Netflix /Silverlight tips how to force HD play manual bit rate selection diagnostics and KB shortcuts - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By tubetwister
post #1 of 11 Old 06-27-2013, 02:20 AM - Thread Starter
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
FORCE HD on NETFLIX EDIT:
PC
Set Netflix Silverlight Bit Rate on PC easy way
While a netflix video is playing (not full screen ) you can also have the mouse pointer on the video in a clear spot away from (above) progress bar and hold down the shift and alt keys only while left clicking on mouse
this will open up an dialog box you can select stream manager there.
For some reason I could not find this exact procedure on the web I figured this out (more likely on accident) when trying some that I read about . I use this all the time in WMC or Browser. Everybody else was saying 3 or 4 keystrokes + clicking mouse or without clicking mouse ,while they will work it is not necessary if you would rather use mouse + 2 keys only
Usually ,2300- 4500 for 720p (see chart below ) or even better (4500 + for 1080p 6000+ for super HD 1080p if you have it ) NOTE : I have done min. HD as low as 2300 but it buffers and is not always stable there.
if have a 3mbps or less service just use the highest one visible or automatic. You *can get stable HD on solid 3mbps conn it will not be 1080p however 720p will be it and it will ramp up slow and if you move progress bar forget it you will forever be in buffer world. .
1.0 - 2.3 Mb/s for SD — Standard definition video
2.3 Mb/s - 4.5 Mbs for HD — High definition 720p resolution video
4.5 Mb/s - 9 Mb/s for HDX — Full high definition 1080p resolution video and high definition audio 6 Mbps + for Netflix super HD
open connect is no longer required for netflix super HD (high bitrate 1080p)
Over 9 Mb/s for 3-D HD movies
Netflix Doubles Video Quality Making 6Mbps SuperHD Streams Available To Everyone
Consumers using ISPs that aren’t in Netflix’s Open Connect program, have to date, been shut of out getting Netflix’s best video quality, dubbed “SuperHD”. But starting today, Netflix announced that all consumers can now get SuperHD quality, on limited devices, even if their ISP doesn’t participate in Netflix’s Open Connect initiative. Netflix only has a limited amount of content available in SuperHD and not all devices support it, but for the ones that do, SuperHD content will now be streamed at double the quality before.
Previously, Netflix highest quality video, available to those with ISPs not in the Open Connect program, was encoded at 3850Kbps. With SuperHD, video is encoded at 4300Kbps and 5800Kbps and adding the audio bitrate brings SuperHD encodes to about 4.5Mbps and 6.0Mbps. Netflix is essentially doubling the quality of their video, for a limited amount of their content. Currently any 1080p version of Apple TV and Roku supports SuperHD as well as the PS3, Nintendo Wii U, TiVo Premiere and Windows 8 app. Note that SuperHD is not available via computer browsers and can only be seen on the PC for those that use the Windows 8 app.
read more
http://blog.streamingmedia.com/2013/...-everyone.html
MAC
MAC (Ctrl+Shift+Option+S for Mac) : Stream Manger (Stream bit rate; Manual rate selection)
Alt PC method
PC Ctrl+Shift+Alt+S or Shift +Alt+ Left Click
To use the following shortcuts, you  may or may not have to  exit Full Screen Mode:
Keyboard shorcuts
F : To enable Full Screen Mode
Esc : To exit Full Screen Mode
PgUp : Play
PgDn : Pause
Space or Enter : Toggle between Play and Pause
Ctrl+Space : Pauses movie and shows and enters Key Frame Viewer; use arrow keys to fast forward or rewind.
NOTE: click manual set in dialog box set 1750 or higher works good for HD
Video may play at lower resolution for a few minutes then buffer for HD while still playing then play HD you may or may not have to do this with every HD movie YMMV .
This is for Netflix in Chrome or Firefox browser should work same in IE. I have not tried this in Netflix for WMC .
No Joy on Amazon Prime . on there you have to have a "compatible device "
Additional Silverlight Netflix Shortcuts
Ctrl+Shift+Alt+M (Ctrl+Shift+Option+M for Mac) : Access the Diagnostics Menu
Ctrl+Shift+Alt+D (Ctrl+Shift+Option+D for Mac) : A/V stats
Ctrl+Shift+Alt+P (Ctrl+Shift+Option+P for Mac) : Player info
Note: To close any of the above windows, simply repeat the keyboard shortcut.
or close dialog box with mouse.
source: http://www.tech-recipes.com/rx/7854/netflix-movie-player-use-keyboard-shortcuts-when-viewing-watch-instantly-videos/
NOTE: On Netflix page you can select Watch Instantly + SHOW HD for PC / Mac or SHOW ALL HD works on both.
Blue Rain likes this.
tubetwister is offline
post #2 of 11 Old 08-18-2013, 12:02 AM
TJAB98's Avatar
Can I just say I love you for this:D:D:)smile.gif
TJAB98 is offline
post #3 of 11 Old 08-22-2013, 02:50 PM
michaeltscott's Avatar
Quoted: 2706 Post(s)
Liked: 1429
I didn't realize that everyone didn't know about these biggrin.gif.
A couple of notes. In the website player, you have to click the picture to give it keyboard focus. The player will not respond to the CTRL-SHIFT-ALT commands when in full-screen mode, though if you bring up one of the overlay displays it will remain up when you switch to full-screen.
1750 Kbps is 480x720 which is not HD.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #4 of 11 Old 08-22-2013, 04:12 PM
reddice's Avatar
Quoted: 597 Post(s)
Liked: 113
Thanks. No wonder why I could not get the info to display when watching on the website. I tried with when I had the videos full screen. The W8 App worked with the commands fine.
Charter Spectrum powered by Earthlink.
My Router: Netgear R7000 - Advanced Tomato 3.4-138 K26ARM USB VPN-64K.
My Primary Streaming Devices: Fire TV Box (2nd Gen), Roku Premier (2016).
Cats are the best pets.
reddice is offline
post #5 of 11 Old 10-14-2013, 11:10 PM
bluefortytwo's Avatar
Cant get the diagnostics menu to open. using PC and not in full screen mode.
bluefortytwo is offline
post #6 of 11 Old 10-14-2013, 11:56 PM
Westly-C's Avatar
Quoted: 321 Post(s)
Liked: 200
Make sure the pointer is not in video window and click the mouse with the cursor in the thin black space between the video and bottom of the browser frame. Then press the 4 buttons CTRL-SHIFT-ALT-D.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is offline
post #7 of 11 Old 10-15-2013, 12:10 AM
Liked: 1429
You have to left-click the picture area to give it keyboard focus.
post #8 of 11 Old 10-15-2013, 12:11 AM - Thread Starter
Liked: 622
I will repeat my fist post in simpler terms
It is just like michael scott says or otherwise you can also :
PC
using just a mouse
While a netflix video is playing (not full screen ) you can also have the mouse pointer on the video in a clear spot ( edit on the movie as it plays ) away from (above) progress bar at the same time hold down the shift and alt keys only while left clicking on mouse
For some reason I could not find this exact procedure on the web I figured this out (more likely on accident) when trying some that I read about . I use this all the time in WMC or Browser. Everybody else was saying 3 or 4 keystrokes + clicking mouse or without clicking mouse ,while they will work it is not necessary if you would rather use mouse + 2 keys only .
post #9 of 11 Old 10-15-2013, 12:14 AM
Liked: 1429
Click anywhere on the picture itself before typing the command. It's as simple as that. You can click the header of the window and it won't work; you have to click the picture.
post #10 of 11 Old 03-29-2014, 09:40 AM
jcmson23's Avatar
Is this corrected in Win 8 8.1? I have been searching silverlight discussion for a way to have silverlight do this automatically. I use PlayLater recorder, which should be able to record in 720p but no matter how long I let a movie run in IE at HD, I can not get the buffering to work with Playlater which works without opening IE, so no way to access manual buffering setting. I was hoping that using this setting through IE and playing long enough in HD might force it to default to that.
BTW, when you check manual buffering, if you want HD immediately drag time played to beginning of movie. It will not start until bufferer is ready for HD Play.
Any ideas for Win 7"
Do you still need to buffer in Windows 8? From what I have read it is not an issue
The commands seem to work in win 7 full screen now.
jcmson23 is offline
post #11 of 11 Old 11-14-2014, 10:40 AM
Liked: 0
On pc and mac if you use chrome there is a chrome extension called super netflix, It can do all that without have to touch the keyboard, Its really useful when you watch sitcoms and you have to change quality every 20 minutes with all ctrl shift ......
And even have more features such as control the volume with mouse wheel and upload subtitles
Jimmy Todd is offline
Reply Video Download Services & Hardware
