100 Mbit and 1000 Mbit/s Routers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 06-27-2013, 08:12 PM - Thread Starter
frankmrt's Avatar
Can anybody explain why I can't get 3D and Super HD with a 100 Mbit router? and with a 1000 Mbit/s I can. Thanks.confused.gif
"By learning you will teach; by teaching you will learn."
frankmrt is offline
post #2 of 15 Old 06-28-2013, 01:42 AM
biliam1982's Avatar
Quoted: 345 Post(s)
Liked: 170
I assume you're talking about NF?
What's your internet speed?
What ISP do you go through?
biliam1982 is online now
post #3 of 15 Old 06-28-2013, 06:48 AM - Thread Starter
frankmrt's Avatar
Yes, I have 30/4 Mb and my ISP is Charter. I spoke with Netflix's CS but they don't know anything about that.
frankmrt is offline
post #4 of 15 Old 06-28-2013, 07:47 AM
Mr.G's Avatar
Quoted: 607 Post(s)
Liked: 313
Charter doesn't support Super HD everywhere but I've heard a few areas in the country have gotten this capability.
What does your browser say when you visit this webpage?
https://signup.netflix.com/superhd
If it says "Your Internet Provider is not configured for Super HD yet" then you're out of luck.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #5 of 15 Old 06-28-2013, 10:46 AM
Westly-C's Avatar
Quoted: 329 Post(s)
Liked: 206
Ok, you've got 2 routers...one gets Super HD and 3D, but the other doesn't?
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is offline
post #6 of 15 Old 06-28-2013, 11:17 AM - Thread Starter
frankmrt's Avatar
Yes, I have 2 routers the 100Mbit is my spare router which I just was testing with NF says that I don't have Super HD but when I put back my 1000 Mb/s router in my network it says I do have Super HD.
@ Mr.G I use that NF link to test for Super HD.
frankmrt is offline
post #7 of 15 Old 06-28-2013, 02:35 PM
Mr.G's Avatar
Quoted: 607 Post(s)
Liked: 313
I'm sorry I didn't read your initial post carefully enough. I don't know what your router(s) issue is.
Mr.G is offline
post #8 of 15 Old 06-28-2013, 02:40 PM - Thread Starter
frankmrt's Avatar
No problem.
frankmrt is offline
post #9 of 15 Old 06-29-2013, 02:00 PM
UHD Addict
aaronwt's Avatar
Quoted: 5221 Post(s)
Liked: 3123
Are they both using the same DNS IP addresses?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #10 of 15 Old 06-29-2013, 02:52 PM - Thread Starter
frankmrt's Avatar
Yes, set up is the same when I switch the routers. Nothing changes just the routers.
frankmrt is offline
post #11 of 15 Old 06-29-2013, 03:28 PM
gregzoll's Avatar
Liked: 33
Probably because the Router with Gig can handle the packets better, along with IGMP and Multicasting better.
You never posted make and models of the two routers, so nothing to tell you the comparission between the two.
gregzoll is offline
post #12 of 15 Old 06-29-2013, 04:09 PM - Thread Starter
frankmrt's Avatar
I have the Asus RT-N56U 1000Mbit and the spare Trendnet TEW-731BR 100Mbit routers. I also watch Netflix on my PS3. I also tried without the routers, from my modem (Cisco DCP3008) directly to my PS3 and I don't get Super HD either.
frankmrt is offline
post #13 of 15 Old 06-29-2013, 05:15 PM
gregzoll's Avatar
Liked: 33
Really cannot tell you about this glitch. If you cannot get it after changing the routers, or direct to the modem, you just found a glitch in the system that one time.
gregzoll is offline
post #14 of 15 Old 06-29-2013, 05:25 PM - Thread Starter
frankmrt's Avatar
Yeah, It is a glitch nobody knows about it I guess.
frankmrt is offline
post #15 of 15 Old 06-30-2013, 05:14 PM
JakeTheSnake783's Avatar
Routers have different CPU's and hardware etc. They might advertise a certain speed because the port can support 100Mb/s or 1Gbit etc but in reality the rest of the hardware components are too slow. Which can happen for cheapo or overpriced routers.
frankmrt likes this.
JakeTheSnake783 is offline
Reply Video Download Services & Hardware
