Netflix Dolby Digital Plus 5.1 Bitrate? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-06-2014, 02:18 PM - Thread Starter
Timothy91's Avatar
Liked: 33
Hey,
Cannot find a thread here about it and my research is not coming back with anything concrete so far.
Does anyone know what the bitrate (or bitrates) Netflix is using for Dolby Digital Plus? The sound quality seems to lack a little on dynamic range, ie, impacts, etc and sounds a bit sharp on the high frequencies and lacking fullness on the midrange during "busy" moments (however speech from the center channel seems to always be very good). This usually means a reduced bitrate is employed, but how low do they go?
Timothy91 is offline
post #2 of 8 Old 04-06-2014, 09:16 PM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 744 Post(s)
Liked: 657
Originally Posted by Timothy91 View Post
Hey,
I can't find anything specific either, but here is a little info from Dolby on what range is capable in the process. My guess would be for streaming it's towards the lower end of the scale of bit rates.
Dolby Digital Plus can scale from 32 kbps all the way up to 6 Mbps.
A typical range for Dolby Digital Plus on high-definition optical discs
is 768 kbps to 1.5 Mbps.
"Oooh a puzzle box, I love puzzles"/ "Are you familiar with 'The Lament Configuration"/ "Actually I'm lousy at puzzles..."
tenthplanet is offline
post #3 of 8 Old 04-07-2014, 04:16 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
It wouldnt need more then 640, and I doubt its even that high.
MovieSwede is offline
post #4 of 8 Old 04-08-2014, 05:02 AM
Quoted: 744 Post(s)
Liked: 657
640 is what reg dolby digital can be when converting down from dolby digital plus which is higher than DVD which is around 385. So in theory you would need less than 640 with DD plus being it's using a more effective compression.
post #5 of 8 Old 04-11-2014, 01:08 AM
michaeltscott's Avatar
Quoted: 2706 Post(s)
Liked: 1429
It's 192 Kbps DD Plus. It was 384 Kbps, then Dolby declared that their new encoding tech was twice as efficient as before and Netflix halved their encoding rate.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #6 of 8 Old 04-11-2014, 01:34 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
lovinthehd is offline
post #7 of 8 Old 04-11-2014, 02:14 AM
undecided's Avatar
Quoted: 123 Post(s)
Liked: 80
Originally Posted by lovinthehd View Post
You might want to check this out http://www.avsforum.com/t/1492916/dolby-digital-plus-and-netflix-on-various-avrs
The last few posts have some comments about why the Apple TV doesn't do DD+
While I can't answer that it doesn't really matter.
The Netflix Apple TV DD 5.1 at 384 kbps sounds identical to DD+ 5.1 192 kbps on other devices.
Now should the audio bit rate on Netflix be little higher - probably - but those looking for DD+ too light up and expecting better audio will be disappointed...
undecided is offline
post #8 of 8 Old 04-11-2014, 05:00 AM
lovinthehd's Avatar
Liked: 4775
Wasn't thinking about the apple thingie, and haven't checked the thread lately either, but rather if his avr was affected.....
Reply Video Download Services & Hardware
