How to Rip video from a DVD menu? - AVS Forum
post #1 of 15 Old 12-22-2008, 01:04 AM - Thread Starter
lilbasee's Avatar
Hi..Theres a video id like to rip from a DVD menu but i dont know how to do it or if its possible..Could someone tell me if theres a program i can use to do that? This is what im trying to rip.
http://i11.photobucket.com/albums/a1.../l__l_0001.jpg
The video in the dvd menu. Now i know there has to be some kind of program to find the video with having to crop it..I mean with all this techonolgy these days lol..If someone could help me out id really appreciate it. Thanks.
lilbasee is offline
post #2 of 15 Old 12-22-2008, 04:43 AM
nded's Avatar
Wow, your already up to 4 posts - I'm looking forward to your spam url coming soon.
Ed Qualls - Just Add Power
nded is offline
post #3 of 15 Old 12-28-2008, 05:51 AM
beanl's Avatar
Not too bad
beanl is offline
post #4 of 15 Old 02-03-2009, 08:54 AM
White Dragon's Avatar
I don't understand why nobody helped him out here. I'm wondering how to do the SAME thing.
Mine is different, but oddly enough another wrestling DVD... here's a cap of the one I want to get...
http://www.dvdtalk.com/reviews/image...08634570_3.jpg
White Dragon is offline
post #5 of 15 Old 02-03-2009, 12:25 PM
Brown Radagast's Avatar
Are those video loops something that is in the movie? Is there something different about the loops, such as text overlays, etc.?
MY DILEMMA: New car or PJ? New car or PJ? New car or PJ?
Brown Radagast is offline
post #6 of 15 Old 02-03-2009, 12:34 PM
It's a separate video loop that's approx 2.5 - 3 minutes long. It's only on the main menu, and I'd LOVE to be able to figure out how to break it down and pull just the video clip out of it.
post #7 of 15 Old 02-07-2009, 06:11 AM
Nobody has any ideas on how to go about doing this?
post #8 of 15 Old 02-09-2009, 06:59 AM
Have you ripped the dvd to your PC yet? I was thinking that maybe this is a separate vob file, probably a lot smaller sized file than the movie vobs...
post #9 of 15 Old 02-12-2009, 06:25 AM
Yea, I did rip it to my computer, however, there isn't an individual vob for that video, there's one for the entire menu screen playing that video in the background.
post #10 of 15 Old 02-12-2009, 07:48 AM
duffman13's Avatar
i use a program called dvd shrink, it's free and rips the audio_ts and video_ts folders off the disc. don't know if something like that's what you're looking for, but it's worked great for backing up my collection for years.
duffman13 is offline
post #11 of 15 Old 02-12-2009, 09:05 AM
Varrius's Avatar
Hopefully linking this is ok.
http://www.videohelp.com/
I'm sure it's possible, and I'm sure the answers/tools are there. You will no doubt spend some time researching it though.
Varrius is offline
post #12 of 15 Old 02-12-2009, 09:09 AM
Varrius's Avatar
I don't believe dvdshrink will allow them to capture just a portion of the video/audio out of a vob file (this is what they are needing to do).
I believe the best route would be to rip the vob file to disk (as you mention), then convert it to mp4. They could then use a video editor to extract just the portion(s) they want. I don't recall what tools will be best to do this, but the link I mention above will provide what they need, and most likely free tools too (if you don't need anything fancy).
Varrius is offline
post #13 of 15 Old 02-12-2009, 10:12 AM
Well I have all the tools to just rotate and zoom into the video and pull just what I need... but what I want is the actual video that's behind the menu graphics... and I want to know if there is a way I can pull it out of the vob files.
Think photoshop layers... the top layer is the menu text that you select when watching the dvd... the 2nd layer is the menu graphics itself, then the 1st layer (or layer furthest back) is the video that I'm trying to get to.
post #14 of 15 Old 02-18-2009, 09:55 AM
Varrius's Avatar
Yea, I understood what you were getting at. I don't have that much in depth knowledge myself, so I have no idea how video is put together. It's possible that they've compressed the layers, and outside of using a very advanced video editor type software, you don't stand a chance.
If they haven't compressed the layers together, then with the right software you should be able to extract just one layer. Again, above my knowledge, but if the answer is out there I'd bet you could find it at the site I mentioned above.
Varrius is offline
post #15 of 15 Old 02-19-2009, 06:55 AM
Thanks, I've actually been over there before, a long time ago... I'll see what I can find... thanks for your help.
Reply Video Download Services & Hardware
User Tag List
