Adding BBC Iplayer On Samsung Smart TV's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-27-2012, 05:49 PM - Thread Starter
cococ's Avatar
I wanted to watch some of the Olympic coverage the BBC was offering. As most people know the Iplayer app is only available in the UK. This is a method to circumvent it. I have done this on my 51E6500 plasma, a 2012 model. This will only get you the necessary UK apps, you will still need a VPN service as the BBC does an IP check to see where you are coming from.
Go to the Smart Hub Screen
Place the cursor on the 'Samsung Apps' icon
Press FF,2,8,9,RW,Enter
A screen should pop up letting you change the region of the App store, choose the UK.
Voila
NOTE: The Apps you currently have that are not available in the UK will be deleted. They will come back when you switch back to the "US" App store however.
cococ is offline
post #2 of 6 Old 09-28-2012, 05:44 AM
hellsbells5's Avatar
Hi,
Is it possible to add a vpn to the samsung smart tv without buying a cloakbox? I use Witopia but they only deliver the cloakbox to the US and I'm in Dubai.
Thanks for the great tip about bbc iplayer
hellsbells5 is offline
post #3 of 6 Old 10-24-2012, 04:23 PM - Thread Starter
cococ's Avatar
There are many VPN's that can be used anywhere in the world, Unblock and Overplay are 2 that have trial offers, you should be able to see if they work for you in Dubai.
cococ is offline
post #4 of 6 Old 01-02-2013, 07:15 PM
Mike601's Avatar
Cococ,
That's exactly what i am trying to do. unfortunately the magic code you provide doesn't work on a series 7 samsung. Does anyone know the magic code to change App store region.
Cheers,
Mike
Mike601 is offline
post #5 of 6 Old 05-29-2013, 12:17 AM
Emanef's Avatar
Hi guys
Did you find a way to do this? I have a Series 8 2013 Samsung TV and am in Dubai and would like to change the store to add BBC iPlayer and ITV Player (connecting using a VPN).
Emanef is offline
post #6 of 6 Old 05-29-2013, 01:23 AM
Emanef's Avatar
Ah! I found it myself - http://support.unblock-us.com/customer/portal/articles/1138038-samsung-f-series-smart-tv-2013-
You need to be using a VPN to access the page as UAE block Unblockus. It worked for my TV though, got it to the UK app strore and it immediately picked up BBC and ITV players, etc.
Emanef is offline
Reply Video Download Services & Hardware
