JBL professional cinema PA theatre systems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-21-2008, 02:57 AM - Thread Starter
JBLsound4645's Avatar
Here are some current JBL professional brands of speakers to consider for home application use. Please, bare in-mind some of these might be a bit large for home use so think before buying?
JBL 5672 Three-Way Screen Channel System
Features : Specifications :
Three-way system design for maximum output with minimum distortion
Optimized Aperture Bi-Radial® and driver technology for ultra-low distortion
Midrange pattern control for increased direct vs. reverberant energy
Vented Gap Cooled (VGC) LF transducer(s) for maximum output and reliability
Flat-front design for easy baffle wall installation
Fully adjustable horn bracket for precise directional control
Frequency : 35 Hz to 16 kHz (-10 dB)
Frequency Response : 45 Hz to 12.5 kHz
(+/- 3 dB)
Horizontal Coverage Angle : 80°, averaged 300 Hz to
16 kHz (-6dB)
Vertical Coverage Angle : 45°, averaged 300 Hz to
16 kHz (-6dB)
Maximum Output : 112dB-SPL @ 10 m
Recommended Crossover Frequency : LF/MF: 297 Hz, MF/HF: 2.5 kHz
Low Frequency : Two 2226H 380mm (15in) dia.,
100mm (4in) edgewound ribbon
voice coil One 4508B LF enclosure
Nominal Impedance : 4 Ohms
Input Power Rating : 1200W, AES; 1200W
Recommended Amplifier
Sensitivity : 103dB, 1W @ 1 m (3.3 ft)
Input Connectors : Barrier Strip
Mid Frequency : 2392 midrange horn 2490H midrange
driver; 100mm (4in) edgewound
ribbon voice coil
Nominal Impedance : 8 Ohms
Input Power Rating : 200W, AES; 300W
Sensitivity : 115dB, 1 W @ 1 m (3.3 ft)
High Frequency : 2352 Horn 2451 driver; 100mm (4in)
edgewound ribbon voice coil
Input Power Rating : 75 W, AES; 200 W
Sensitivity : 112dB, 1 W @ 1 m (3.3 ft)
Mounting Accessories : HF horn baffle board and mounting
frame which couples MF and HF;
mounts to LF enclosure for
aiming/tilting
Dimensions (H x W x D) : 2786.6 x 1118 x 812.8mm
(109 x 44 x 32in)
Net Weight : 87.3 kg (192.5 lb)
JBL5674 Three-Way Screen Channel System
Frequency Range : 35 Hz to 16 kHz (-10 dB)
(+/- 3 dB)
16 kHz (-6dB)
Vertical Coverage Angle : 45°, averaged 300 Hz to 16 kHz (-6 dB)
Maximum Output : 117 dB-SPL @ 10 m
Low Frequency : Four 2226 H 380 mm (15 in) dia., 100
mm (4 in) edgewound ribbon voice coil
One 5504 LF enclosure with Diamond
Quad driver array
Nominal Impedance : Each pair in parallel; two 4 Ohm loads
per driver pair
Input Power Rating : 2400 W, AES; two channels of
1200 W Recommended Amplifier
per driver pair
Sensitivity : 103 dB, 1 W @ 1 m (3.3 ft)
Mid Frequency : 2392 midrange horn 2490 H midrange
driver; 100 mm (4in) edgewound
ribbon voice coil
Input Power Rating : 200 W, AES; 300 W
Sensitivity : 115 dB, 1 W @ 1 m (3.3 ft)
Sensitivity : 112 dB, 1 W @ 1 m (3.3 ft)
Mounting Accessories : F horn baffle board and
mounting frame which couples
MF and HF; mounts to LF enclosure
or aiming/tilting
Dimensions (H x W x D) : 2895.6 x 1118 x 812.8mm
(114 x 44 x 32in)
Net Weight : 171.69 kg (378.5 lb)
JBLsound4645 is offline
post #2 of 13 Old 11-21-2008, 03:01 AM - Thread Starter
Three-way Screen Array® design for maximum output, optimal coverage, and minimum distortion
One 380 mm (15") Vented Gap Cooled (VGC) LF Transducer
Available for Bi-amplified operation (Model 3631) or Tri-amplified operation (Model 3631-T)
Approved for THX® certified applications (3631-T)
M/HF ships fully assembled
Second Generation Optimized Aperture Waveguide technology for ultra-low distortion, and extremely uniform frequency response
SSCTM Screen Spreading Compensation
Focused Coverage TechnologyTM
Flat-front waveguide design for easy baffle wall installation
Shallow depth for minimum behind screen requirements
Low profile design with 600W LF
Frequency Range : 30 Hz - 20 kHz
Frequency Response : 40 Hz - 16 kHz
System Sensitivity : 104 dB, 2.83V
@ 1m (3.3 ft)
Rated Maxium SPL : 126 dB @ 1m (3.3 ft), 132 dB peak
System Input Power Rating : LF: 600 watts, M/HF: 150 watts [HF: 50 watts]
Hor. Coverage Angle (-6 dB) : 90°
Vert. Coverage Angle (-6 dB) : 20° up, 30° down
Directivity Factor (Q) : 10.0
Directivity Index (DI) : 10 dB
Crossover Frequencies : 350 Hz [1.2 kHz]
Dimensions (HxWxD) : 1600 mm x 762 mm x 450 mm (63 in x 30 in x 17.75 in)
Net Weight : 68.6 kg (151 lbs)
Shipping Weight : 80.8 kg (178 lbs)
JBL 3632 Three-Way Bi-Amplified ScreenArray Loudspeaker System
Three-way ScreenArray design for maximum output,
Available for Bi-amplified operation (Model 3632) or
Tri-amplified operation (Model 3632-T)
Approved for THX® certified applications (3632-T)
Ships fully assembled
SSC Screen Spreading Compensation
Shallow profile for minimum behind screen
depth requirements
Frequency Response : 40 Hz - 16 kHz (±3 dB)
@ 1m (3.3 ft)
System Input Power Rating : 3632: LF: 500 W, M/HF: 150 W 3632-T: HF: 50 W
Hor. Coverage Angle : 90° (-6 dB)
Vert. Coverage Angle : 20° up, 30° down (-6 dB)
Crossover Frequencies : 3632: 350 Hz
3632-T: 1.2 kHz
Dimensions (H x W x D) : 1937 x 762 x 450 mm
76.3 x 30 x 17.75 in)
Net Weight : 97.7 kg (215 lb)
Shipping Weight : 112.5 kg (248 lb)
JBL 4632 Three-Way Bi-Amplified ScreenArray Loudspeaker System
Available for Bi-amplified operation (Model 4632) or
Tri-amplified operation (Model 4632-T)
Approved for THX® certified applications (4632-T)
installation Shallow profile for minimum behind
screen depth requirements .
System Sensitivity : 106 dB, 2.83V
@ 1m (3.3 ft)
Rated Maxium SPL : 129 dB @ 1m (3.3 ft), 135 dB peak
System Input Power Rating : 4632: LF: 800 W, M/HF: 200 W
4632-T: HF: 50 W
Crossover Frequencies : 4632: 250 Hz
4632-T: 1.2 kHz]
Dimensions (H x W x D) : 2427 x 762 x 450 mm
(95.6 x 30 x 17.75 in)
Net Weight : 120.4 kg (265 lb)
Shipping Weight : 139.4 kg (307 lb)
JBL 4641 4641 Single 460 mm (18 in.) Subwoofer System
600 Watts Continuous Pink Noise, 1200 Watts Continuous Program Power Handling
Usable response to 25 Hz (-10 dB, no EQ), flat to 25 Hz (-3 dB) with External EQ
2241H VGCTM Vented Gap Cooled Driver - High Sensitivity - Low Power Compression - High Maximum-SPL Capability - Low 2nd and 3rd Harmonic - Distortion - Symmetrical Field Geometry SFGTM - Magnet Structure - Long Excursion Capability
Approved by Lucasfilm, Ltd. for THX® installations
Transducer : JBL Model 2241H
460 mm (18 in)
Low Frequency Transducer
Rated Impedance : 8 ohms
Minimum Impedance : 6.3 ohms
Power Handling Capability : -
Continuous Pink Noise : 600 Watts
Continuous Program : 1200 Watts
Peak Power : 2400 Watts
OUTPUT CAPABILITY : -
Axial Sensitivity : 50 Hz to 500 Hz; 98 dB, 1W @ 1m
40 Hz to 100 Hz; 97 dB, 1W @ 1m
Power Compression : -
At -10 dB power (60 W) : 0.8 dB
At -3 dB power (300 W) : 2.6 dB
At rated power (600 W) : 4.3 dB
Recommended Crossover Frequencies : High-pass: 20 Hz, 24 dB/octave or greater
Low-pass: 80 Hz to 150 Hz, 12 dB/octave or greater
Net Weight : 60 kg (131 lbs.)
Dimensions H x W x D : 1010 mm x 674 mm x 450 mm
39.75 in x 26.5 in x 17.75 in
JBL 4642A 4642A Dual 460 mm (18 in.) Subwoofer System
1200 Watts Continuous Pink Noise, 2400 Watts Continuous Program Power Handling
Usable response to 22 Hz (-10 dB, no EQ), flat to 22 Hz (-3 dB) with External EQ
2241H VGCTM Vented Gap Cooled Drivers - High Sensitivity - Low Power Compression - High Maximum-SPL Capability - Low 2nd and 3rd Harmonic - Distortion - Symmetrical Field Geometry SFGTM - Magnet Structure - Long Excursion Capability
Rated Impedance : 4 ohms
Minimum Impedance : 3.2 ohms
Continuous Pink Noise : 1200 Watts
Continuous Program : 2400 Watts
Peak Power : 4800 Watts
Output Capability : -
Axial Sensitivity : 50 Hz to 500 Hz; 101 dB, 1W @ 1m
40 Hz to 100 Hz; 100 dB, 1W @ 1m
Net Weight : 98 kg (216 lbs.)
Dimensions H x W x D : 762 mm x 1219 mm x 610 mm
30 in x 48 in x 24 in
JBL 4645C 4645C Single 460 mm (18 in.) Subwoofer System
800 Watts Continuous Pink Noise, 1600 Watts Continuous Program Power Handling
2242H SVGTM Super Vented Gap Cooled Driver - High Sensitivity - Minimal Power Compression - Highest Maximum-SPL Capability - Extremely Low 2nd and 3rd - Harmonic Distortion - Symmetrical Field Geometry SFGTM - Magnet Structure - Extended Excursion Capability
Minimum Impedance : 7.2 ohms
Continuous Pink Noise : 800 watts
Continuous Program : 1600 watts
Peak Power : 3200 watts
Axial Sensitivity : 50 Hz to 500 Hz; 99 dB, 1W @ 1m
At -10 dB power (80 W) : 0.6 dB
At -3 dB power (400 W) : 2.0 dB
At rated power (800 W) : 3.3 dB
Net Weight : 63 kg (138 lbs.)
39¾ in x 26½ in x 17¾ in
post #3 of 13 Old 11-21-2008, 03:24 AM - Thread Starter
JBL 8330A Three-Way Cinema Surround System
Tight-cluster design of components for uniform horizontal and vertical dispersion.
Convenient mounting design uses JBL QuickMount, Omnimount® or APC Multimount brackets.
Special cabinet shape incorporates 20° angled front baffle.
SMPTE / ISO2969 Curve X high frequency de-emphasis.
Lightweight, rigid molded enclosure.
Input terminals located on top of cabinet for quick access.
Approved by Lucasfilm, Ltd. for THX® installations.
Low Frequency Driver : 203 mm (8 in)
High Frequency Driver : Mid: 130 mm (5 in) High: 25 mm (1 in)
High Frequency Horn : N/A
Frequency Range : 40 Hz - 20 kHz (-10 dB)
Power Capacity (Continuous Pink Noise) : 100 W
Power Capacity (Continuous Program) : 200 W
Sensitivity : 91 dB SPL (1 W, 1 m, 3.3 ft.)
Crossover Frequencies : 650 Hz, 3.1 kHz
Horizontal Beamwidth : 110° Nominal
Dimensions (H x W x D) : 457 x 457 x 260 mm
(18 x 18 x 10.25 in)
Net Weight : 8.6 kg (19 lb)
JBL 8340A High Power Cinema Surround System
45 Hz to 18 kHz Frequency Range
High Sensitivity, 96 dB SPL, 1 W, 1 m (3.3 ft)
High Power Handling Capability: 250 watts continuous pink noise
Convenient mounting design uses JBL QuickMountTM, Omnimount® or APC Multimount brackets
SMPTE/ISO2969 Curve X high frequency de-emphasis
Uniform horizontal and vertical coverage
Frequency Range: : 45 Hz - 18 kHz (-10 dB)
Frequency Response: : 75 Hz - 16 kHz (±3 dB)
Power Rating: : 250 watts continuous pink noise, 1000 watts peak
Sensitivity: : 96 dB SPL, 1W @ 1m (3.3 ft)
Nominal Impedance: : 8 ohms
Hor. Coverage Angle (-6 dB): : 100° averaged 400 Hz to 12 kHz
Vert. Coverage Angle (-6 dB): : 80° averaged 400 Hz to 12 kHz
Directivity Factor (Q): : 7 averaged 400 Hz to 12 kHz
Directivity Index (DI): : 8.4 dB averaged 400 Hz to 12 kHz
Crossover Frequency: : 2.2 kHz
High Frequency Contour: : ISO2969 Curve X surround contour
Polarity: : EIA (Positive voltage to RED terminal gives
Low Frequency Transducer Nominal Diameter:: : 250 mm (10 in)
High Frequency Transducer Nominal Diameter: : 25 mm (1 in)
Downward Firing Angle: : Nominal 20° when mounted flush on back panel
Enclosure Material: : Textured Black H.I.P.S. Plastic
Grille Color: : Black
Input Connectors: : 5-way binding posts
Dimensions (H x W x D): : 457 mm x 457 mm x 260 mm (18 in x 18 in x 10.25 in)
Net Weight: : 8.6 kg (19 lb)
JBL 2516 Bracke t2516 Quick-Mount® Fixed-Angle Bracket
Cost-effective wall-mount bracket
Designed for 8330A and 8340A surrounds
Packed two brackets to a carton
Units per carton : 2
JBL 2517 Speaker Mount 2517 Speaker Mount Pan and Tilt Rotations
Alloy steel
Black powder coat paint
Working Load : 20 lbs. (9 kg)
Shipping wgt: : 4 lbs. (1.8 kg) pair
Pack count: : 2 units/carton
post #4 of 13 Old 11-21-2008, 03:33 AM - Thread Starter
JBL 3677 Screen Channel System
Low Frequency Transducer: One 380 mm (15 in) low frequency driver.
High Frequency Transducer: 25 mm (1 in) horn throat diameter, 44 mm (1.75 in) pure titanium diaphragm compression driver.
90° x 40° Flat-Front Bi-Radial® horn.
Newly designed passive network with driver protection circuit.
All in one enclosure for simple installation.
Shallow profile cabinet minimizes behind-screen space requirements.
Frequency Range : 40 Hz to 20 kHz (-10 dB)
Frequency Response : 45 Hz to 12 kHz (+/- 3 dB)
Power Capacity (Continuous Pink Noise) : 250 W
Sensitivity : 99 dB (1W, 1m)
Crossover Frequency : 1.2 kHz
Nominal Coverage : 90° Horizontal, 40°Vertical
Half-Space Reference : 3.2%
Maximum Acoustic Power Output : 7 Acoustic W (Sine Wave Input)
System Polarity : Positive Voltage to RED produces forward cone motion
Input Connectors : Barrier Strip Screw Terminals
Dimensions (H x W x D) : 65 x 651 x 292 mm
(30.125 x 25.625 x 11.5 in)
Net Weight : 39 kg (85 lb)
Flat power response 100° x 100° Bi-Radial® horn.
Operable in bi-amp or passive mode.
Includes adjustable bracket for horn aiming.
THX® - approved for THX system installations (biamplified only).
Frequency Range : 30 Hz to 20 kHz (-10 dB)
Power Capacity (Continuous Pink Noise) : 300 W Passive HF: 50 W Bi-Amp LF:600 W Bi-Amp
Sensitivity : 98 dB (1W, 1m)
Crossover Frequency : 1 kHz
Nominal Coverage : 90° Horizontal, 90° Vertical
Half-Space Reference Efficiency : 3.3%
Maximum Acoustic Power Output : 8 Acoustic W (Sine Wave Input)
Dimensions (H x W x D) : 1019 (w/horn) x 651 x 292 mm
(40.125 (w/horn) x 25.625 x 11.5 in)
Net Weight : 41 kg (90 lb)
JBL 3310 Surround Loudspeaker System
Components:
One 200 mm (8 in) low frequency driver, one 1 in titanium dome high frequency tweeter.
Newly-designed passive network with driver protection circuit.
Built-in installation points.
Special cabinet shape with angled front baffle for common aiming angle (-15°).
Input terminals located on cabinet top for quick access.
Frequency Response : 100 Hz to 12 kHz (+/- 3 dB)
Power Capacity (Continuous Pink Noise) : 75 W
Sensitivit : 89 dB (1W, 1m)
Nominal Impedanc : 8 Ohms
Crossover Frequency : 2.5 kHz
Nominal Coverage : 100° Horizontal, 100° Vertical
forward cone motion
Dimensions (H x W x D) : 446 x 483 x 267 mm
(17.5 x 19 x 10.5 in)
Net Weight : 13 kg (29 lb)
JBL 3635 Cinema Subwoofer System
Components: One 460 mm (18 in) low frequency driver.
Shallow profile cabinet minimizes behind-screen space.
Frequency Range : 28 Hz to 500 Hz (-10 dB)
Frequency Response : 38 Hz to 100 Hz (+/- 3 dB)
Sensitivity : 100 dB (1W, 1m)
Recommended Crossover Frequency : 100 kHz
Half-Space Reference Efficiency : 5%
Maximum Acoustic Power Output : 15 W IEC Standard (Sine Wave Input)
Dimensions (H x W x D) : 1168 x 651 x 368 mm
(46 x 25.625 x 14.5 in)
Net Weight : 51 kg (113 lb)
JBL 3622N Two-Way ScreenArray Cinema Loudspeaker System
Fully passive two-way system
Power Capacity: 400 W continuous IEC pink noise
Sophisticated crossover network
High quality in a compact and very cost effective system
Smooth response, Controlled coverage
Frequency Range : 30Hz to 20kHz
Sensitivity : 101dB, 2V @ 1m (3.3ft)
Rated Maximum SPL : 127dB, @ 1m (3.3 ft) 133db peak
Passive System Input Power Rating : 400W
Crossover Frequency : 1300Hz
Dimensions (H x W x D) : 1289 x 762 x 450mm
(50.75 x 30 x 17.75in)
Net Weight : 65kg (143 lb)
3639 Low Frequency : 2 M115H-8A 380 mm (15 in) dia4509 LF enclosure.,
61 mm (2.5 in) edgewound ribbon
voice coil transducers mounted in
4509 LF enclosure
Net Weight : 56 kg (123 lb)
Shipping Weight : 64.5kg (142 lb)
3622-HF High Frequency Pack : One 2418H-1Compression Driver, One
2374 HF horn, one adjustable bracket
Net Weight : 9kg (20 lb)
Shipping Weight : 10.9kg (24 lb)
JBL 4622/4622N Two-Way ScreenArray Cinema Loudspeaker System
Two-way system provides smooth and accurate
reproduction of cinema soundtracks
4622 is available as a Passive model with a network
(4622N) or the Bi-amp Ready 4622
Dual 380mm (15 in) low frequency transducers
Power capacity: 600 W continuous IEC pink noise
Nominal Impedance : 4622N: 4 Ohms
4622: HF 8 ohms
4622: LF 4 ohms
Rated Maximum SPL : 127dB, @ 1m (3.3ft) 133 dB peak
Bi-amp System Input Power Rating : LF: 600W HF: 100W
Crossover Frequency : 4622: 630Hz
4622N: 750Hz
Net Weight : 73kg (160 lb)
Shipping Weight : 81.3kg (179 lb)
4639 Low Frequency : 2 x 2035H-1 380 mm (15 in) dia.,
76 mm (3 in) edgewound ribbon
in 4509 LF enclosure
Net Weight : 73 kg (160 lb)
Shipping Weight : 70.4kg (155 lb)
4622-HF High Frequency Pack : One 2430H compression driver, One
2384 horn, one adjustable bracket
Shipping Weight : 10.9 kg (24 lb)
post #5 of 13 Old 11-21-2008, 03:53 AM - Thread Starter
JBL 4638 Low Frequency System
Usable Response to 30 Hz.
100 dB Sensitivity, lW, 1 m.
800 W Power Capacity 1600 W Continuous Program.
Two 380 mm (15 in) Low Frequency Transducers with Exceptional Performance.
Low Frequency Drivers : 2035H
Frequency Range : 30 Hz - 5 kHz (-10 dB)
Power Capacity (Continuous Pink Noise) : 800 W
Power Capacity (Continuous Program) : 1600 W
Sensitivity : 100 dB SPL (1W, 1m, 3.3ft.)
Crossover Frequency : 500 to 800 Hz recommended
Dimensions (H x W x D) : 991 x 648 x 451 mm
(39 x 25.5 x 17.75 in)
Net Weight : 42.7 kg (94 lb)
JBL 4648A Low Frequency System 4648A-8 (8 ohm) and 4648TH
Usable Response to 35 Hz
100 dB Sensitivity, 1 W, 1 m
1200 W Power Capacity
Direct Radiator Ported Enclosure
Low Frequency Drivers : 2) 2226H
Frequency Range : 30 Hz - 1.8 kHz (-10 dB)
Power Capacity (Continuous Pink Noise) : 1200 W
Power Capacity (Continuous Program) : 2400 W
JBL 4670D Cinema Loudspeaker System
Frequency Range: 34 Hz to 20 kHz
Sensitivity: 100 dB 1 W, 1 meter (3.3 ft)
Power Capacity: 600 W continuous IEC pink noise
Components:
Dual 380 mm (15 in) low frequency loudspeakers 100 mm (4 in) compression driver 90° x 40° Constant-Coverage Bi-Radial® horn
Selectable crossover adjustment for the proper alignment for 2380 series Bi-Radial® horns
Simple field assembly reduces labor costs
Frequency range : 34 Hz - 20 kHz (-10 dB)
Frequency response : 40 Hz - 16 kHz ( ± 3 dB)
Power capacity1 : 600 W continuous pink noise
Sensitivity : 100 dB 1 W (2.83V) 1 m (3.3 ft)
Nominal impedance : 4 ohms
Crossover frequency : 800 Hz
Nominal coverage : 90° horizontal, 40° vertical
Half-space reference efficiency : 6.3%
Maximum continuous acoustical power output : 28 acoustic W (sine wave input)
System polarity : Positive voltage to red terminal
Input connector : Color-coded push terminals
High frequency output connector : Color-coded push terminals
JBL 4675C Cinema Loudspeaker System
Components:
Dual 380 mm (15 in) low frequency loudspeakers 100 mm (4 in) compression driver 90° x 40° Constant-Coverage Bi-Radial® horns
alignment of 2360 Series Bi-Radial® horn
Low Frequency Drivers : (2) 2035H
High Frequency Driver : 2446H
High Frequency Horn : 2360A
Frequency Range : 35 Hz - 20 kHz (-10 dB)
Power Capacity (Continuous Pink Noise) : 600 W
Power Capacity (Continuous Program) : 1200 W
Crossover Frequency : 500 Hz
Horizontal Beamwidth : 90°
Dimensions (H x W x D) : 1797 x 770 x 949 mm
(70.75 x 30.3125 x 37.75 in)
Net Weight : 98 kg (215 lb)
JBL 4675C-4(8)LF Cinema Loudspeaker System
Sensitivity: 100 dB (LF), 113 (HF) 1 watt, 1 meter (3.3 ft)
Power Capacity: 1200 W (LF): 75 W (HF), AES pink noise
Components: Dual 380 mm (15 in) low frequency loudspeakers 100 mm (4 in) compression driver 90° x 40° Constant-Coverage Bi-Radial® horns
4675C-ELF approved by Lucasfilm, Ltd. for THX® system installations
Low Frequency Driver : (2) 2226H
Power Capacity : (LF) 1200 W, (HF) 75 W
Sensitivity : (LF): 100 dB (1 W, 1 m)
(HF): 113 dB (1 W, 1 m)
Crossover Frequency : 500 Hz - 630 Hz
Beamwidth : 90° horizontal, 40° vertical
Nominal Impedance : (LF) 4(8) ohms, (HF) 8 ohms
(70.75 x 30.3125 x 37.375 in)
post #6 of 13 Old 11-21-2008, 09:36 AM
electrobot9727's Avatar
Never used JBL before, JBL. Some neat looking stuff. I'll look into it, unless otherwise advised.
electrobot9727 is offline
post #7 of 13 Old 11-23-2008, 02:18 AM
Dizzman's Avatar
Dude... next time drop in a few pics, maybe the high points and some bloody links instead! oy Vay!
just hanging out, rollin with the flow.
Dizzman is offline
post #8 of 13 Old 11-23-2008, 07:05 AM
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1672 Post(s)
Liked: 914
Send a message via Skype™ to CINERAMAX
Spam, spam, spam, spam, spam, spam, spam, spam...
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is online now
post #9 of 13 Old 11-24-2008, 12:01 AM
Dizzman's Avatar
ok, that was funny
Dizzman is offline
post #10 of 13 Old 11-24-2008, 12:42 PM
Well, duh it's spam. haha. nice though.
post #11 of 13 Old 01-06-2009, 09:46 AM
flyingfaders's Avatar
JBL already shrunk the Cinema speakers to fit into your home. Check out jblsynthesis.com. The Syn-One-Array is the closest to a pure mini-cinema system with bi-amped fronts and 18" subs. systems includes electronics too!
flyingfaders is offline
post #12 of 13 Old 01-06-2009, 09:53 AM - Thread Starter
LOL
That’s no moon. it’s a JBL!
The height is just a bit over 7 feet it would just barley fit in my room, but if I was to turn the LF on its side no sweet. Let me talk to the bank manager.
post #13 of 13 Old 01-07-2009, 08:29 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
Spam, spam sausage and spam, spam eggs sausage and spam.....
I LIKE SPAM!
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is online now
Reply D-cinema Equipment and Theaters
