Aspect ratio issues - netflix streaming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-04-2010, 06:17 PM - Thread Starter
edit's Avatar
I seem to be having issues when it comes to streaming a movie that is in the
2.35:1 aspect ratio to an HDTV using Netflix streaming. A 2.35:1 movie should have some black on top and bottom on an HDTV. But It seems that the picture is just stretching to the screen edges -so the image fills the 16:9 screen. - This leaves the image still stretched up and down - - - When playing the same movie on a computer - it is displayed properly as 2.35: 1 - - has anyone encountered this problem - -
Streaming via Insignia BluRay player - connected via HDMI -
edit is offline
post #2 of 4 Old 03-04-2010, 06:20 PM
fpconvert's Avatar
I had the same vertical stretch problem w/ a 1:78 ar movie called the Canyon.
Everything else is fine
fpconvert is offline
post #3 of 4 Old 11-18-2010, 01:05 PM
audiomagnate's Avatar
A recent firmware update for current model Samsung Blu-ray players causes all sorts of aspect ratio problems. Old 4:3 movies are stretched and wider than 16:9 is squished. Samsung admitted to me there was a problem (pretty much a first for Samsung, I hope the guy I talked to still has his job!) and that they are working on it. Netflix claims ignorance, but if there is a problem they blame Samsung.
audiomagnate is offline
post #4 of 4 Old 11-19-2010, 12:54 PM
Brian Conrad's Avatar
Quoted: 1424 Post(s)
Liked: 744
Might have something to do with the preparation of the streams. Whatever the workflow is I think sometimes somebody either at the studio, distributor or Netflix screws up. The odd thing about the foreign film I watched the other night that was supposed to be 2:35:1 and was squished horizontally as a 16:9 full screen with the subtitles partly off the screen and I couldn't pop up the progress bar either. Don't know if Samsung screwed up or Netflix.
Brian Conrad is offline
Reply Video Download Services & Hardware
