV Live have the old common UI with a menu row above "My List" and my PS3, Xbox 360, TiVo Roamio, TiVo Premiere and Roku 3 have the new common UI.
post #6044 of 8755 Old 07-22-2014, 10:41 PM
reddice's Avatar
Quoted: 602 Post(s)
Liked: 117
Netflix played great on the ATV3 tonight go figure. Also my credits are not shrinking which is a plus but I wonder why since they added post play.
reddice is offline
post #6045 of 8755 Old 07-23-2014, 03:13 PM
reddice's Avatar
Quoted: 602 Post(s)
Liked: 117
Interesting read.
http://www.extremetech.com/extreme/1...rizon-customer
So you can set up a VPN using software does that mean you have to leave your computer on at all times. I would not care about only being able to watch Netflix on the computer since Fox, Sony and Paramount (just the movies) cripple the video to only 480p (except Disney which allows up to 720p) and reserve 1080p playback to TV devices only.
reddice is offline
post #6046 of 8755 Old 07-23-2014, 07:05 PM
Liked: 623
Originally Posted by reddice View Post
Interesting read.
Never used a VPN B4 but I don't see why you couldn't switch back and forth in Win /network proxy /vpn /settings .
AFAIK you would just need a VPN ip resolver address and then after you get there maybe log in credentials (or cookies ) maybe once you get there on open VPN you probably don't even need that .
post #6047 of 8755 Old 07-23-2014, 08:07 PM
xcrunner529's Avatar
Quoted: 33 Post(s)
Interesting read.
You have Asus software. You could use the OpenVPN support built into the router to create a tunnel to the service and make it available to a special SSID for tunneled traffic.
undecided likes this.
xcrunner529 is offline
post #6048 of 8755 Old 07-23-2014, 11:38 PM
undecided's Avatar
Quoted: 123 Post(s)
Liked: 80
Interesting read.
Yes reddice is also running Merlin firmware on his Asus router and as has been posted before it should be pretty easy to set up using OpenVPN and these instructions...
https://www.goldenfrog.com/support/vyprvpn/faq/general
post #6049 of 8755 Old 07-24-2014, 07:24 PM
Westly-C's Avatar
Quoted: 346 Post(s)
Liked: 220
For Apple TV owners, you now have post play on your ATV Netflix app.
http://t.co/qPYovR8T7o
post #6050 of 8755 Old 07-24-2014, 08:14 PM
Liked: 1516
Here's what it looks like on ATV:
Spoiler!
Much more sensible than on other platforms with the credits minimally shrunk. The new and old common UIs waste a ton of space.
post #6051 of 8755 Old 07-24-2014, 08:49 PM
Westly-C's Avatar
Quoted: 346 Post(s)
Liked: 220
Agreed. The wasted space on the standard UI is asthetically poor designing. This actually looks...enticing.
post #6052 of 8755 Old 07-24-2014, 09:22 PM
reddice's Avatar
Quoted: 602 Post(s)
Liked: 117
I'm not getting it glad thought.
reddice is offline
post #6053 of 8755 Old 07-24-2014, 10:39 PM
Liked: 1516
I'm sorry--I'm having trouble parsing that. Please rephrase.
I think that Netflix wants all of its customers to have all current features in their players, on all platforms for which that's possible. Be happy that they're not insisting that Apple switch to their common UI.
They have that UI on Roku 3 and the Roku HDMI Streaming Stick and we were expecting them to bring it to the other 2nd and 3rd generation Roku products, but apparently they couldn't get it to perform well enough so they quit. I expect that they'll add Profiles and Post-play to the native Roku Netflix channel. Lots of people will be happy to get Profiles; Post-play, no so much.
post #6054 of 8755 Old 07-25-2014, 09:06 AM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
I'm happy with my S60's UI. As long as I can browse the latest releases, see the Super HD designation, and have the option to start from the beginning, I'm good to go.
Ian
mailiang is offline
post #6055 of 8755 Old 07-25-2014, 04:21 PM
Liked: 1516
If the UI on an older device hasn't changed yet, it's probably never going to change. My 2011 Panasonic DMP-BDT110 has the old common Netflix UI but does not have support for Profiles, Kids or Post-play.
post #6056 of 8755 Old 07-25-2014, 09:08 PM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
Panasonic never updates their Netflix UI. What you see is what you get.
Ian
mailiang is offline
post #6057 of 8755 Old 07-25-2014, 09:39 PM
Liked: 1516
My 2012 DMP-BDT220 also has the old common Netflix UI, but it has been updated to have Profiles, Kids and Post-play as they gradually appeared on other platforms. That version of the UI can have its web-tech components (JavaScript and HTML code, etc) updated w/o a firmware update by the OEM. I recall that Profiles turned up simultaneously on the BDT220, WD TV Live, Sony BDP-S390 and PS3 on the day it was announced.
The Netflix player on the BDT110 looks almost identical, but it seems to use a different version of the video encodes; "Example Short 23.976" in that set does not have bit rate/resolution information on it. It's also constrained to 720p and has a bug which never got fixed, outputting a blank black frame every time it switched to an encode of a different bit rate.
post #6058 of 8755 Old 07-26-2014, 12:30 AM
Liked: 1516
Originally Posted by Mark12547 View Post
Does the BDT110 also show the quality of the stream when it starts playing by showing between 1 and 4 dots or bars (4 dots HD or 4 bars HD for 720p)? If so, it's using the older "Advanced Streams" and the "Example Short 23.976" for "Advanced Streams" does not have the bit rate, resolution, pixel aspect ratio information burned in it; that's only in the more recent "Adaptive Streams".
No--it's definitely adaptive. Like I said, it has a bug we called "black flashes" where it outputs a blank black frame every time it switches from one video encode to another at a different bit rate.
post #6059 of 8755 Old 07-26-2014, 07:33 AM
Westly-C's Avatar
Quoted: 346 Post(s)
Liked: 220
Unblock will not interfere with any file downloading or any other internet activity.
reddice likes this.
post #6060 of 8755 Old 07-26-2014, 08:42 AM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
Panasonic told me they only do updates for two years. My DMP85 BD player never received a firmware update for the UI. I don't expect an update on my S60 either, which is fine with me since, as I posted before, my current UI shows Super HD, and allows me to re-start a program from the beginning. I really don't have much use for the new features.
Ian
mailiang is offline
Reply Video Download Services & Hardware
