What devices support Netflix Super HD and 24p? - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #271 of 278 Old 10-05-2017, 04:47 AM
gorman42's Avatar
Quoted: 96 Post(s)
Liked: 51
Originally Posted by Brian Conrad View Post
Inverse telecine has been around since DVD players were introduced. Most all movies on DVD are 24fps. Makes sense as you can put more on a disc at 24fps than at 30. And about any fps can be handled by most streaming players and smart TVs these days. It's done by showing whatever frame is available in the fame buffer regardless of the refresh rate is on the TV. Timing is done by microseconds and synchronization with the audio dropping frames to keep up if necessary. It was fun figuring this out for a Sony PSP game where I couldn't use their h264 player.
Sure, everything can be handled, that doesn't cancel the fact that if the console displays 24Hz or 50Hz content at 60Hz it looks like juddery crap.
In the Advanced Video Settings there are two specific checkboxes to allow *Apps and programs* to switch to either 24Hz or 50Hz according to what's needed.
The Blu-Ray player app is capable of doing this, the DVB-T USB key is capable of doing this when watching European broadcast channels. Everything works as it should.
Now TV (Sky internet app), Prime Video, Netflix, YouTube, etc. do not do this. I don't even know who could be responsible for this. If it's Microsoft because, so far, I've only seen their apps working correctly (hence devs maybe don't have access to the needed API) or if it's the apps developers.
Seriously. AVS is a place where you go to learn to be unhappy. - Bear5k
gorman42 is offline
post #272 of 278 Old 10-05-2017, 10:54 AM
Brian Conrad's Avatar
Quoted: 1745 Post(s)
Liked: 1004
Judder is in film too. I just think TV watchers became more aware of it when DVD and particularly BD became available. Cinematographers have panning charts to pan slowly enough with film to avoid judder but they don't always do that. I suspect the same charts can aid judder on streaming codecs. Then there is the problem that stuff isn't always encoded at the best because it takes more time and that costs more money.
Brian Conrad is offline
post #273 of 278 Old 10-06-2017, 10:23 AM
Mr.G's Avatar
Quoted: 766 Post(s)
Liked: 441
It appears that Roku has heard and responded to complaints of people wishing 24p compatibility with their hardware.
The new Roku OS 8 firmware will be rolling out to owners. Several other fixes and enhancements are also part of the new OS.
http://cordcuttersnews.com/first-loo...w-home-screen/
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #274 of 278 Old 10-06-2017, 11:22 AM
Keenan's Avatar
Quoted: 2523 Post(s)
Liked: 2376
It's about time! This is the primary reason why I rarely use my Roku; no 24fps output. If it now does auto-switching framerate, and it does it properly, then it now has a shot at being my go-to streaming device. Currently, it's just been another box with a shiny surface I have to dust off every month!
Keenan is offline
post #275 of 278 Old 10-06-2017, 11:26 AM
Liked: 1004
Sometimes depends on the TV. 24fps is easy to do on a 120hz display, you just show each frame 5 times. 25fps is another matter. Do you slow it to 24fps and adjust the audio? Or do you drop frame? On the Shield TV I could set 24fps default but 25fps British offerings on Netflix had an annoying frame drop.
post #276 of 278 Old 10-06-2017, 11:39 AM
Keenan's Avatar
Liked: 2376
I have a Samsung plasma and it seems to handle just about any framerate thrown at it with ease. I also send the streaming device output to a Oppo 103D before sending it on to the display and it has a world-class video processing section that handles everything perfectly as well. I noticed just the other day when I was watching the French drama "Spin" from Walter Presents(Amazon Channel) it was getting a 50Hz signal and the Oppo handled that signal with ease. My issue has always been just getting the correct signal out of the source device as the rest of my signal chain is more than capable of handling it.
Keenan is offline
post #277 of 278 Old 10-06-2017, 01:41 PM
Liked: 1004
Certainly high end gear should be capable of that but there's not that much to showing a frame rate that even a bargain device can't handle it. Case in point my "free" Sony BD player which is their low end 2015 model can handle any frame rate too (except that Sony doesn't seem to like non Region PAL BDs though Samsung is okay with them). Sony probably does it the same way their h264 api on game consoles does by how many microseconds per frame you display until moving on to the next frame. That's 1000000/24 (or 23.93). You set a countdown time and when it goes off flip the frame buffer. That's why such devices can play all kinds of video files off the Internet that are at different frame rates.
On the Shield TV I can see what Netflix is serving by running a program that can read the debug logs. Stuff from PAL countries is often 25 fps. No drop frame needed for PAL in countries that have it. I can't on the Roku TV unless there is some hidden development debug command (which should exist).
Keenan likes this.
post #278 of 278 Old 10-09-2017, 08:18 PM
dwaleke's Avatar
Quoted: 1144 Post(s)
Liked: 541
Roku Ultra OS 8 is the first device that I've used that auto switches Netflix to 24fps (also 25 and 30). Also appears to drop to 4:2:0 output which is native video sub sampling.
dwaleke is online now
Reply Video Download Services & Hardware
