Amazon VOD (Prime) gets HD on XBOX but not Roku and Panny Blu-Ray - AVS Forum | Home Theater Discussions And Reviews
Old 09-21-2012, 11:46 AM - Thread Starter
fcwdev's Avatar
Quoted: 54 Post(s)
I'm trying to understand what's the issue here. My XBOX 360 gets the "HD" signal strength indicator all the time (and looks good), however, my ROKU and Panasonic Blu-Ray player hardly ever. They are more or less in the same location. What could be the cause?
I do not prefer using my XBOX because of fan noise and the clunky interface. Ideally my blu-ray player would get the HD connection but hardly ever does. Once it did, but could not sustain it. I have Comcast (30+ mbps burst) and wonder what tricks they may be doing. Perhaps Amazon streams are artificially down throttled (unless via XBOX). Any info is appreciated. (on the blu-ray player) I've tried Wireless G and Wireless N. I may try a wired connection as a test.
fcwdev is offline
Old 09-21-2012, 12:44 PM
rdgrimes's Avatar
Quoted: 2023 Post(s)
Liked: 1355
Using a wired connection to all devices is the only way to level the playing field. Wireless reception is different in each location.
Also, reboot your Comcast modem in case it needs to update firmware. There were some recent updates rolled out by Comcast. Mine has an April 2012 date on the firmware.
rdgrimes is online now
Old 09-24-2012, 12:14 PM - Thread Starter
fcwdev's Avatar
Quoted: 54 Post(s)
Wired connection solves the problem. I now get "HD" on my panasonic blu-ray player. Perhaps the Wireless modem in the player is sub par.
fcwdev is offline
Old 09-24-2012, 02:52 PM
michaeltscott's Avatar
Quoted: 2711 Post(s)
Liked: 1434
It's gotta be pretty frickin' sub-par. HD Amazon Instant Video with 5.1 sound comes in at 2.3 Mbps, or so sayeth Roku's player's debug message. You wouldn't need more than 3.5 Mbps or so to keep ahead of that.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is online now
Old 09-24-2012, 06:11 PM
UHD Addict
aaronwt's Avatar
Quoted: 5233 Post(s)
Liked: 3131
Nothing on the Roku should be an issue for wifi streaming if the wireless N network is setup properly.. Even 9Mb/s from VUDU 3 bar HDX should be no issue for wifi on the Roku2. Mine always connects at a 65Mb/s rate(20Mhz bandwidth) to my APs so it should be good for half that bandwidth of 32.5Mb/s. And of course none of the streaming services come close to 32.5Mb/s. Whether they are connected wirelessly or wired mine are just as fast with the streaming services.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
Old 09-25-2012, 09:30 AM - Thread Starter
fcwdev's Avatar
Quoted: 54 Post(s)
I am using Wireless G. I'm not sure if my ROKU has Wireless N, it is an older model then the current batch. Anyways, more specifically, are there settings in my Netgear router that I should be using to be "setup properly". Thanks
fcwdev is offline
Old 09-26-2012, 12:54 PM
Liked: 1434
You should probably check out the "Optimize your streaming experience", "Compatible Wireless Routers and Access Points" and "FAQ: Networking 101 and your Roku Player" threads in the Roku Forums.
