D-Cinema Projector Aspect Ratio - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 02-21-2009, 02:30 PM
Art Sonneborn's Avatar
Quoted: 250 Post(s)
Liked: 312
Originally Posted by Dbuudo07 View Post
These threads are the best. I'm loving the info I'm getting. Keep it up guys.
Question: how do you integrate digital projectors, a Barco for example, into a home theater to use with a blu ray player? What kind of connections and hardware do you use/need? Can you use 1080p/24? Sorry if these are off topic. I just want to learn more.
This is one of Peter's fortes.
Art
My HT
For Sale: Stewart 14' wide Vistascope screen with BRIC controller
Contact me for pricing.
Art Sonneborn is offline
post #32 of 36 Old 02-21-2009, 02:52 PM
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1735 Post(s)
Liked: 955
Send a message via Skype™ to CINERAMAX
HI Dubdo,
Hardware wise you need the projector fitted with an hdcp carte. Then just plug in.
1080p24 is best but then it gets presented at 48 fps. The projector is capable of three times 48 for 3-D triple flash, that would be better than Imax 3D temporally.
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is offline
post #33 of 36 Old 02-21-2009, 03:46 PM
Dbuudo07's Avatar
Quoted: 218 Post(s)
Liked: 194
Originally Posted by CINERAMAX View Post
HI Dubdo,
That was a fast response! Thank you. What is happening in IMAX that would make it better than what you're offering? Aren't they running 2 2k pr now, or is it 2 4k? Are they going to up the frame rate to inhance the 3D experience?
Cinermax, I sent you an email(your website email address)
David Budo
Dbuudo07 is offline
post #34 of 36 Old 02-21-2009, 04:08 PM
CINERAMAX's Avatar
Liked: 955
I just happened to return from Imax Undersea 3D who getsa my Oscar for best 3D ever. I was able to compare, of course the resolution of Imax is way more than you can obtain presently with DLP but the ansi contrast of the Barco units seems superior. IF you can get a perfectly converged Barco (which may involve cherry picking a unit at the factory, AND PERHAPS some sort of Bribe ) and you use a Torus screen, then the tripled flash dolby system for 3D (using triple flash xpand 3d glases) will be much better than the Imax 3d I just saw.
Dub,
Your email has not come through for some reason. I will pm you.
Sincerely, GC*
post #35 of 36 Old 02-21-2009, 05:04 PM
Dbuudo07's Avatar
Quoted: 218 Post(s)
Liked: 194
Dub,
Thanks for the PM. I sent a new email.
Is Barco working on a 4k or higher design?
David Budo
Dbuudo07 is offline
post #36 of 36 Old 02-21-2009, 05:07 PM
CINERAMAX's Avatar
Liked: 955
Hi David, no development from TI since they won the format war new development has stopped, however on a 4 meter screen 13.13 feet the image from 4.5 feet away is phenomenally comfortable. That is the great advantage of having DCI units over consumer high end three chippers.
I am putting together a zip file for you to peruse.
Talk later...
Sincerely, GC*
Reply D-cinema Equipment and Theaters
