Netflix streaming quality - Page 207 - AVS Forum | Home Theater Discussions And Reviews
 601Likes
post #6181 of 8756 Old 08-05-2014, 03:19 AM
DRC72's Avatar
Quoted: 69 Post(s)
Liked: 30
Originally Posted by reddice View Post
Earlier Alias and Lost went to Super HD no problems. Now the 4400 won't go past 720p. I restarted it about 10 times changed DNS changed playback from auto to high back to auto this is all on the PS4.
Edit now it went up to super HD.
Yeah after 8 p.m it dropped down to 720p, but still much more acceptable than the 480p and lower that it usually drops down too.
reddice likes this.
DRC72 is offline
post #6182 of 8756 Old 08-05-2014, 06:17 AM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
I agree. Also Amazon 720p (don't know the bitrate but it must be higher) blows Netflix 3000 kbps 720p out of the water in quality. Still don't understand why Netflix can't at least maintain the 3850 kbps 1080p stream which I wish I can set it to only use.
Still with Netflix wanting to push 4K on non Open Connect ISP's which won't happen if they can't even maintain 720p. At least 4K players are very rare heck even the PS4 and Xbox One can't play Netflix in 4K I don't see it much as a problem in increasing congestion.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-140 K26ARM USB VPN-64K.
My Streaming Device: Fire TV Box (1st Gen).
Cats are the best pets.
reddice is offline
post #6183 of 8756 Old 08-05-2014, 01:15 PM
michaeltscott's Avatar
Quoted: 2844 Post(s)
Liked: 1516
I strongly disagree. Amazon's 720p is pretty good, but to my eyes Netflix 720p is at least as good (they're around the same bit rate). I just watched the entirety of the 3rd and final seasons of The Killing in Netflix 720p. It was quite good.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #6184 of 8756 Old 08-05-2014, 01:39 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
Well all I know is try to watch Once Upon A Time in 720p which looks like total crap banding and bad macroblockage. If you watch it on Amazon which I won't because it is behind a paywall it would be night and day.
reddice is offline
post #6185 of 8756 Old 08-05-2014, 01:40 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
Also per your request I created a new post about all my problems which I will keep updated.
Netflix issues in the evening with Time Warner Cable.
I will still post here but I will try not to rant about streaming issues instead I will rant in my own new post.
reddice is offline
post #6186 of 8756 Old 08-05-2014, 03:04 PM
mailiang's Avatar
Quoted: 946 Post(s)
Liked: 620
Lightbulb
Hate to rub it in, but Mike has Open Connect, so of course it's going to look much better.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #6187 of 8756 Old 08-05-2014, 03:59 PM
undecided's Avatar
Quoted: 123 Post(s)
Liked: 80
You know it may vary by device.
I would agree when using a Roku 2 720P on Netflix or Amazon look pretty similar - I have couple of 720P TVs so the Rokus are set to 720P out.
However using a FireTV 1080P Amazon is definitely superior to Netflix 1080P SuperHD (on any platform).
I also think that some of the Amazon streams on a FireTV are probably 720P (with bit rate of around 6 - 7 Mbps vs the 10 Mbps for 1080P) and if these are truly 720P they do look better than Netflix 720P.
As you suggested before I do need to set the FireTV to output 720P sometime check video quality and bitrate....
reddice likes this.
undecided is offline
post #6188 of 8756 Old 08-05-2014, 04:01 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
Also on Netflix I have seen some great 480p content. Batman Beyond looks great just like on DVD which I own with no macroblockage.
reddice is offline
post #6189 of 8756 Old 08-05-2014, 05:56 PM
Liked: 1516
I've been primarily watching old-but-not-very-old television recently, like Star Trek Voyager--PQ is decent. (It'd be nice if Netflix'd upgrade STNG to the recent BD transfer HD video).
In the past, I've measured Amazon's 720p at <3000 Kbps, but it's been a few years; they might have increased that. I know that their 1080p is a ridiculous 10 Mbps (who do they think they are, VUDU ?). Here's a 3 y/o graph of 10 encoder-challenging minutes of Ong Bak 2 (martial arts combat in the rain):
Spoiler!
~2700 Kbps average including audio and anything in the buffer.
post #6190 of 8756 Old 08-05-2014, 07:19 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
See that chart Michael I can achieve that during the day but after 9 PM on Netflix all I can get is 720p with a straight fluctuating up and down horizontal line across. Amazon always comes in as bursts at least on my Fire TV.
I would have hope Netflix would have came our with a streaming box but they would have botched it up with the new crappy modern ui and no precache optimization in other words it would have performed the same under congestion.
reddice is offline
post #6191 of 8756 Old 08-05-2014, 08:20 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
I just relized something. Looking at my bandwidth meter since June when the problems started again I noticed after 9 PM that I was not using as much bandwidth as earlier streaming HD on Netflix. All those programs I watched like the 4400 and Clone Wars when using the ATV3 and Roku 3 most likely was playing in 720p with some bursts of 1080p. I just notice it more now since I got the PS4 because when you press the options menu it shows the bit-rate indicator.
reddice is offline
post #6192 of 8756 Old 08-05-2014, 08:22 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
Does Amazon have anything similar to a example short that shows you the bitrate like Netflix does?
reddice is offline
post #6193 of 8756 Old 08-06-2014, 10:57 AM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
I do wonder though if a HEVC encoded 4k file will be as efficient (lower bitrate) than an H.264 encoded 1080p file. With the efficiency of HEVC I think that it will not make much of a difference... I recently encoded a movie to HEVC and it was about 1/4 the bitrate as x264 encoding make it incredibly more efficient. I only tested it using on movie file so I'll have to wait and see if it increases efficiency across the board on other files.
jhughy2010 is offline
post #6194 of 8756 Old 08-06-2014, 11:26 AM
Brian Conrad's Avatar
Quoted: 1657 Post(s)
Liked: 918
On my ancient BD player it shows the connect speed and then the bitrate plus how much of the buffer is full at the moment. A series on Amazon in excellent quality may show the buffer filled at least a half minute's worth on play.
Let's remember we are talking about moving targets regarding the technology. All companies are going to go for improved PQ plus try to do that at reduced bitrates. Thing is many of us pay for broadband speeds way beyond what is required for top quality which tells us indeed the gangsters running the ISPs were indeed messing things up.
This is an inverse method of doing away with net neutrality by making the content providers pay rather than the consumer. And it is very dirty and needs a congressional investigation.
mgkdragn likes this.
Brian Conrad is offline
post #6195 of 8756 Old 08-06-2014, 12:00 PM
mgkdragn's Avatar
Quoted: 2006 Post(s)
Liked: 2365
Or as I like to say, the extortionists .. and the upshot is possible price increases from the content providers to the consumer .. I doubt if we'll ever actually see an investigation, but you're right ..
Uncle Willie
Oddball: Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?
mgkdragn is offline
post #6196 of 8756 Old 08-06-2014, 01:07 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
Netflix is trying to squeeze water from a rock compressing the video so much. There is only so much compression you can do to a file before you notice it. Amazon and other streaming services uses a higher bitrate for there video and it shows.
reddice is offline
post #6197 of 8756 Old 08-06-2014, 02:01 PM
Liked: 1516
What is it that you think you know about video compression ? At one point people would have scoffed at getting the quality possible using AVC at streaming bit rates. It rivals and surpasses the quality of MPEG2 TV broadcasts at triple the rate.
Unless they've changed (which they might have) Amazon's 720p is encoded at a lower bit rate than Netflix's 720p and Netflix's is encoded with eyeIO tech. As I stated yesterday, Amazon's 720p video, though quite good, isn't better to my eyes than Netflix's. I have not had the pleasure of seeing Amazon's 1080p, but my guess is that the subset of their customers with equipment which can display it and network bandwidth sufficient to stream it is a percentage in single digits.
post #6198 of 8756 Old 08-06-2014, 02:19 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
Don't believe me Michael. Fine look at this. Also I forgot to mark after Lost was Charmed on Netflix which is only 480p.
The last two programs on Amazon Fire TV after Covert Affairs was Batman and Superman the animated series in 480p using the same amount of bandwidth as Netflix 720p streams.
I may need glasses for distance but I can tell lower quality video from higher quality when wearing my glasses.
reddice is offline
post #6199 of 8756 Old 08-06-2014, 03:03 PM
Liked: 1516
Can you make a graph of 10 minutes of Amazon streaming 720p on your otherwise quiescent network? I want to see some indication of what bit rate they're encoding 720p at today.
post #6200 of 8756 Old 08-06-2014, 03:23 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
I forgot Michael I read before you use a Roku 2 for Amazon. The Fire TV streams Amazon different which is why it performs the best. It precaches and optimizes the stream. The other devices don't do that. Also Netflix none of the devices so that. I am just hoping the new Apple TV 4 if it ever comes out does something with Netflix precache and optimize but that's wishful thinking.
reddice is offline
post #6201 of 8756 Old 08-06-2014, 03:29 PM
Liked: 1516
I only use Amazon to stream things that I cannot get from Netflix, like Orphan Black; nothing else about the Fire interests me in the least, so I haven't bothered with it. I've also never been able to get very interested in ATV. Lord knows I have far more than enough streaming devices--something truly special will have to arise to get me to buy one. I plan to buy one of the Vizio P-Series UHD panels whensoever they might ship (I've been waiting since CES). Its HEVC-capable smart TV platform will be my next streamer.
post #6202 of 8756 Old 08-06-2014, 03:31 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
I understand. I buy steaming devices like candy and I found the perfect Amazon streamer the Fire TV (the Roku, PS3 and PC were not that great) but I still have not found the perfect Netflix streamer that can handle congestion. I refuse to buy a Xbox One or a Wii U which have a different Netflix UI.
reddice is offline
post #6203 of 8756 Old 08-06-2014, 07:33 PM
Postmoderndesign's Avatar
Quoted: 305 Post(s)
Liked: 143
Netflix seems to be running smooth this evening. It's almost 7pm and Super HD is running most of the time. Maybe AT&T and Netflix have finally optimized the connections.
Netflix, AT&T Uverse, Atlanta, 9PM, Maiden Voyage, 1080p start to finish. I had complained so much that I thought I should report SuperHD is working, even though others have already said so.
gadgtfreek likes this.
Postmoderndesign is offline
post #6204 of 8756 Old 08-07-2014, 03:28 AM
DRC72's Avatar
Quoted: 69 Post(s)
Liked: 30
It has gotten a lot better on AT&T, but I still do drop down below 720p on occasion. It doesn't last long though. I'll stay on Super HD most of the time. I feel bad for the Verizon people. Just like their wireless division, their still cocky on their isp side as well.
DRC72 is offline
post #6205 of 8756 Old 08-07-2014, 10:50 AM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
Funny you live in Atlanta connect to the same CDN I do but you have no issues. So it is not the CDN I can most likely connect to the CDN in LA what causes the poorer performance is going though Level 3. Even when I connected right to the NYC CDN which was practically next door I still had to go though crappy Level 3 so I still had congestion issues.
reddice is offline
post #6206 of 8756 Old 08-07-2014, 10:53 AM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
Maiden Voyage is not even on Netflix. How the heck do you watch it in Super HD unless it is in another stupid region another reason why I hate that Netflix gone international.
Also searching for Maiden Voyage on Google just gives me a jazz album, a book and a song no movie.
reddice is offline
post #6207 of 8756 Old 08-07-2014, 11:41 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 623
7 Aug 2014 11:05 PDT
Played 1080p Netflix example short23.796 bit rate = 4300kbps @ 1:00 > 5800kbps @ 3:00 for remainder no slowdown or buffer > 2013 Roku 2 streamer > ATT U verse FTTN 18mbps internet plan
Yo...anybody know when the Vizio pee reference thing cumin out Wall Mart peoples wanna know
tubetwister is offline
post #6208 of 8756 Old 08-07-2014, 11:48 AM
Liked: 623
ATT been behaving better here lately too , probably ain't screwin wit da flex $&%$ like dey been too much right now
cause dey don't want no federal beef cummin down on dem while dey be tryin to buy Direct TV .... you wit me ?
post #6209 of 8756 Old 08-07-2014, 12:25 PM
DRC72's Avatar
Quoted: 69 Post(s)
Liked: 30
Word yo.....
tubetwister likes this.
DRC72 is offline
post #6210 of 8756 Old 08-07-2014, 01:07 PM
Liked: 1516
Yo...anybody know when the Vizio pee reference thing cumin out...
Vizio has stated that the P-Series is coming in "Fall". (That page is best viewed in Chrome with the browser blown up full screen; it has an extremely cool little animated demo of local dimming (Mr. Peabody and Sherman clip)). They said that the M-Series was coming in "Summer" and gradually released models for a couple of months before making the official "M-Series is here!" announcement on June 10th, 10 days before the solstice. Based on that I'd expect the first P-Series models to hit any time now, it being a little over six weeks until the equinox. No date has been given for release of the Reference Series, just "soon". I doubt that you'll see the Reference Series in Walmart.
Reply Video Download Services & Hardware
