Netflix streaming quality - Page 226 - AVS Forum | Home Theater Discussions And Reviews
 581Likes
post #6751 of 8672 Old 12-07-2014, 10:27 PM
michaeltscott's Avatar
Quoted: 2749 Post(s)
Liked: 1470
Originally Posted by mailiang View Post
They also removed the 'Super' HD designation on the old common UI.
Ah, you're right! We discussed that. Another semi-cosmetic change that they made to the new UI. Back when the "Super HD" label was there you could tell what the 720p-only titles were because they'd be marked simply "HD".
The sole holdout is the Win8 app, AFAIK. No doubt it's only a matter of time until they change that.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is online now
post #6752 of 8672 Old 12-08-2014, 07:32 AM
Westly-C's Avatar
Quoted: 338 Post(s)
Liked: 216
What button do you press to call up that corner display on the Win8 app? Nothing I've pressed shows it.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is online now
post #6753 of 8672 Old 12-08-2014, 01:19 PM
Liked: 1470
AFAIK, not available in that app. CTRL-SHIFT-ALT-S will get you a list of available bitrates and indicate which one is being played and which is being buffered now (you can also set a fixed bitrate on that dialog, but it will repeatedly pause and rebuffer if it can't keep up with what you choose). CTRL-SHIFT-ALT-D will cover the screen with a transparent debug dialog, which will give you that information and a little more. Neither will tell you what the displayed resolution is. Here's a table:
Code:
2.610 - 5800 Kbps  (1920 x 1080,  1:1)
1.935 - 4300 Kbps  (1920 x 1080,  1:1)
1.350 - 3000 Kbps  (1280 x  720,  1:1)
1.057 - 2350 Kbps  (1280 x  720,  1:1)
0.787 - 1750 Kbps  ( 720 x  480, 32:27)
0.472 - 1050 Kbps  ( 640 x  480,  4:3)
0.337 -  750 Kbps  ( 512 x  384,  4:3)
0.252 -  560 Kbps  ( 512 x  384,  4:3)
0.169 -  375 Kbps  ( 384 x  288,  4:3)
0.106 -  235 Kbps  ( 320 x  240,  4:3)
(The first column is GB/hour consumed at that bitrate).
post #6754 of 8672 Old 12-08-2014, 09:16 PM
mdavej's Avatar
Quoted: 2161 Post(s)
Liked: 950
Quick question. Why am I getting 1080 SD on my Sony? I thought SD was 480, and 1080 was HD? And why do we park in driveways and drive on parkways? And what if there were no hypothetical questions?
(Carlin)
mdavej is online now
post #6755 of 8672 Old 12-08-2014, 09:42 PM
Mark12547's Avatar
Quoted: 730 Post(s)
Liked: 491
Same reason why I am getting 1080 SD on my Visio Smart TV!
However, I had known since I first saw "1080 SD" that the "SD" part was a bug (meaning, the "1080" part was correct, the "SD" part was incorrect).
My very humble setup:
Spoiler!
Mark12547 is offline
post #6756 of 8672 Old 12-08-2014, 09:55 PM
Westly-C's Avatar
Quoted: 338 Post(s)
Liked: 216
Hmm...thanks. Didn't know the CTRL commands worked inside the app.
CTRL-SHIFT-ALT-D showed a more abbreviated version of the overlay seen in the web browser, with CTRL-SHIFT-ALT-S showing the Stream manager.
Name:	IMG_WIN 8 APP 2.jpg
ID:	409793   Click image for larger version
post #6757 of 8672 Old 12-08-2014, 10:02 PM
nalthien's Avatar
Quoted: 380 Post(s)
Liked: 429
Former Netflix engineer here (I was one of the main developers on the TV UIs for 3 years). I want to correct a misconception here: Netflix does not (and has never) used HD vs "SuperHD" as a designation between 720p and 1080p. "SuperHD" was a marketing term to denote 1080p titles encoded at a higher bitrate than the "normal" 1080p encodes. There were a lot of reasons for this marketing that I can't discuss; however, I did want to clear that particular detail up.
nalthien is offline
post #6758 of 8672 Old 12-08-2014, 11:53 PM
Liked: 1470
Not a misconception. When Netflix announced the Super HD video encodes not nearly all HD titles had them; the Super HD label indicated which ones did and all the others continued to be labelled "HD". Most of those others had 3850 Kbps "normal" 1080p video but some had only 720p video encodes. Now that the 3850 Kbps video encodes have gone away all of the titles labelled simply "HD" in those UIs which still use the "Super HD" designation are 720p-only. Of the dozen or so devices which I own, the only one which still uses the Super HD label is the Win8 Netflix app. Using it to check through my "My List", the following movies are marked simply "HD":
  • Chasing Amy
  • The Cider House Rules
  • Emma
  • Equilibrium
  • Evita
  • An Ideal Husband
  • Leroy and Stitch
  • Life is Beautiful
  • Lilo and Stitch 2: Stitch Has a Glitch
  • Mimic
  • Mulan
  • Pirates of the Caribbean: The Curse of the Black Pearl
  • Playing By Heart
  • The Prophecy
  • The Prophecy 2
  • The Prophecy 3: The Ascent
  • Reservoir Dogs
  • Rounders
  • Slingblade
  • Strictly Ballroom
  • They
All can be verified to max out at 3000 Kbps 720p by playing them and typing CTRL-SHIFT-ALT-S to bring up the Stream Manager dialog which lists the bitrates of all available video encodes. None have the 4300- and 5800 Kbps 1080p video encodes. (Many titles in my queue aren't available in HD at all in the Win8 app but are HD in the device embedded ones; some of those are probably 720p-only. I've run across titles which were 720p-only on PCs which had available 1080p video encodes in device embedded players; if any of those are like that there's no easy way to tell since the elimination of the Super HD label in those players).
Technically though, you're right--Netflix has never used the "HD" label instead of the "Super HD" label to indicated that a title only had 720p video, but to indicate that it didn't have have the 4300- and 5800 Kbps "Super HD" 1080p encodes. Today, however, the only HD titles which don't have those only feature 720p HD video.
post #6759 of 8672 Old 12-09-2014, 06:17 AM
mdavej's Avatar
Liked: 950
Not a bug. It's correct. SD means Super HD.
post #6760 of 8672 Old 12-09-2014, 07:55 AM
nalthien's Avatar
Quoted: 380 Post(s)
Liked: 429
Fair enough; my point was really that, even if it's the case right now, it's mere happenstance due to the change in encodes and the dropping of the "SuperHD" marketing. I only wanted to point out that it wasn't the intended meaning of SuperHD to differentiate between 720 and 1080
nalthien is offline
post #6761 of 8672 Old 12-09-2014, 09:38 AM
reddice's Avatar
Quoted: 599 Post(s)
Liked: 117
The only thing I notice that is in 720p that I know of is some older Disney comedies (expiring Jan 4th I am ticked off about that). After which everything else I notice in HD is at 5800kbps but I only view it on the TV using enabled devices. If I tried the computer at least half the titles would be restricted to 720p or godawful 480p.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-138 K26ARM USB VPN-64K.
My Primary Streaming Devices: Fire TV Box (2nd Gen), Roku Premier (2016).
Cats are the best pets.
reddice is online now
post #6762 of 8672 Old 12-09-2014, 12:04 PM
mailiang's Avatar
Quoted: 869 Post(s)
Liked: 593
Post
Here was my take on SD: Netflix streaming quality
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #6763 of 8672 Old 12-09-2014, 12:57 PM
Liked: 1470
It's a moot point anyway--I fear that soon the "Super HD" designation will be removed from the Win8 app and there'll no longer be any way to be absolutely sure that an HD title only has 720p (well, you can play it and bring up the Stream Manager, but there's no way in the actual UI). I personally wouldn't refuse to watch a title that was 720p-only, but I'm sure that there are people who would. Poor website-player-only subs haven't had a way to determine (on the website) whether a title has any HD video for several months. They can use sites like Instantwatcher to see what's in HD, but it won't tell them if it's not in HD on PCs (other than the Stream Manager, if they're tech-savvy enough to know about it).
post #6764 of 8672 Old 12-10-2014, 12:02 PM
Brian Conrad's Avatar
Quoted: 1514 Post(s)
Liked: 817
I do keep seeing the phenomenon of starting a title and it stays at 480 then stop and resume it will ramp up to 1080. I wonder that that is about?
Brian Conrad is offline
post #6765 of 8672 Old 12-10-2014, 06:27 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3308
Very odd but it happens to me.
Maybe they auto throttle you the first start of a flick with hopes you dont notice. If you stop and start they give you full bandwidth
gadgtfreek is offline
post #6766 of 8672 Old 12-10-2014, 06:46 PM
Liked: 2
I just did a search for Marco Polo on Netflix and I found four trailers all steaming at 4k (2160). I can't wait for the show on Friday. Netflix needs more 4K content now that Amazon is in the game.
mario315 and jhughy2010 like this.
ik2014 is offline
post #6767 of 8672 Old 12-11-2014, 05:45 AM
RocShemp's Avatar
Quoted: 12 Post(s)
BTW, who's Alvin?
Ian
Thanks. I just got Netflix the other day and noticed that designation went completely MIA today. I was wondering if I did something wrong while browsing through the settings or if I was having a connection issue.
RocShemp is offline
post #6768 of 8672 Old 12-12-2014, 05:47 AM
rlb
rlb's Avatar
Quoted: 1736 Post(s)
Liked: 1397
I've viewed a few minutes in UHD of "Marco Polo". To me (it's subjective and I'm sure some will disagree) it appears to be on a quality level with the Black List. Looks like it will be an excellent series (10 episodes are now available).
rlb is online now
post #6769 of 8672 Old 12-12-2014, 12:32 PM
Liked: 1470
I watched the first 10 minutes and I'd agree that interior shots are pretty finely detailed, though I didn't get the same jaw dropping experience as from The Blacklist. I think that problem will be that a lot more of this will be set outdoors, and in broad, panoramic exterior shots, the greater resolution loses impact. But then, I've only watched 10 minutes .
post #6770 of 8672 Old 12-12-2014, 07:30 PM
met_fan's Avatar
Quoted: 52 Post(s)
It looks pretty, but I don't think it's going to win any awards, judging from the first ep.
met_fan is online now
post #6771 of 8672 Old 12-12-2014, 07:39 PM
Liked: 1470
Supposedly lots of sex and skin and violence. They're going for prurient appeal.
post #6772 of 8672 Old 12-12-2014, 08:21 PM
met_fan's Avatar
Quoted: 52 Post(s)
Yeah - I like a good sex scene as much as the next guy...but there's just not much backing it up. I'll probably keep watching anyway as it's a time of year that's kind of between shows for me.
post #6773 of 8672 Old 12-13-2014, 10:32 AM
hmunster2's Avatar
Quoted: 93 Post(s)
Liked: 32
Why only 720p and DD+
I posted in the general networking forum and they suggested I ask here. I have a new Sony 5200 BDP (2014 yr) Blu-ray player. I have the video set to output whatever is coming into it, same for the Digital audio. I have the blurry player connected by Lan cable, but still am only receiving streams in 720p, never see 1080p-I gather from my searches that they are now streaming most titles in 1080p. My second question concerns the audio-I have the Blurry set to output bitrate (not PCM) so it is being decoded by my AVR (bluray is connected with HDMI to AVR). The receiver indicates Dolby Digital + (it actually shows a plus sign)-I thought that Netflix was now streaming in DD5.1 or is DD+the same??
I am new to this whole streaming thing-when I called Netflix, they said that the Sony BDP5200 supports their highest audio and video.
Am I doing something wrong?
hmunster2 is offline
post #6774 of 8672 Old 12-13-2014, 12:22 PM
Liked: 817
My experiment of the week was to get the AT&T recommended range extender the Netgear N300. Though it could keep the connection and work with everything turns out that range extenders aren't good for streaming video and will actually slow them down. The only real use for my Chromecast is the 500+ apps for it and my own software development. I get Netflix fine with the cheap (actually free) Sony S1200 and the entire episode of "Marco Polo" was 1080p. A better choice of router will probably have to wait another year until another competition comes down the street.
post #6775 of 8672 Old 12-13-2014, 03:22 PM
mailiang's Avatar
Quoted: 869 Post(s)
Liked: 593
Who is your ISP and what is your download speed? DD plus is backward compatible with DD. So to answer your question, yes Netflix provides it through your HDMI, but they are pretty much the same. The main difference is that DD plus supports 7.1 audio, DD only supports up to 5.1 channels.
Ian
mailiang is offline
post #6776 of 8672 Old 12-13-2014, 04:53 PM
Liked: 1470
DD+ is only backward compatible with basic DD in the sense that there is a computationally lightweight algorithm for converting it into basic DD with some loss of quality; you cannot play DD+ streams on a device which only has a decoder for basic DD. DD+ is more efficient than basic DD; Dolby would claim that it delivers the same quality at one quarter the bitrate, using their latest encoders. If that claim is true, Netflix's 192 Kbps DD+ should equal basic DD at 384 Kbps (Netflix started with DD+ at 384 Kbps, at a time when Dolby was only claiming it to be twice as efficient as basic DD).
Streaming services like it because it offers more bang for the bit (literally ). Netflix, Amazon, VUDU and M-GO are all using it. Netflix on a limited set of devices streams in basic DD (Apple TV, smart TVs which have only S/PDIF and/or ARC output for their streaming apps); Amazon only recently start streaming DD+, so the set of devices for which you can get DD+ is smaller than the set on which you can get basic DD. Fire TV can be set to output either, as can most if not all BDPs.
jhughy2010 likes this.
post #6777 of 8672 Old 12-13-2014, 08:52 PM
mailiang's Avatar
Quoted: 869 Post(s)
Liked: 593
Thanks, I realize that Mike. We covered this subject some time ago with Roger. My point was that the audio differences are pretty much indiscernible. It's ability to support 7.1 audio should have more impact, as more of those on-line ppv titles, become available.
Ian
RRS1947 likes this.
mailiang is offline
post #6778 of 8672 Old 12-13-2014, 10:04 PM
Liked: 1470
I think that your use of the term "backward compatible" is improper. USB 3.0 is backward compatible since you can plug USB 3.0 devices into USB 2.0 connectors (if they're not USB powered), though you won't get full features. An AVR or other device with only basic DD decoding cannot be used to decode DD+. Sure, you can get pretty much the same sound out of both if you use the right bitrate for each.
I personally don't think that 7.1 sound has much of a future in streaming video. VUDU supposedly offers it (there used to be a collection but it's apparently gone), but does any other service? What portion of the streaming video consuming public has a 7.1 speaker system set up in their home? Increasingly people are going with soundbars.
post #6779 of 8672 Old 12-14-2014, 08:00 AM
hmunster2's Avatar
Quoted: 93 Post(s)
Liked: 32
Ian
Unfortunately Comcast-poor reliability; I have the slowest (lowest) tier-about 3Mbps. I know that they say you should have over 5Mbps at a minimum for HD, but I also saw Netflix's report showing how individual cable providers were basically throttling the signal, so that even if u have 100 Mbps, they were only giving the Netflix signal about 3. I know that Netflix has paid Comcast, but I don't believe that much has changed. So, if I had a higher bit rate and the Netflix signal actually was allowed to come in at that speed, would I then get 1080p?
post #6780 of 8672 Old 12-14-2014, 08:45 AM
Liked: 1
Hi,
I'm having an ongoing issue with Netflix showing a aip-701 error code on a 42" Panasonic S60 plasma TV using the smart TV's built in Netflix application. Every few days the aip-701 code will come up and nothing will play no mater how many times I retry to play the episode or what I chose. All I get is aip-701. The only way I have been able to fix this is to Deauthorize the Neflix account on the S60 and log back in on the TV using the remote control, which is incredibly tedious. Below is a list of what I have done to try to remedy this:
  • Logged out of Netflix on the computer and sign back in
  • Changed my password on my online Netflix account
  • Lowered the picture streaming quality on my online Netflix account
  • Spoke with Netflix (who suggested all the above)
  • Updated the firmware on the Panasonic S60 by downloading it from the Panasonic site and installing it via USB drive
  • Factory reset the TV
  • Spoke with Panasonic who suggested the above
  • Spoke with my ISP who monitored my connection for 48 hours and found no fault
  • Confirmed the download and upload speed on my computer when the issue pops up (25 down/2.5 up)
  • Replaced the CAT5 cables from the TV to the router and from the router to the modem
  • Changed the DNS on the TV to OpenDNS and Google DNS
  • Unplugged and plugged back in the modem and router
  • Replaced the router
  • Complained to my wife, my neighbours, the AVS Forum Panasonic S60 thread
  • Swore, yelled, got in a pissy mood, gave up, tried again days later
Now, since replacing the router my issue has gone from a daily occurrence to happening every 4 or 6 days. I haven't tried connecting the TV via Wi-Fi yet but that is next on my list. I know that all I probably have to do is buy an Apple TV or a Roku but I really want the simplicity of pushing the Netflix button on the TV's remote. I should note that this issue seemed to start right around when Netflix changed its logo.
mr.steevo is offline
Reply Video Download Services & Hardware
