Netflix streaming quality - Page 247 - AVS Forum | Home Theater Discussions And Reviews
 555Likes
post #7381 of 8596 Old 06-13-2015, 09:09 AM
michaeltscott's Avatar
Quoted: 2708 Post(s)
Liked: 1429
Originally Posted by Gary J View Post
As you have said before. This until they add new services and call it a new plan.
They don't have an accurate name for it now; they call it "2-screens + HD" without mentioning the UHD, as they do in the name of the 4-screen plan. Some forum member got 4-screens when they were apparently testing it and still has it at the 2-screen price.
No new service could tempt me to change my plan. It's like being in a rent controlled apartment: D.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #7382 of 8596 Old 06-13-2015, 11:23 AM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
Originally Posted by andyross63 View Post
What ISP do you have? It could have been congestion between your ISP and Netflix's server, or just getting assigned to an overloaded server.
Time Warner Cable.
After I made some minor adjustments to my router about a month ago, I haven't experienced any issues with picture quality.
What router do you have and what adjustments did you make.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-138 K26ARM USB VPN-64K.
My Primary Streaming Devices: Fire TV Box (2nd Gen), Roku Premier (2016).
Cats are the best pets.
reddice is offline
post #7383 of 8596 Old 06-13-2015, 02:07 PM
Mark12547's Avatar
Quoted: 712 Post(s)
Liked: 472
Originally Posted by reddice View Post
I rebooted my router and it improved the stream I was able to get 1080p. Weird how it did not affect the other services. I hope rebooting is not a placebo effect as trouble starts tomorrow at 9 PM.
Especially with my previous router, I noticed that after a few months the Netflix channel on my original-generation Roku would start having various issues. If more threads are used by Netflix for retrieval than for other services, I could imagine a reboot of the router fixing an issue where the router's NAT table was filling up, and indeed when I start noticing the Netflix channel (or the Netflix App on my Smart TV) start having odd issues, rebooting the router usually fixes it.
Back when the modem I was renting was DOCSIS 2, rebooting the modem during congested evening times often restored the expected throughput. Now that the "gateway" I am renting incorporates a DOCSIS 3 modem, I haven't noticed local congestion, probably because instead of locking into only one download QAM channel at bootup and being stuck at that until the next reboot, DOCSIS 3 establishes (in my case) eight download QAM channels so congestion on just a few of those QAM channels don't affect my download rate.
My very humble setup:
Spoiler!
Mark12547 is offline
post #7384 of 8596 Old 06-13-2015, 02:09 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Netgear N600. Software update and 5G channel set to 153 (recommended by tech support).
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #7385 of 8596 Old 06-13-2015, 02:17 PM
Brian Conrad's Avatar
Quoted: 1424 Post(s)
Liked: 744
I've tried rebooting my U-Verse gateway but then looked the IP address and it was always the same as if U-Verse is static IP. Lately all I've seen is problems with "popular" titles where a lot of people are trying to get the same movie. It's like there are only so many ports allocated for that title on the servers. Summer's here and the neighborhood kids will be piling on in the evening so I'll see how it goes. It appears I have fiber to pole.
Brian Conrad is offline
post #7386 of 8596 Old 06-13-2015, 05:05 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Post
I have the same issue and contacted Cablevision. A tech told me the IP does change, but infrequently.
Ian
mailiang is offline
post #7387 of 8596 Old 06-14-2015, 12:11 AM
Mark12547's Avatar
Quoted: 712 Post(s)
Liked: 472
Why worry if the IP changes on reboot?
When the router is rebooted the local IP address might change, or the modem is rebooted the public IP might change, but that has nothing to do with NAT tables nor with which QAM channels are allocated.
Spoiler!
post #7388 of 8596 Old 06-14-2015, 02:49 AM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
I updated my router firmware yesterday and my IP address changed but later when I upgraded my modem to a 16 channel one my IP address stayed the same.
reddice is offline
post #7389 of 8596 Old 06-14-2015, 07:03 AM
andyross63's Avatar
Quoted: 228 Post(s)
Liked: 71
It may vary a bit with each ISP or type of service, but typically the IP address is tied to the MAC address of the router or computer connected to the modem. In a gateway device, the router is built-in, so you may not be able to manually change the MAC. With a separate router/computer, the ISP's DHCP server sees a different MAC, so gives out a different IP. If you have a separate router, you can often manually change it's default MAC to match something else (by copying the connected computer) or manually typing one in, and the modem/ISP will never think anything changed.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is online now
post #7390 of 8596 Old 06-14-2015, 09:10 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
My router provides an option for resetting the IP address, but I never found a use for it.
Ian
mailiang is offline
post #7391 of 8596 Old 06-14-2015, 03:29 PM
DRC72's Avatar
Quoted: 69 Post(s)
Liked: 30
Ian
Comcast is the same.
Sent from my AT&T iPhone 6 Plus using Tapatalk
DRC72 is offline
post #7392 of 8596 Old 06-14-2015, 04:13 PM
Liked: 744
IP addresses were usually on "lease" so when you reset a modem or gateway you would often get a different address. I some cases that might improve your connection. IT networking is not my specialty but some of techs around here might be able to tell you how it works. But we're also just about to run out of IPv4 and most are already set (and using) IPv6 where you would supposedly always have the same address.
Companies charged more for static IPs (I had one for a while with Earthlink for business reasons). They didn't want to give them out to everyone because they feared some could run a server out of their house with a static IP.
post #7393 of 8596 Old 06-15-2015, 12:47 PM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
Streaming was surprisingly good last couple of nights. The only thing was that the videos did not start out in HD like they usually do but once ramped up they stayed in HD. I really only watched Netflix last night until about 9:30 PM then I watched a program on Amazon Instant then played my PS4 so I don't know it it went to crap thanks to OITN"Lame".
reddice is offline
post #7394 of 8596 Old 06-15-2015, 03:22 PM
andyross63's Avatar
Quoted: 228 Post(s)
Liked: 71
Saw an article that Level3 ran into some issues on Friday:
Level 3 outage slows down the internet
reddice likes this.
post #7395 of 8596 Old 06-15-2015, 04:51 PM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
THANK YOU
I don't know where you find these things but I could not find crap about it online because everything happening is on social media which I don't follow because of all the profanity on there. As usual calling Netflix is useless always blaming my ISP. I am not even going to bother calling them anymore. I will only call them if I am having problems with my account like billing issues.
reddice is offline
post #7396 of 8596 Old 06-16-2015, 12:37 PM
Liked: 744
Are these recently released titles? "Daredevil" was still grainy which might be an older codec whereas "El Gringo" was great PQ as was "Free the Nipple". Might be an improved codec as I can't seem them boosting the bitrate without letting subscribers know (in case they might rack up enough to get capped by the evil doers).
post #7397 of 8596 Old 06-16-2015, 12:43 PM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
Yesterday during Arrow it turned to mud. I did ramp up but it still ticked me of. Netflix really needs to get rid of encodes lower than 480p and yes I rather have it buffer then go to a unwatchable picture.
reddice is offline
post #7398 of 8596 Old 06-16-2015, 02:13 PM
UHD Addict
aaronwt's Avatar
Quoted: 5201 Post(s)
Liked: 3106
480P can look like crap too,. depending on the setup and how far away from the screen you are viewing.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #7399 of 8596 Old 06-16-2015, 02:39 PM
Mark12547's Avatar
Quoted: 712 Post(s)
Liked: 472
And it can depend on the source material. I had seen some excellent 480p material (try streaming the original "Mission: Impossible" TV show; the stream I got on my first-generation Roku four years ago to my former HDTV looked very good, so good that I suspect they went back to the 35mm film to generate the streams. Contrast that to my current HDTV streaming a 480p stream, the first episode of "Golden Years", and it was awful with most horizontal movement breaking up with jagged and comb-like appearance on the edges of moving boundaries, just as if the stream was a simple digitizing of the odd lines followed by the digitizing of the even lines. (I stopped after the first episode, not because of the poor interlace artifacts, but because the story was dragging on and I didn't feel like enduring another 6 episodes before a payoff, if any.)
Anyway, today I paid attention to the resolutions the TV reported when ramping up when starting "Eve of Destruction":
  • 240
  • 288
  • 384
  • 480
  • 720
  • 1080
I could definitely do without the first two (240 & 288)
Spoiler!
post #7400 of 8596 Old 06-16-2015, 04:21 PM
mdavej's Avatar
Quoted: 2127 Post(s)
Liked: 940
Netflix runs on lots of devices, probably even some old smart phones with 240 lines. I also wouldn't want Netflix to push 1080p to such a device, eating up my data plan. I vote we leave well enough alone and live with the occasional ramping. It's only TV after all, and it looks great 99.9% of the time, for me at least.
mailiang likes this.
mdavej is online now
post #7401 of 8596 Old 06-16-2015, 04:27 PM
Westly-C's Avatar
Quoted: 323 Post(s)
Liked: 202
The old MI tv series is, in fact, streaming in HD. CBS/Paramount supplied Netflix with HD, after remastering it in high definition, following the footsteps of their HD conversion of the original Star Trek.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is online now
post #7402 of 8596 Old 06-16-2015, 05:13 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
I didn't find Daredevil all that grainy. Some film directors actually prefer it that way.
  • 240
  • 288
  • 384
  • 480
  • 720
  • 1080
Anything along the video chain between the source and the display, can effect PQ. Even the quality of the video transfer. For example, The Following on FOX looked rather grainy, with a lot of dithering on my Panasonic pdp. Yet FOX's Wayward Pine's is much cleaner with more pop.
Ian
mailiang is offline
post #7403 of 8596 Old 06-16-2015, 05:45 PM
Mark12547's Avatar
Quoted: 712 Post(s)
Liked: 472
Nonetheless, I streamed most of Mission: Impossible (TV series) in SD by using the secret bit override screen on the original generation Roku. (It works for "advanced streams" that the original generations of Roku Digital Video Players used; it does not work for the "adaptive streams" that the more recent Roku Digital Video Players use.) I was doing a lot of streaming in those days and I was keeping my eye on the monthly data usage. That's 171 52-minute episodes from April to June in 2011, all viewed on my (then) 46-in Samsung HDTV.
The point was that even if the stream is an SD stream, it is possible that, if taken from an excellent source (and both Mission: Impossible and the original Star Trek were filmed on 35mm stock at Desilu Studios), it can look beautiful! But if an SD stream is taken from a bad source, it will look bad.
(Of course, an SD stream still doesn't have quite the detail that a 720p stream would have, which is the max resolution the Netflix channel on my original model, original generation Roku can handle. Nor does even that have quite the detail that a 1080p stream that my current Visio 50-in Smart TV pulls in.)
Spoiler!
post #7404 of 8596 Old 06-16-2015, 11:33 PM
Liked: 1429
I believe that Daredevil has intention digital "film grain" added. The grain is quite noticeable in the 2160p encode (which kind of makes 2160p useless for the title ). It's an artistic decision. They used that in the interior scenes of the reimagined Battlestar Galactica because they wanted that combat documentary look but couldn't afford to use film production, which was more expensive than digital. I'm not sure what drives the decision in the case of Daredevil.
fredxr2d2 likes this.
post #7405 of 8596 Old 06-17-2015, 01:46 AM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
240p looks horrible on every device even phones and I wish they would just get rid of it. I rather have audio only then if I was on mobile network which I don't even attempt as it uses data.
As for 480p SD streams some do look great as the way they are encoded they look just like the DVD source. It seems however HD content that drops down to 480p looks worse then lets say the DVD of the series. It is like they skimp on encodes lower than 1080p and they think we are all stupid and blind that we don't know the difference.
reddice is offline
post #7406 of 8596 Old 06-17-2015, 12:46 PM
Liked: 744
It doesn't work well for streaming codecs. If a director wants that it should be more exaggerated and use sparingly perhaps to set a scenario that occurred at a previous time from the story. "El Gringo" used such techniques appropriately including blown out scenes ala grindhouse. No one watching would think there is anything wrong with their TV that way as they might seeing grain they don't usually see on a whole episode.
The kind of grain I'm talking about is well known if you shoot video in low light. You will get a very grainy image. Some of the titles Netflix has would show a crystal clear image for well lit scenes but go grainy on low lit. It was not intentional but due to the difficulty of encoding an image like that (the original might not have been grainy). The recent titles including Sense8 did not have this.
post #7407 of 8596 Old 06-17-2015, 06:33 PM
Liked: 1429
You're right--low-light digital video is exactly the level of graininess in Daredevil but it's in every scene, regardless of the level of light.
post #7408 of 8596 Old 06-17-2015, 08:45 PM
barth2k's Avatar
Quoted: 728 Post(s)
Liked: 526
I wish directors would keep in mind not everyone has uber expensive studio quality displays they do. The low light scenes are challenging enough for your average LCD. No need to add fake grain.
barth2k is offline
post #7409 of 8596 Old 06-17-2015, 10:18 PM
Liked: 1429
I suspect that it's meant to be atmospheric, sort of film-noir-esque.
post #7410 of 8596 Old 06-18-2015, 01:48 PM
Liked: 744
"The Walking Dead" always looked worse than it should have because they insisted on having "grain" as a homage to Romero's early movie. I'll have to pop Romero's "The Crazies" BD but I think the grain got filtered.
Watching "Winter Sleep" on Netflix last night there is a very dark scene with no grain at all. It too is recently added and the PQ was superb all the way through.
Reply Video Download Services & Hardware
