Netflix Ps3 app no longer shows quality? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 10-09-2012, 04:09 PM - Thread Starter
mproper's Avatar
Started watching something tonite and my ps3 is now only showing the time/time remaining and audio....no video quality indicator.
Was working last night, and I didn't get any updates. I really hope they didn't get rid of it like on other devices.
Anyone else?
mproper is offline
post #2 of 16 Old 10-09-2012, 09:00 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi mproper, no issue here but another member (hsedsie) posted the issue in the PS3 thread.
JChin is online now
post #3 of 16 Old 10-09-2012, 09:58 PM
Westly-C's Avatar
Quoted: 351 Post(s)
Liked: 224
It's there for me as well.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is offline
post #4 of 16 Old 10-15-2012, 07:24 PM - Thread Starter
mproper's Avatar
Figured I'd try again later, but it's now only showing time. Tried several titles (The Ward, Boy Wonder and Twin Peaks) and none are showing either the sound or the quality indicators.
I am annoyed.
EDIT: Ok... Two minutes later... Now showing the sound on The Ward (5.1). Maybe it's not showing it if it's stereo and it had to ramp up?
Trying Cheers (a stereo title) and no sound indicator. Let it run a few minutes and it never showed up.
mproper is offline
post #5 of 16 Old 10-16-2012, 10:38 AM
MA5CMPB's Avatar
Its not showing up for me either. I get the time & sound options but not video quality.
MA5CMPB is offline
post #6 of 16 Old 10-16-2012, 03:51 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
Same with me too. Started a couple of weeks ago first with not displaying audio and then since last Thursday not displaying the video quality. I deleted the game data and app but it still does not work. Also when watching SD or HD content sometimes the quality would drop for about 15 to 30 seconds which looks real bad then it is fine. Also the interface is worse now because the titles are smaller and misaligned.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-140 K26ARM USB VPN-64K.
My Primary Streaming Devices: Fire TV Box (2nd Gen), Roku Premiere.
Cats are the best pets.
reddice is offline
post #7 of 16 Old 10-17-2012, 07:35 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi mproper, try all three titles and still display time, video and sound. Wonder if this issue is with certain location (ie. east coast, west coast)?
JChin is online now
post #8 of 16 Old 10-20-2012, 09:47 AM
michaeltscott's Avatar
Quoted: 2844 Post(s)
Liked: 1516
I reported this in a few threads the other day, asking if others had seen the same problem. I have a launch model 60 GB PS3 and nothing that I've tried will get its Netflix player to show the "Video" line in that information overlay. I also have a Sony BDP-S390 BD player whose Netflix player has the same feature which is also partially broken. The PS3 will only display time, unless I change the audio option or enable subtitles; the S390 displays the Video line, but will not dynamically update it--turning the overlay off and back on will get the currently correct value displayed, but it won't change if the encode changes.
Not actually a bug, since that information overlay is not an advertised feature of the player, however much some of us enjoy it. If you want to get a quick read on whether you're currently getting the higher bit rate encodes from Netflix, play Example Short 23.976, a test clip which has an overlay with bit rate and resolution information burned into every encode. I know, it's not the same thing.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #9 of 16 Old 10-20-2012, 05:11 PM
Tom Bley's Avatar
Quoted: 707 Post(s)
Liked: 639
Same here. I just discovered this thread. I noticed this a couple weeks ago. I'm annoyed, I used the feature quite often.
Tom Bley is offline
post #10 of 16 Old 10-23-2012, 05:48 PM
StormCrow's Avatar
Quoted: 69 Post(s)
Liked: 114
Maybe they are downgrading the streams and don't want it to be readily apparent?
If I'm playing X-HD, I always check to make sure it toggles up. Can't do that now....
StormCrow is offline
post #11 of 16 Old 10-27-2012, 06:10 PM
StormCrow's Avatar
Quoted: 69 Post(s)
Liked: 114
Without any update since last I checked....I just pushed select while watching Walking Dead and it once again shows stream quality!
post #12 of 16 Old 10-27-2012, 07:26 PM
Liked: 1516
Works for me now as well, though I was forced to take the 4.30 system firmware update before I could run a network app.
post #13 of 16 Old 10-31-2012, 07:00 AM - Thread Starter
mproper's Avatar
Yep, mine was back last night as well. Whew.
mproper is offline
post #14 of 16 Old 11-01-2012, 10:06 AM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
It started showing video quality again for me too however I still have the problem with it sometimes dropping down to crappy Low/SD quality for about 15-30 seconds and It does not matter if I am watching SD or HD. Low/SD is pathetic and should not even be a encoding option come on it is 320x240 resolution. Actually I have a bunch of 320x240 videos on my computer that look better than Low/SD. mad.gif
reddice is offline
post #15 of 16 Old 11-01-2012, 10:54 AM
MA5CMPB's Avatar
Mine is showing up as well.
Has anybody tried syncing this up with their iPhone? Its pretty cool.
Directions:
Open the iPhone Netflix app and the ps3 app. Browse with your phone until you find a movie or tv show that you want to watch. When you select the video it'll ask you if you want to watch the video on your phone or on the ps3. If you select ps3 you can continue to browse and queue up other videos on your phone.
MA5CMPB is offline
post #16 of 16 Old 11-01-2012, 04:05 PM
reddice's Avatar
Quoted: 603 Post(s)
Liked: 117
I deleted the Netflix app on my 4th Gen iPod Touch since it runs like crud. It is slow, laggy and crashes. The 4th Gen is a POS anyway and I might upgrade to the 5th Gen when I can get a good deal on one.
reddice is offline
Reply Video Download Services & Hardware
