Tsmuxer 1.10.6 replacement - AVS Forum | Home Theater Discussions And Reviews
Old 12-30-2012, 07:00 PM - Thread Starter
fits79's Avatar
Quoted: 46 Post(s)
Hi.
I just want to know if there is any newer version of that program or if there is any other program that can replace that one.
A LOT OF THANKS.
fits79 is offline
Old 12-31-2012, 01:05 PM
Brian Conrad's Avatar
Quoted: 1425 Post(s)
Liked: 744
I just use ffmpeg with a -i inputfile.ts -vcodec copy -acodec copy to outputfile.mpg. That usually works just fine unless it has some sync error with the .ts file then seeking in a bit where ffmpeg will find the first full frame will solve that problem.
Brian Conrad is offline
