Roku 3 for MKV playback and HD audio. Your thoughts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-11-2013, 12:08 PM - Thread Starter
adamnyholt's Avatar
Hi there. I'm looking for the best STB for playing back full-size uncompressed blu-ray rips in MKV format with DTS-HD audio support. Everything I've read seems to show that the Roku will do this. It supports MKV files, and will pass-through the HD audio. it also has a USB for connection to an external HDD.
Do you guys have any experience using the Roku for this? Is there a box you'd recommend more?
Adam Nyholt
www.nyholt.com
adamnyholt is offline
post #2 of 3 Old 05-12-2013, 09:25 AM
michaeltscott's Avatar
Quoted: 2708 Post(s)
Liked: 1429
You might want to post this ask in the "Networking, Media Servers & Content Streaming" forum. That being said, Rokus are definitely not the best device for your purposes; its file playing capabilities are extremely limited. If you want something with an ability to also stream network VOD services like Netflix, VUDU and Hulu Plus, I'd recommend the WD TV Live. I recently bought one and was astonished at the range of files that it will play. If you don't care about network VOD there are plethora of other choices; see the other forum for those.
If your file playback needs are within the Roku's capabilities then it'll work for the purpose though the USB channel UI is pretty drab.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #3 of 3 Old 05-13-2013, 01:54 PM - Thread Starter
adamnyholt's Avatar
Thanks a lot, michael. I'll check out that forum. For general VOD, I like the apple TV. So I'm happy to get whatever box works best simply for playing back MKVs from a HDD.
Adam Nyholt
www.nyholt.com
Reply Video Download Services & Hardware
