Dolby DP564 professional processor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-21-2008, 04:40 PM - Thread Starter
JBLsound4645's Avatar
List price: $4,600
Multifunction Display
For status indication and setup operations
Keypad
Access to all Dolby downmix, decode, listening, compression modes and user-assignable presets; input and monitoring selection
Volume Controls
Master and headphone levels
Headphone Output
6.35 mm (1/4-inch) standard stereo headphone jack, user-selectable: Dolby Headphone or stereo modes, +7 dBu maximum output into 50Ω nominal
RS-232 Serial Remote Port
8-pin female mini-DIN connector for remote control and software upgrades
Digital Audio Inputs
Three total: two BNC female connectors, unbalanced, 75Ω, signal levels per AES-3ID-1995 (SMPTE 276M); one fiber-optic via Toslink connector
AES Reference Input
BNC female with loop-through, unbalanced, 75Ω, signal levels per AES3-ID-1995 (SMPTE 276M), external 75Ω termination required
Digital Audio Outputs
Four BNC female connectors, unbalanced, 75Ω, signal levels per AES-3ID-1995 (SMPTE 276M)
Analog Audio Outputs
0 dBFS = +24 dBu; balanced floating; eight 3-pin XLR male connectors, 24-bit DAC
Linear Timecode Output Port
One SMPTE 12M-1995, BNC female, unbalanced, nominal output signal 1 Vp-p, output impedance 50Ω
RS-485 Serial Remote Control Input/
Output Port
9-pin female D-connector for remote control and software upgrades
General Purpose Input/Output Port
37-pin female D-connector, TTL compatible, may be configured to be level or edge sensitive using either polarity; supports Dolby Cat. No. 549 GPI/O controller
Ethernet Port
RJ-45 female connector, 10/100 Base-T with auto-detection
User manual for Dolby DP564
http://www.dolby.com/uploadedFiles/z...ual_issue1.pdf
JBLsound4645 is offline
post #2 of 9 Old 11-21-2008, 05:26 PM
fastl's Avatar
Quoted: 22 Post(s)
Genelec USA uses one of these in their pro-audio sales demo setup. I've heard really high quality dolby digital material decoded through this processor and it sounds as good as PCM. Did you just discover this thing or are you trying to sell one?
fastl is offline
post #3 of 9 Old 11-22-2008, 05:01 AM - Thread Starter
LOL I knew about the Dolby DP 564 years ago when it more or less first came out. No spearing the word that's all.
post #4 of 9 Old 11-30-2008, 07:32 PM
shaun5's Avatar
I am on a quest for a processor that will take my blu-ray spdif output and output 6 channels via 3 aes digital connections. Would this work?
shaun5 is offline
post #5 of 9 Old 12-31-2008, 03:14 PM
GXM
GXM's Avatar
YES AND NO
This unit is one of the best Dolby Digital decoders there is, but it is limited to just Dolby Digital, no plus, no loss less etc. I think the number is about 768 kbps max AC3. For Blu Ray in a high quality setup, you will want to be able to handle the newer advanced codecs. Since they use higher bit rates, they can only be sent over the HDMI output.
GXM is offline
post #6 of 9 Old 01-01-2009, 10:21 AM
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1674 Post(s)
Liked: 918
Send a message via Skype™ to CINERAMAX
Since a custom order DCI compatible Tact Audio TCS Mk 3 (beeing built as we speak) has 4 aes ebu pair digital ins, as well as handling all the hdmi codecs it is conceivable what shaun 5 wants to do MAY work.
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is online now
post #7 of 9 Old 01-01-2009, 04:13 PM
shaun5's Avatar
I have a mk 2. Has the mk 3 actually shipped to any end users?
shaun5 is offline
post #8 of 9 Old 01-01-2009, 06:52 PM
CINERAMAX's Avatar
Liked: 918
No but he is assembling a few.
Sincerely, GC*
post #9 of 9 Old 01-02-2009, 08:09 AM
shaun5's Avatar
Do you loose any of the other inputs with the DCI option? What is DCI option cost?
My quest ended with the a used mk 2, but now awaiting a possible upgrade to the mk 3...
shaun5 is offline
Reply D-cinema Equipment and Theaters
