RealD vs Dolby 3D? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 91 Old 06-17-2009, 05:36 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Quoted: 2055 Post(s)
Liked: 1161
Send a message via Skype™ to CINERAMAX
CINERAMAX is online now
post #62 of 91 Old 06-30-2009, 03:44 PM
kevinsert's Avatar
Real3D working with special HDD's or 70mm film?
kevinsert is offline
post #63 of 91 Old 06-30-2009, 04:01 PM
Lee Stewart's Avatar
Liked: 51
According to this website, there are no 70mm productions scheduled other than documentaries:
http://www.in70mm.com/
Buuuuut . . .
I would LOVE to see a 70mm 3D film made.
Lee Stewart is offline
post #64 of 91 Old 06-30-2009, 04:28 PM
Dbuudo07's Avatar
Quoted: 225 Post(s)
Liked: 199
I saw Under the Sea in 70mm 3D and it was pretty amazing. Your entire field of view is filled and you're placed in the film. I loved it.
David Budo
Dbuudo07 is offline
post #65 of 91 Old 07-06-2009, 06:25 AM
Liked: 51
RealD Achieves 100% Growth Worldwide, 400% Growth in Europe in First Half of 2009
Over 8,700 Screens Contracted and Over 3,200 RealD 3D Screens Installed
http://www.dcinematoday.com/dc/PR.aspx?newsID=1479
post #66 of 91 Old 07-06-2009, 11:03 AM
Dbuudo07's Avatar
Quoted: 225 Post(s)
Liked: 199
I thought the 3D for Ice Age: Dawn of the Dinosaurs was really good. I saw it on a RealD system and it was tight, with no ghosting. I also liked how the movie and the 3D really complimented eachother and not just adding depth to the picture. There were moments where you felt you were in the adventure with the characters and felt like you were in the environment going along for a ride with them.
David Budo
Dbuudo07 is offline
post #67 of 91 Old 07-06-2009, 07:27 PM
ice_blu5's Avatar
I saw ice age 3D in Australia at reading cinemas with dolby 3D. The 3D is incredible in that movie. The dolby 3D is mind blowing in terms of the quality and depth. the objects really do come into the audience and into the distance. its by far the best utilised 3D to date. There is full colour and 100% no ghosting. The image was extremely bright and i have never seen a digital projector with the sharpness and clarity this one had. Dolby has really achieved a milestone in creating very real high quality 3D That feels natural and not artificially 3D.
ice_blu5 is offline
post #68 of 91 Old 07-11-2009, 03:26 PM - Thread Starter
johnty's Avatar
Quoted: 20 Post(s)
Liked: 33
Colorado got its first Dolby 3D theater in late May so I was finally able to A/B both RealD and Dobly3D over the past two days. My observations…
The film was Ice Age: Dawn of the Dinosaurs. Screen width was about 32’ in both theaters. I sat back about 1.5 screen heights in both auditoriums, perfectly centered. The Dolby3D theater was using a Barco. I watched the brightness level on the screen go down very slightly as the color wheel moved into position after the 2D previews. The spinning color wheel, per se, did not introduce any noticeable artifacts. The RealD theater was using a Christie. I don’t know the model number or lamp wattage of either but both seemed to be very bright for the 2D video, easily 14fl or above.
From my vantage point, the 3D was essentially perfect for both systems. No image ghosting and good depth although I thought the stereo image was slightly better with Dolby. It was also slightly sharper although I would attribute that to the Barco which seemed to have a slightly crisper image in 2D. As the end credits rolled, I walked up to the last row of each stadium theater. The credits appeared to be exactly on the screen but random artwork on each side of the letters appeared to be about 4’ in front of the screen in my normal seating position. At the back of the theater, they looked like they were much further in front of the screen with Dolby. In RealD nothing changed.
Then I walked down to about 1 screen height and to the edge of the screen. RealD had real ghosting issues. The first time I’d ever seen a double image in RealD. I’m sure it has to do with loss of polarization and the angle of light off of the silver screen. IMAX and others have produced charts of seating areas in their theaters that are not suitable for 3D viewing. Obviously, if you get too far off of center axis, the same holds true for RealD. Dolby had no ghosting problem at screen edge.
RealD also had more light loss than Dolby when the glasses were in place. Not a problem for most of the movie but in some cave scenes shadow detail, clearly visible without the glasses, disappeared with the glasses on. A brighter Christie might have fixed that.
Did Dolby3D have any issues? Absolutely. Since they fiddle with the color spectrum to achieve 3D, I was most interested to see if it changed the color of the movie in any manner. It certainly does. Ice Age is an ideal movie for an A/B because there is a lot of pure white in it; snow, ice, etc. Without glasses, snow-capped mountains look perfectly white. With RealD glasses they were still white although a bit subdued because of the gray filters. With Dolby glasses they took on a very slight hue of red/orange. If the viewer weren’t lifting their glass out of the way dozens of times a minute as I was the color shift probably wouldn’t be as apparent.
Most astonishing, though, was the green spectrum. There’s a point in the movie where everyone is surrounded by a dense green fog. In Dolby it looked like pea-green soup. In RealD it had more of the hue of a well maintained lawn of grass.
Supposedly, Dolby applies color correction in real time to the PJ video feed to compensate for the color shift introduced by the color wheel and the filtering on the lenses of the glasses. This is done with “look up” tables to ensure compliance with DCI color parameters. If that be true, some of the tables need new numbers.
If Dolby can ever achieve true whites, and get the rest of the color spectrum correct, I think it would be the best (passive) 3D system. As it stands, the color shift is the deal breaker for me. The hot setup would be a RealD system on a Barco PJ. Since most RealD systems in Denver are Christies, it will take some looking to find such a combination. If I find it I can do an apples to apples A/B. Until then, game point goes to RealD.
johnty is offline
post #69 of 91 Old 07-11-2009, 08:02 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1161
Jonhnty,
Great writeup. There is an advantage in sharpness and MTF on the Dolby; comes from the wheel being placed in between the lamp and the light engine where it does not affect ansi contrast-a proxy for MTF. The encoding for Movies is done by the studios, is not real time. There may be an adjustment to white fields that was not performed, as other demonstrations of the format have not shown the hue issue. Thank you for bringing it up.
post #70 of 91 Old 07-12-2009, 07:29 PM - Thread Starter
johnty's Avatar
Quoted: 20 Post(s)
Liked: 33
Peter,
Thanks for the compliment. Quite right, the Dolby color wheel is before the optical path. I would infer, then, that if the Barco didn't have a color wheel but instead a RealD ZScreen at the end of the optical path, that the ANSI contrast and MTF would both be affected? Also true that RealD does ghost busting encoding before the movie is sent to the theater. But from your previous post I don't think Dolby does any pre-encoding.
Originally Posted by CINERAMAX View Post
Dolby 3-D Article
In this link you provided last May in this thread, Jim Slater talks with the Dolby3D folks about some of the technical details. I've re-read the article several times and I quote a few lines:
However, the Dolby 3D system has been designed so that a standard unprocessed' 3D movie file can be used, with any additional processing required for the 3D version being applied in real time in the Dolby Digital Cinema server during playback. Effectively, a process of compensation for any effects of the filtering on left and right eye images is performed in the server, and an additional 1U high control rack is used to synchronize the operation of the filter with the projector and server. (Emphasis added.)
I asked how they ensure that all the necessary DCI colour parameters are complied with, knowing how stringently DCI applies its specifications, although there isn't yet a compliance testing procedure in place, and was told that there are agreed reference look up' tables which are used to ensure compliance.
I'm sure that thousands of eyeballs tested the Dolby system before it was released and if other demos have not shown hue issues, then something was wrong with the theater's Dolby3D equipment. Yet, it was a brand new install (less than 45 days) and without the glasses the snow-capped mountains were white (D6500, give or take), with the glasses they weren't the same color.
It would be interesting to hear from any Dolby people reading this thread as to a possible cause. I think Dolby3D is the better system but in at least one theater the artifacts are too apparent to ignore.
John
johnty is offline
post #71 of 91 Old 07-15-2009, 08:03 AM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1161
I stand corrected Jonhnty. SPOKE TO DOLBY It is a simple adjustment of the crosstalk cancellation value . This is built into the dp-2000 or in the dp3000 it is outside the box in Dolby's processor, essentially the wheel from the "other side" is showing".
Dolby is licensing a Variant of the IDC superflex to encode Dolby 3-D for 120hz double flash content to upconvert to triple flash and play on DCI projectors.
http://www.datacast.com/Media/Conten..._ProCinema.pdf
One of these new realtime encoders will be needed if you want to do gaming 3D (A KILLER APP) on a DCI, also if you want to play BD3D which will most likely not be triple flash (although we sure are hoping to eliminate conversions).
post #72 of 91 Old 07-16-2009, 05:52 AM
Terry Montlick's Avatar
Location: State of Rhode Island and Providence Plantations
Originally Posted by GXM View Post
I see a lot of bad info about this, so I just wanted to post some fact and a little opinion. I will just give some technical details about the two systems. ...
Thanks for the excellent explanation. I sat through an overly long and yet superficial SMPTE presentation on 3D projection systems, and your info was more detailed and concise.
My 2 cents on the future of 3D: It's all about the acceptance of the glasses. In the early 50's (even allowing for the host of bad movies and the use of red/green separation filters as a cheapie and headachy alternative), I think that people just couldn't put up with having to wear special glasses. Now, folks stick all kinds of technological stuff on their person: earbuds, electronic fruit (BlackBerrys), etc.
- Terry
Terry Montlick Laboratories
Home Theater Acoustics
Critical Listening Rooms
Design, Evaluation, Alpha Certification®
www.tmlaboratories.com
Terry Montlick is offline
post #73 of 91 Old 07-19-2009, 04:04 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1161
Today I saw Ice Age 3D- a much more entertaining flick than the first 2 combined, the 3D was almost as good as MVA, very very close in portraying a natural world view with very little popping off the screen, the action takes place in a virtual space that ends 9 feet in front of the screen to a horizon in the hundreds of feet deep..
This is similar to MVA and the story is kept entertaining as well but what makes MVA trump IceAge 3D is the CINEMASCOPE aspect ratio (not so in Imax which sorto sucked).
I know everyone is saying Avatar this and Avatar that but strictly from the previews seems to me that G Force is going to be the game changer in live action 3D, with some risks taken in the coming at ya aspect of things.
post #74 of 91 Old 01-02-2010, 06:56 PM
ooms's Avatar
Hmmm.
ooms is offline
post #75 of 91 Old 01-02-2010, 09:37 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1161
After seeing G-Force in 2-D what a lousy movie. Statement retracted.
Although I very much want to see more risk taken with In Your Face effects in some better flicks in the future.
post #76 of 91 Old 01-04-2010, 03:35 PM
Zerox_no1's Avatar
Watched Avatar 3D in an Dolby 3D theater and not only did it show great 3D effects but also the whole picture looked like HD. I'm impressed!
Zerox_no1 is offline
post #77 of 91 Old 01-08-2010, 04:28 PM
girlHere2learn's Avatar
wow!!! just came across this web site. You guys are great, I have a lot of reading to do so I can catch up with the discussion.
Love the whole 3D world we are entering and as a screenplay writer, I am excited about this new escape world. As for Avatar, it was like walking into a 3D hologram world.
girlHere2learn is offline
post #78 of 91 Old 01-08-2010, 04:42 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1161
Welcome,
Your colleagues need to show the viewing audiences also that movies like My Dinner with Andre can benefit from 3-D as well...
post #79 of 91 Old 01-09-2010, 12:16 PM
Hooty82's Avatar
I have seen James Cameron's Avatar in both RealD 3D and Dolby 3D. I have to say that there was virtually no noticeable differences except that the RealD technology seemed to "pop' a little more from the screen. The RealD glasses are also much more comfortable and have a classic "Ray-Ban" fit rather than the akward Dolby glasses that tend to squeeze the sides of your head rahter than sit gently on the ears. I hope this helps. I personally prefer the RealD.
Hooty82 is offline
post #80 of 91 Old 01-09-2010, 05:53 PM
Thanks... Cinerama
My fellow filmmakers are being guided by the parties who hold the money bags. If they (movie ppl) don’t want a movie made, you won’t get funded.
James Cameron is always setting the bar for "the new stuff." the man is flat out good. I love his futuristic thinking and his new world of possibility.
I would love to like have a long talk on how we can chance the world and bring more fantasy into our reality. It's a great way to escape.
What we need is more private investors investing in the film business. In the independent film business, which I am apart of, it’s getting hard to find backers to finance film or provide letter of credit so we can make the kind of movies we know the public would enjoy.
But think about all the new stuff that awaits us. Looking at all the scripts in front of me – wow from action, to Sci-action, to fantasy, etc. We have a great future ahead of us. We need more dreamers in the film business to bring alive a world we are just starting to tap into.
post #81 of 91 Old 01-11-2010, 10:41 AM
Cor Jansen's Avatar
I miss the discussion of 'one versus dual projector' setup.
I'v seen Avatar with a dual projector setup (with circulair polarized glasses) and with one projector (dolby 3D glasses).
I much more liked the first one. And I think it is not because of the polarizing glasses, but because of the dual projector.
With the one-projector setup it was very difficult to keep track of fast moving objects. My brains got confused.
What do you peaple think about that?
Cor Jansen is offline
post #82 of 91 Old 01-11-2010, 01:05 PM
donaldk's Avatar
Quoted: 457 Post(s)
Liked: 110
We're ready to learn of your work, any references to point to?
donaldk is online now
post #83 of 91 Old 01-11-2010, 01:10 PM
donaldk's Avatar
Quoted: 457 Post(s)
Liked: 110
Cor meer licht? Bandwidth (did you see it on a DP-100, with the older chips? And cross talk are likely sources of head-aches. Where did you see it, I was told that overhere most of the Barco set-ups for Avatar are ExpanD, only one is Barco/Dolby. There's also some Imax XD with the two Christie (not DPI!) 2K DLPs.
post #84 of 91 Old 01-11-2010, 01:14 PM
donaldk's Avatar
Quoted: 457 Post(s)
Liked: 110
Hmm, Peter has a big head (both litteraly and figuratively) and those original Dolby glasses seemed to fit him well, eventhough he told us performance of much more expensive glasses was better.
post #85 of 91 Old 01-12-2010, 05:49 PM
mmiles's Avatar
Quoted: 487 Post(s)
Liked: 220
The glasses I wore at the JVC booth while looking at the smaller screens was more like regular glasses.
mmiles is offline
post #86 of 91 Old 01-14-2010, 07:02 PM
Hi Donald,
I'll blast you over an email regarding my background in the independent film world. My future appears better than my past!!!!!!!! LOL
post #87 of 91 Old 04-21-2010, 08:41 AM
soulpunisher's Avatar
My theater I go to uses Dolby Digital 3-D and I never get headaches and love the quality
http://www.warrentheatres.com/index.asp
and it's the only theater that is 100% THX too! It rocks.
soulpunisher is offline
post #88 of 91 Old 06-03-2011, 03:01 PM
GXM
GXM's Avatar
I have not seen anyone else comment about the 1 vs 2 projectors so I thought I would drop a note in here.
I have seen 3 different dual projector systems, as well as several single systmes and I have to say any dual projector setup is a big improvement. Most current single projector systems are running at triple flash. This is where the projector is showing 144 frames per second. Each 1/24 sec frame is show 3 times for left and 3 times for right. This is pretty fast and does not suffer any real flicker like you can get at double flash. But even at this rate, there is still a very noticeable issue with fast motion where the left eye is always getting the new frame first. You left eye sees the object in a new position, while your riht eye is still percieving the last flash of the previous frame. On a fast horizontal move, this causes a bad judder and loss of depth perception for many people, me included. The IMAX digital screens are all dual projector, but they are using just linear polarized glasses, so any tilt of your head and you get ghosting. Circular polarized glasses are better at tilt, but actually do not cancel as well when perfectly level. Ghost cancelling is used to help reduce this ghosting, but it is a compromise that only works if there is a fair amout of light in the image to subtract from. An image on a black background cannot utilze the ghost cancellation because the other eye is already at black, it cannot suck light off of the screen, only add less when it is showing an image. The big red "ME" at the beginning of "Despicable Me" was a perfect example of native ghosting. Dual projectors does give a good bit more light to work with as well, but I feel even small screens would be better served with 2 smaller projectors. Then when they run 2D only light one to cut lamp cost.
Active glasses systems do not get the same improvement with 2 projectors. Since the isolation between your eyes is a time split with the active shutters in the glasses, you have no choice but to project just left eye when that shutter is open, and just the right eye when that shutter is open. No matter how you stack them, both projectors must alternate eyes in sync with the glasses for it to work. So you still get the left eye getting the new frame first. This makes any passive glasses system look better than active glasses when you go to 2 projectors.
Another small improvement is that there is no need for any "Dark time" to allow the system to change eyes. Real D, Dolby, Master Image all take some time to switch from one eye to the other. This is time the DLP has to be showing black, wasting some light. 700usec may not sond like much, but blank the projector 6 times for that time every frame, and it adds up to about 12% of the time the projector is dark.
3D done right can look amazing, but 3D done wrong can be horrible is so many ways.
GXM is offline
post #89 of 91 Old 06-03-2011, 03:37 PM
Electric_Haggis's Avatar
Quoted: 24 Post(s)
Nicely put! That's a great summary of the difference.
Electric_Haggis is offline
post #90 of 91 Old 04-22-2013, 09:21 PM
dmickey's Avatar
I watched two movies that were shown in Real3D (RealD?) The first was an animated movie. I was disappointed in the 3D effect. It looked like I was watching two pieces of film with a small distance between them. I thought that it was because it was an animated movie. Then I saw the GI Joe movie in Real3D. Same effect! I was very disappointed!!
Dennis Mickey @ Gettysburg, PA
dmickey is offline
Reply D-cinema Equipment and Theaters
