Best possible Netflix streaming device - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 50Likes
Old 03-08-2011, 02:52 PM
[Irishman]'s Avatar
Quoted: 175 Post(s)
Liked: 121
Originally Posted by Charles R View Post
I think the legacy of supporting over 200 devices causes all kinds of grief. Like with the TiVo they support the TiVo buttons (info, 30 second advance, 10 second skip back, etc) which makes it great using TiVo's remote. The queue is crude and very slow to move around in (even though it's largely text based). So the code isn't even chip dependent it's unique per the device itself (for each generation of the device too in many cases). I figure the earliest they will get back to revisiting the TiVo interface is when a new model is introduced.
I thought that, with the TiVo, the interface was Java or Flash, and slow as molasses.
COMING SOONFinding the Ark of the Covenant by Brian Roberts, in the iBook Store on iTunes, a new investigation into the Hebrew’s Most Sacred Relic!
[Irishman] is offline
Old 03-08-2011, 03:46 PM
michaeltscott's Avatar
Quoted: 2706 Post(s)
Liked: 1429
I just played with it and I certainly wouldn't call it that. It took it 10 seconds to start up (as does my Roku; the PS3 and Xbox take about 20 secs each); it required about 20 seconds to buffer an HD stream (16 on the Roku and Xbox, 2 on the PS3--sort of ) and about 14 seconds to buffer an SD one (about the same on the Roku, 9 on the Xbox, 2 on the PS3). Navigation of the interface is fairly snappy, with a one or two second delay while it sucks in data for the next page of titles (it buffers them, so once you've flipped through them you can scroll back through without delay).
(The PS3 starts streams up so quickly because it's the only one of them using a real adaptive bit rate algorithm--it quickly buffers enough of a low quality stream to get something up on the screen, then ramps up to the highest bit rate available encoding that the speed of your connection to the server will support).
That's on my 4 y/o TiVo S3--the new TiVo Premieres may be slower.
The great deficiency of TiVo's interface is that it cannot browse the entire Netflix library like many newer players can and it cannot add things to your Instant Queue. It does have a complex online search feature which can scan the entire Netflix library.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
Old 03-08-2011, 04:15 PM
dfiler's Avatar
Here is a comparison of a PS3 and an AppleTV2. Note that these are scaled photos from a cheap digital camera. Pictured is the image off a 1080p front projector
This means that relative color and detail should probably be ignored. In real life the images look quite different than the representation here.
What they can show is the type of banding present in large areas of a similar color on the ATV2. There is gradient banding in the green chalk board above Kevin Spacey's shoulder. Some people aren't bothered by this but for me it is distracting when watching netflix on the ATV2. The provided example is a completely average frame. The banding can also be much worse or not present at all, depending on the scene in question.
dfiler is offline
Old 03-08-2011, 04:52 PM
Charles R's Avatar
Liked: 536
Originally Posted by dfiler View Post
Here is a comparison of a PS3 and an AppleTV2..
Do you notice different intra-scene contrast levels? The Apple TV's image appears to be much greater. Look at the washed out collar (brighter) and his tie appears darker. Might just be the camera but this is what I saw when I played with the Apple TV.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Old 03-08-2011, 05:36 PM
Liked: 1429
Originally Posted by michaeltscott View Post
The DMP-BDT110 is cheap enough that I'm tempted to buy one just to screw around with its VieraCast apps (I have the PS3 for BDs, and I can't remember the last time I watched one).
A car repair came in much, much cheaper than expected so I went ahead and ordered one--my birthday's this week, so what the hell .
If I like it for streaming Amazon, I think I'm sending the Roku back.
Old 03-09-2011, 03:44 AM
dfiler's Avatar
I have noticed the appletv to be a bit more saturated and higher contrast. Note how the map in the background looks more neon on the apple tv. Although those pictures are not a fair representation of what is seen in real life.
I eagerly await hearing how it performs. If it can do 24p and dd+, I'll buy one immediately.
dfiler is offline
Old 03-09-2011, 08:27 AM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
There's no reason why the PS3 can't do this- it's just up to Sony to fix. I'm still hoping they do. I don't feel like spending $120+ for another device.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
Old 03-09-2011, 08:28 AM
[Irishman]'s Avatar
Quoted: 175 Post(s)
Liked: 121
No, the problem I'm talking about only affects the Premiere. Slow, and inconsistent GUI (some is HD, some is not), etc.
Old 03-09-2011, 08:30 AM
[Irishman]'s Avatar
Quoted: 175 Post(s)
Liked: 121
I wonder what improvements we'll see when Apple updates the A4 chip in the ATV2 to the new A5? It allowed 1080p output and 9x better graphics on the iPad2.
Old 03-09-2011, 09:20 AM
dfiler's Avatar
I too don't want to spend more money simply for 24p support. With my luck, Sony would fix the issue the day after I bought a device specifically for 24p. Granted, it is just an assumption that the fault lies at Sony's feet. That assumption is based upon the fact that other streaming services (such as vudu) also fail to do 24p on the PS3. The question is, how many months or years should we wait before it is reasonable to give up and spend that money?
The atv2 is nice but it does seem a bit constrained by limited processing power. It does just fine on the officially supported apps and formats. However xbmc sometimes stutters with 720p, or even standard def content with some codecs. Post processing will frequently cause it to drop frames. The hardware of the iPad2 is really close to being sufficient for another decade. Once there is sufficient power to do 1080p without breaking a sweat, we can stop this constant upgrade cycle. At that point, software upgrades will be all that is necessary. My guess is that the eventual AppleTV3 will achieve that level of performance.
dfiler is offline
Old 03-10-2011, 07:05 AM
[Irishman]'s Avatar
Quoted: 175 Post(s)
Liked: 121
Apple TV fans rejoice! Apparently, according to a thread here on AVS, the ATV2 has just added DD support for NF titles that offer it, via firmware update.
So, for those of you who were on the fence on picking one up...
Old 03-10-2011, 11:20 AM - Thread Starter
rpauls's Avatar
I know, that is great news! Now if they could just make the picture quality look as good as the PS3 at 720p... When they finally do my PS3 goes on ebay ;-)
rpauls is offline
Old 03-10-2011, 02:59 PM
[Irishman]'s Avatar
Quoted: 175 Post(s)
Liked: 121
I gotta think it's the A4 chip's fault.
Old 03-10-2011, 03:10 PM - Thread Starter
rpauls's Avatar
Possibly, but my guess is it's just that the PS3 is receiving a different stream than the ATV (even when both are at 720p), and the one the PS3 gets just plain looks better. Either because it is a higher bitrate or it has a better compression algorithm employed.
It would be interesting to do a bitrate test of these two devices.
rpauls is offline
Old 03-10-2011, 03:47 PM
dfiler's Avatar
This is my theory as well.
With xbmc installed on an ATV2, it is easy to see that post processing results in dropped frames on higher bitrate video. Post processing is what I think gives the PS3 better picture quality. It is able to eliminate blocking, banding, and other artifacts present in aggressively compressed video.
In a rather simplified sense, more processing power equates to better post processing.
dfiler is offline
Old 03-11-2011, 06:12 PM
Liked: 1429
Okay--my DMP-BDT110 came yesterday and I've played around with it some. It seems to run the same Netflix player as the PS3 (though it performs a bit differently) and has access to the 5.1 soundtracks and closed captions available on some titles. AFAICT, the presentation is pixel-for-pixel identical to the PS3's--it's an HTML5 app, much of which is dynamically downloaded at startup (which is why there are still multiple variants of it running on the PS3).
I ran a handful of experiments and the player apparently does not have access to 1080p encodings (or, as some would have it, the higher-bit-rate-720p encodings ). It does seem to use the same "DASH"-like tech the PS3 player does, though it doesn't perform quite as well. (DASH, or "Dynamic Adaptive Streaming over HTTP", is an emerging ISO standard for adaptive bit rate video streaming; Netflix and several major tech concerns are supporting the effort--see this). The PS3's player seems to use the adaptive bit rate streaming tech to start streams very nearly instantly (typically 3 seconds or less after pushing PLAY); the BDT110's stream start time is very average, usually 15 seconds or more. The PS3 switches between encodings of different bit rates seamlessly--you can see that it's happening, but it's so smooth it's a bit like watching the focus of a lens sharpen and soften. The BDT110's encoding switches often involve a skipped frame or two, the entire screen flashing black for a fraction of a second. During my playing around with it, conditions on my connection were never so turbulent to make it happen more than a couple of times during stream start--if I saw a lot of that, I'd probably stop watching. The algorithm might be sensitive to that possibility and have provisions to deal with it.
Here are some graphs of bandwidth consumption during Netflix play, 10 minutes of a long high-action sequence at the beginning of The Good, the Bad, the Weird starting about 3 minutes in (I chose it because its PQ has received a lot of praise in these forums). 5.1 audio was explicitly selected (strangely it was the default on the PS3 but not the BDT110). My method was to push PLAY, start a stopwatch when the video appeared and snap a picture of the bandwidth usage graph at 13 minutes. I'd run this before on the PS3, but I did it again as a sanity check--the results turn out to be highly repeatable. If you blow this page up to fill the screen, you'll see the graphs from a single machine displayed side-by-side. The scales are not the same--there doesn't seem to be any way to control that in my router's monitor; pay attention to the TX numbers (in these, the router's reporting bandwidth of data transmitted to the attached devices):
The Roku's buffering algorithm is obviously different; it seems to be loading up and playing until some low-water mark, then loading again, lather, rinse, repeat :
Here's some graphs of the HD version of The Dark Knight as streamed from Amazon on the Panny and the Roku. No 5.1 on this one, but some Amazon streams do have it. Pretty damn decent PQ for the bit rate, though I don't know that I'd feel like I got my money's worth for a $5 new release rental. Again, the Roku's buffering pattern is distinctive:
Note that all of these streaming players start by downloading a large bolus of data--with my Network service it was a 25+ Mbps spike for a couple seconds.
I'm probably going to keep the Panny and return the Roku--I only bought either device to get access to Amazon streaming (a weak excuse for buying a new toy ) and I certainly don't need both. The Roku has more apps (mostly junk), but the Panny does everything I need it to do and has VUDU (VUDU surprisingly gave me another $6 credit for registering a new device on my existing account--sweet ). The Panny has a bunch of other capabilities that I haven't explored yet, like an ability to play content from DLNA servers (not to mention 3D BD playback, though I'm not interested in that). I also got a coupon with the Panny good for a free copy of the 3D Avatar BD.
Old 03-11-2011, 06:22 PM
dfiler's Avatar
Thanks! You've done it again... providing the best netflix streaming analysis available anywhere on the internet!
dfiler is offline
Old 03-11-2011, 09:20 PM - Thread Starter
rpauls's Avatar
Wow! That's impressive reporting. Thanks for taking the time to do this.
It appears the panasonic and the PS3 both run about the same average bitrate for 720p, so I'm guessing the PQ is pretty much equal in this case? But what jumps out, is that although the avg bitrates are the same, the instantaneous bitrates are drastically different. The panasonic has a much more bursty stream, and its maximum bitrate is consequentially much higher than the PS3. I would guess this indicates different buffering schemes are being used, with the PS3 taking more of a "constant bitrate" approach. Most likely this means a little more latency on this stream, but of course that has no impact on home viewing.
The Roku is even more bursty. How very interesting. I also bought a Roku recently to take advantage of that Amazon prime offering.
It is interesting to note that all three streamers show about the same average bitrate for 720p, but in my experience, the PS3 definitely looked much better than the Roku. Your graphs would indicate that whatever the PQ difference was, it was not due to raw bitrate. Two reasons I can think of that may have made the PS3 look better would be (A) it could be using a more effective compression algorithm, or (B) it is doing a lot of post processing as dfiler said.
rpauls is offline
Old 03-11-2011, 09:33 PM - Thread Starter
rpauls's Avatar
Question: Your data show an average bitrate of 4.36 mbps for the Roku HD of the first movie. I think the highest I recall seeing on the Roku debug window on my TV was either 3.5 or 3.8. Do you have the debugging option activated on you Roku yet? What bitrate does your Roku report when it starts playing that movie?
rpauls is offline
Old 03-11-2011, 10:49 PM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
Is the DMP-BDT110 bitstreaming DD+ over Netflix or just DD like the PS3?
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
Old 03-11-2011, 11:51 PM
Liked: 1429
Unfortunately I have a 4 y/o AVR without DD+ decoding; the Panny is extracting the AC-3 core and bitstreaming that to my AVR (it's capable of processing the lossless formats and rendering them as uncompressed 7.1 PCM over HDMI, like the PS3). Others have reported getting DD+ out of it though, in the DMP-BDT110/210/3xx thread.
It's always perplexed me that the 720p stream (High/HD on the PS3) looks to be 4.4 or 4.5 Mbps when it was advertised as being 3.8 Mbps, but now I think that it could be the difference between the bit rate of the stereo sound component and that of DD+. That would make it 700 Kbps richer than whatever the old rate was. But that wouldn't seem to jibe with the Roku's average bit rate being nearly the same as the Panny's. I'm taking some stereo data on the PS3 as I type this and will follow it up with stereo on the Panny.
Old 03-11-2011, 11:56 PM
Liked: 1429
I didn't know about the debug mode of the Roku's Netflix player--I'll try it and get back to you.
Old 03-12-2011, 07:07 AM - Thread Starter
rpauls's Avatar
To enter Roku debug mode use the following sequence on the remote:
home home home home home rew rew rew FF FF
rpauls is offline
Old 03-12-2011, 07:46 AM
Charles R's Avatar
Liked: 536
My receiver reports DD+ (sounds great).
Old 03-12-2011, 07:57 AM
Liked: 1429
Yeah--it was pretty easy to find that out once you mentioned that the mode exists . I tried it last night and it said that the stream was 3.8 Mpbs. I tried to get some data last night but I couldn't reliably get 5 Mbps out of my supposedly 25 Mbps service (I have got to get around to having a chat with Cox ). I'm doing it now, at 7 AM, when there should be much less contention for service from all concerned parties.
Old 03-12-2011, 09:25 AM
spiritfox's Avatar
Nice Work with those graphs. I wonder if the difference between your Panny and Roku is a larger buffer in the Roku? I ask that because my Samsung 6500 really doesn't do all that well compared to Roku and my Apple TV--and I know the ATV has about 8GB to work with so I would bet the graph would be similar to the Roku. I tried an HDX movie on the Samsung but it got downgraded to HD--would be nice to see how it would work on Roku if it were available. So for me, I use the Roku and ATV the most since they never seem to have any picture freeze issues and PQ is quite good. Very interesting for sure.
Bob
spiritfox is offline
Old 03-12-2011, 05:48 PM
Liked: 1429
I took some more data this morning. To start, I tried the PS3 and Panny in 2.0 sound to see if that made much difference. Suprisingly, it didn't account for much (I was expecting it to add 400-700 Kbps to the average):
Then I took some data from the other platforms that I have (all without 5.1 or 1080p capability, of course):
It's also interesting to see the different way that each of these players start:
I thought that the Xbox player was particularly interesting--it sucked down data at a furious pace for about 1 minute, then played from the buffer exclusively for over 2 minutes; interesting tactic. It would be interesting to see how it (and all of the rest of these things) deal with different amounts of available bandwidth at startup.
One problem with interpreting these averages is that we don't know how much video time they represent. The data streamed in 10 minutes doesn't just represent 10 minutes of video, but 10 minutes plus some amount in the buffer, of unknown playback duration. Different buffer sizes and buffering schemes in use by these players prevents us from drawing any firm conclusion about average bit rate.
One thing that I notice about these is that, except for the very beginning (when the Xbox is playing out of that mammoth buffer fill) the curves for TiVo and the Xbox are very nearly identical. The curve for the PC is the least like any of the others (except for the Roku); its average comes closest to the nominal 3.8 Mbps--I think that it may use the smallest buffer of them all.
Unless someone else can think of something else interesting for me to try, I think that will do it for now. I've seen the beginning of The Good, the Bad, the Weird so many times that I believe that I could recite all of the lines, in Mandarin and Korean
Old 03-12-2011, 08:58 PM - Thread Starter
rpauls's Avatar
So the Roku says 3.8 mbps and your graphs say 4.4 mbps. I wonder if the difference can be attributed to header info on the packets? The Roku may be measuring the actual data payload (just the movie) and the router reporting total raw throughput? Just a guess.
rpauls is offline
Old 03-12-2011, 10:35 PM
Liked: 1429
As I said above, I think that the data sent to a streaming player in the 10 minute shown in the graphs does not represent 10 minutes of video. The 10 minutes worth of video played while it was receiving that data is part of it, but at the end of that 10 minutes there's still unplayed video data in the player's buffer. If you stopped sending the stream after that 10 minutes and let the unplayed buffer play to its end, the total duration of the video would be more than 10 minutes; how much more depends upon the size of the player's buffer, the buffering algorithm it uses and the amount of excess bandwidth available.
If you look at the first Roku Netflix graph that I posted (the blue and red one), you'll see the player was sent 319.41 MB of video data in that 10 minutes:
319.41 MB x 8 bits-per-byte = 2555.28 Mbits / 3.8 Mbps = 672.44 seconds
I think that at the end of that 10 minute window, the Roku had approximately 72.44 seconds worth of video left to play in its buffer.
Old 03-12-2011, 11:01 PM
cubiczee's Avatar
Is there anyone else that feels like a ****** looking at those graphs?
cubiczee is offline
Samsung Bd D6700 3d Blu Ray Disc Player
