PS3 1080p, is it super hd? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-14-2013, 10:24 AM - Thread Starter
plasma21's Avatar
I know there is a long thread on the topic of super hd, i just had a simple question.
Is the 1080p i see on ps3 these days super hd? I have fios, not part of netflx open connect. If 1080p is not super hd, is there an even higher resolution displayed when ps3 plays super hd?
plasma21 is offline
post #2 of 4 Old 02-14-2013, 10:30 AM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 895
Nope, regular HD. Still better than 720p HD though.
ambesolman is offline
post #3 of 4 Old 02-15-2013, 06:36 AM
UHD Addict
aaronwt's Avatar
Quoted: 5193 Post(s)
Liked: 3102
It will show "1080 Super HD" when playing the Super HD encodes. While the regular 1080P encodes shows up as "1080 HD"
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #4 of 4 Old 02-16-2013, 07:59 PM
michaeltscott's Avatar
Quoted: 2706 Post(s)
Liked: 1429
Super HD is not a higher resolution, just a higher bit rate 1080p video encode. The regular "1080p HD" is 3850 Kbps and "1080p Super HD" is either 4300 Kbps or 5800 Kbps. The extra bits should provide a sharper picture (5800 Kbps is half again as high as 3850 Kbps), though we have no objective proof that it actually does.
Some of us have been getting Super HD with ISPs who aren't signed up to access Open Connect using a method discussed in the Super HD thread starting with this post. There are caveats--you should read through to the end of the thread to hear some of the problems we've seen and the workarounds we've found.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
Reply Video Download Services & Hardware
