iPad Air Netflix in 1080p? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-16-2014, 04:41 PM - Thread Starter
anonAVS's Avatar
What is the max Netflix stream bit rate you can get on iPad Airs?
I thought we were supposed to be able to stream in 1080p (3850kbps), but I never go above 720p (3000kbps) - according to the available example videos.
anonAVS is offline
post #2 of 9 Old 03-16-2014, 04:59 PM
Westly-C's Avatar
Quoted: 348 Post(s)
Liked: 221
Check in  the iPad's settings, under Device Info, and see what the resolution of the screen is. The screen has to be higher than 720p to get a stream higher than that.
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is online now
post #3 of 9 Old 03-16-2014, 05:32 PM - Thread Starter
anonAVS's Avatar
iPad Air screens are 2048 x 1536, more than enough for 1080p.
anonAVS is offline
post #4 of 9 Old 03-17-2014, 11:35 AM
metalsaber's Avatar
Quoted: 1027 Post(s)
Liked: 827
I haven't been able to achieve anything past 720p on my iPad Air. Not sure why.
metalsaber is offline
post #5 of 9 Old 03-17-2014, 12:57 PM - Thread Starter
anonAVS's Avatar
Engadget says that they confirmed it would max at 720p on iPhone/iPod and 1080p on iPad (http://www.engadget.com/2013/10/03/netflix-5-ios-hd-video-airplay/), but it seems like all iOS devices are maxed at 720p.
anonAVS is offline
post #6 of 9 Old 03-17-2014, 02:17 PM
andyross63's Avatar
Quoted: 264 Post(s)
Liked: 86
Even on an iPad, could you really notice the difference between 720 and 1080 without putting your nose on the screen?
reddice likes this.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is offline
post #7 of 9 Old 03-17-2014, 11:55 PM - Thread Starter
anonAVS's Avatar
I would think almost certainly yes.
anonAVS is offline
post #8 of 9 Old 03-20-2014, 02:51 PM - Thread Starter
anonAVS's Avatar
While playing the test video today (to test something completely unrelated) I did (briefly) get a 1080p stream on my iPad air today, so I can confirm that it is possible. As to why we're all staying at 720p most of the time is still a mystery.
anonAVS is offline
post #9 of 9 Old 03-23-2014, 01:41 PM
metalsaber's Avatar
Liked: 827
Just tried out the test video and was able to get 1080p @4300kbps.
Reply Video Download Services & Hardware
